Re: SHAFT BEARINGS ON F-45
Hi Bruce-
The cutless bearings (one in the through hull and one in the skeg) can be replaced once the shaft is pulled.
As for water to the forward end, if the slots are plugged it would block the lubrication.
Of course, you should replace both bearings and then you also will need to do an engine alignment - which will should also necessitate replacing the engine mounts. Good luck.
John
Hull 42
In a message dated 11/18/2008 4:58:45 P.M. Eastern Standard Time, bmarserv@… writes:
Beside the cutlass bearing in the strut, I seem to have a cutlassbearing in the shaft log as the tube exits the hull. Am I the onlyone? If other F45 owners have replaced this or other FREEDOMS havethis bearing, what was the process? As well even though there appearsto be a bearing there is no source of water to the forward end whichis so important in cutlass performance. Can anyone shed some light.INDEPENDENCE HULL 33, BRUCE Get the Moviefone Toolbar. Showtimes, theaters, movie news more!
Posted by bmarserv (bmarserv@…>)
