The best and easiest way to make a gunmount sleeve lining is: get a
piece of pvc pipe-1/2 inch larger in diameter than the inside of the
gunmount tube–and the same length as the gunmount tube. Lengthwise,
cut out a section of the pvc-1/2 inch wide, for the length of the
pvc. Squeeze the pvc and insert in to the tube. The pvc will want to
expand to its original diameter, thereby placing outward pressure
onto the inside of the tube-keeping the pvc in place. Charlie
— In freedom21@yahoogroups.com, “Clark Myers” <cdmyers1@…> wrote:
Thomas,
It is more a mater of what I didn’t see. In your 12th photo you
gave
us a close-up of the gun mount. I could not see any sign of the
white palstic lining that should extend from the outside edge of
mount to about 1.5" in. The small holes you see around the edge of
the mount were used to anchor the ligning.
There are instructions for making new linings posted on
http://www.freedom21.info/gunmountingsleeve.htm
I wonder, has anybody contacted Garry Hoyt to see if there is a
source for ready made replacement linings? I’m going to need
replacements on Teke’s Pride in the near future.
Clark Myers
Teke’s Pride
F21 #345
— In freedom21@yahoogroups.com, “Thomas Curran”
<kaikouravoyager@> wrote:
Lining? What lining? Did you see something in my picture that I
didnt
see? [:-?]
I love the group already
T
<kaikouravoyager@>
Thanks Clark
I am talking to my favorite sailmaker in Vermont
I will keep you posted
T
— In freedom21@yahoogroups.com, “Clark Myers” cdmyers1@
Thomas,
[#-o] Newer is not always better!
Derek pointed out in his original posting that while he picks
up
more
speed on a beam reach with his rig over the gun mount rig; he
looses
straight down wind performance. Gibing is more difficult
with a
gennaker than with the Hoyt gun mount as well. Derek also
rightly
pointed out that his rig prevents him from entering class
races
(I
know,
when was the last time there was a class race?). I would
also
like
to
point out that as the Gennaker is not a reccognized F21 rig
there
are
no
Portsmith Handicap numbers for open racing. I admit racing
isn’t
everybody’s cup of tea. You may just want to cruise, but
rather
than
reinventing the wheel, why don’t you repair the lining on
your
gun
mount
and try the spinnaker rig? You might even like it if you try
it!
[=D>] After all Garry Hoyt is a genious!
The www.fredom21.info http://www.fredom21.info site has
links to
several sailmakers who make or have made F21 sails.
Clark Myers
Teke’s Pride
F21 #345
kaikouravoyager@
Good On Ya Mate [:)]
Thanks for the info. 23 years have passed since the gun
mount
concept,
the new sail setups are the way to go.
I do have the carbon mast will do as you say
Faster is better!
T
— In freedom21@yahoogroups.com, Derek Plante derek.plante@
Hi Thomas,
I used the aluminium Selden pole number 072-072-70. This
is
2080mm
long x 72 mill diameter. I shortened it to about 1500mm so
that it
stores neatly in the retracted position between the bow
fitting
just
to starboard of the mast. The slight offset to starboard
also
allows
pole to clear the mooring cleat. This size still gives
approx
700mm
extension from the bow when extended, which the local Selden
distributor
reckoned was about ideal.
I would have liked the carbon pole but baulked at the
high
price
(approx 4x the alloy!)
As for the sail dimensions, I will check these and get
back
to
you.
But I stress that my boat was built in Austraila with Alloy
mast;
so
may
differ from USA factory dimensions. So it would be
essential
to
measure
your own boat, after fitting the bowsprit, before any
sailmaking.
I have never sailed a Freedom with the standard gun mount
spinnaker
so
cannot compare ultimate performance. But I am happy with the
performance
of the gennaker; and it certainly is very simple to fit and
handle,
(the
Snuffer is invaluable). It also is much simpler, avoiding
miles
of
line that are needed for the GunMount system.
Happy sailing,
Derek Plante.
"At Last " 209, Lake Macquarie, NSW Australia.
— On Sun, 11/2/08, Thomas Curran kaikouravoyager@ wrote:
Subject: [freedom21] Re: Spinnakers: and North Gennakers
To: freedom21@yahoogroups.com
Date: Sunday, November 2, 2008, 5:26 PM
Derek
Which Selden spar did you use, Carbon or aluminum? and
which
dimension.
I have downloaded there pdf file for choices
Tom
— In freedom21@yahoogrou ps.com, “derek.plante”
<derek.plante@
Hi All,
I have noted some recent discussion on the F21 Forum
about
spinnakers. Can I add a different point of view as seen
from
“Down
Under”!
My F21 “At Last” is one of only 4 Freedoms that I am
aware of
in
Australia. I have owned it now for about 10 years.
It is unusual in having an aluminium mast by Spunspar in
Sydney;
it was never fitted with the gunmount spinnaker.
For years I procrastinated about fitting a spinnaker,
until my
son
Julian who works for North Sails in Sydney, suggested
that a
simpler,
and cheaper option would be to go for a gennaker flown
from
one
of
the new Selden retractable bowsprits.
We just finished fitting this rig a couple of weeks
ago,
have
now
sailed with it 3 times. Verdict is great! Extremely
simple to
fit,
and very easy to hoist and drop using North’s clever
“Snuffer”.
Only
possible drawbacks are that it is obviously not legal
for
F21
Class
racing, which we do not have in Australia; and that one
cannot
sail
as square as with conventional spinnaker. This
necessitates a
bit
of
downwind tacking, which is fun as the boat is dead easy
to
gybe.
For anyone interested, the Selden pole is not cheap,
but
is
very
well
designed, and constructed, and worth the cost. We used
their
smallest
pole (2 meters long), and shortened it to approx 1.5
meters.
This
is
about the right length to be able to store the
retracted
pole
on
deck
between the bow and mast; and gives approx 700mm
extension
beyond
bow when extended through the special ring bowfitting.
We also fitted an new North mainsail with a loose foot,
this
is also a big improvement, with much better and more
accurate
control
of sailshape with the outhaul, compared to the previous
bolt
rope.
I have just added photos of the rig to the “At Last”
section
of
photos page on this F21 Forum site.
Derek Plante.
“At Last”, Lake Macquarie, New South Wales, Australia.
Lucky me, I had a machinist friend machine black plastic pipe to fit the entire length of the gunmount pipe.He machined the inside to the diameter of the pole. A little silicone each season and It’s ready to go.
Lucky bfn
----- Original Message ----From: Charlie L. <clivaday@…>To: freedom21@yahoogroups.comSent: Thursday, November 6, 2008 11:40:19 AMSubject: [freedom21] Re: Spinnakers: and North Gennakers; GUNMOUNT SLEEVE LINING
The best and easiest way to make a gunmount sleeve lining is: get a piece of pvc pipe-1/2 inch larger in diameter than the inside of the gunmount tube–and the same length as the gunmount tube. Lengthwise, cut out a section of the pvc-1/2 inch wide, for the length of the pvc. Squeeze the pvc and insert in to the tube. The pvc will want to expand to its original diameter, thereby placing outward pressure onto the inside of the tube-keeping the pvc in place. Charlie — In freedom21@yahoogrou ps.com, “Clark Myers” <cdmyers1@… .> wrote:>> Thomas,> > It is more a mater of what I didn’t see. In your 12th photo you gave > us a close-up of the gun mount. I could not see any sign of the > white palstic lining that should extend from the outside edge of
the > mount to about 1.5" in. The small holes you see around the edge of > the mount were used to anchor the ligning. > > There are instructions for making new linings posted on > http://www.freedom2 1.info/gunmounti ngsleeve. htm> > I wonder, has anybody contacted Garry Hoyt to see if there is a > source for ready made replacement linings? I’m going to need > replacements on Teke’s Pride in the near future.> > Clark Myers> Teke’s Pride> F21 #345> > > — In freedom21@yahoogrou ps.com, “Thomas Curran” > <kaikouravoyager@ > wrote:> >> > Lining? What lining? Did you see something in my picture that I
didnt> > see? [:-?]> > I love the group already> > T> > — In freedom21@yahoogrou ps.com, “Thomas Curran” <kaikouravoyager@ >> > wrote:> > >> > > Thanks Clark> > > I am talking to my favorite sailmaker in Vermont> > > I will keep you posted> > > T> > > — In freedom21@yahoogrou ps.com, “Clark Myers” cdmyers1@ wrote:> > > >> > > >> > > > Thomas,> > > >> > > > [#-o] Newer is not always better!> > > >> > > > Derek pointed out in his original posting that
while he picks up> > more> > > > speed on a beam reach with his rig over the gun mount rig; he > looses> > > > straight down wind performance. Gibing is more difficult with a> > > > gennaker than with the Hoyt gun mount as well. Derek also > rightly> > > > pointed out that his rig prevents him from entering class races > (I> > > know,> > > > when was the last time there was a class race?). I would also > like> > to> > > > point out that as the Gennaker is not a reccognized F21 rig > there> > are> > > no> > > > Portsmith Handicap numbers for open racing. I admit racing > isn’t> > > > everybody’s cup of tea. You may just want to cruise, but rather> > than> > > > reinventing the wheel, why
don’t you repair the lining on your > gun> > > mount> > > > and try the spinnaker rig? You might even like it if you try > it!> > > > [=D>] After all Garry Hoyt is a genious!> > > >> > > > The www.fredom21. info <http://www.fredom21 .info> site has > links to> > > > several sailmakers who make or have made F21 sails.> > > >> > > > Clark Myers> > > >> > > > Teke’s Pride> > > >> > > > F21 #345> > > >> > > >> > > > — In freedom21@yahoogrou ps.com, “Thomas Curran” > kaikouravoyager@> >
wrote:> > > > >> > > > > Good On Ya Mate [:)]> > > > > Thanks for the info. 23 years have passed since the gun mount> > > concept,> > > > > the new sail setups are the way to go.> > > > > I do have the carbon mast will do as you say> > > > > Faster is better!> > > > > T> > > > > — In freedom21@yahoogrou ps.com, Derek Plante derek.plante@> > wrote:> > > > > >> > > > > > Hi Thomas,> > > > > >> > > > > > I used the aluminium Selden pole number 072-072-70. This is> > 2080mm> > > > > long x 72 mill diameter. I shortened it to about
1500mm so > that it> > > > > stores neatly in the retracted position between the bow > fitting> > and> > > > just> > > > > to starboard of the mast. The slight offset to starboard also> > allows> > > > the> > > > > pole to clear the mooring cleat. This size still gives approx> > 700mm> > > > > extension from the bow when extended, which the local Selden> > > > distributor> > > > > reckoned was about ideal.> > > > > > I would have liked the carbon pole but baulked at the high > price> > > > > (approx 4x the alloy!)> > > > > > As for the sail dimensions, I will check these and get back > to> > > you.> > > > > But I stress that my boat was built in
Austraila with Alloy > mast;> > so> > > > may> > > > > differ from USA factory dimensions. So it would be essential > to> > > > measure> > > > > your own boat, after fitting the bowsprit, before any > sailmaking.> > > > > > I have never sailed a Freedom with the standard gun mount> > > spinnaker> > > > so> > > > > cannot compare ultimate performance. But I am happy with the> > > > performance> > > > > of the gennaker; and it certainly is very simple to fit and> > handle,> > > > (the> > > > > Snuffer is invaluable). It also is much simpler, avoiding the> > miles> > > of> > > > > line that are needed for the GunMount system.> > > > >
Happy sailing,> > > > > >> > > > > > Derek Plante.> > > > > >> > > > > > "At Last " 209, Lake Macquarie, NSW Australia.> > > > > >> > > > > > — On Sun, 11/2/08, Thomas Curran kaikouravoyager@ wrote:> > > > > >> > > > > > From: Thomas Curran kaikouravoyager@> > > > > > Subject: [freedom21] Re: Spinnakers: and North Gennakers> > > > > > To: freedom21@yahoogrou ps.com> > > > > > Date: Sunday, November 2, 2008, 5:26 PM> > > > > >> > > > > >> > > > > >> > > > > >> >
Derek> > > > > > Which Selden spar did you use, Carbon or aluminum? and which> > > > > dimension.> > > > > > I have downloaded there pdf file for choices> > > > > > Thanks> > > > > > Tom> > > > > > — In freedom21@yahoogrou ps.com, “derek.plante” > <derek.plante@> > > > …>> > > > > > wrote:> > > > > > >> > > > > > > Hi All,> > > > > > >> > > > > > > I have noted some recent discussion on the F21 Forum about> > > > > > > spinnakers. Can I add a different point of view as seen > from> > >
“Down> > > > > > > Under”!> > > > > > > My F21 “At Last” is one of only 4 Freedoms that I am > aware of> > in> > > > > > > Australia. I have owned it now for about 10 years.> > > > > > > It is unusual in having an aluminium mast by Spunspar in> > Sydney;> > > > and> > > > > > > it was never fitted with the gunmount spinnaker.> > > > > > >> > > > > > > For years I procrastinated about fitting a spinnaker, > until my> > > son> > > > > > > Julian who works for North Sails in Sydney, suggested > that a> > > > > simpler,> > > > > > > and cheaper option would be to go for a gennaker flown > from> > one> > > of>
the new Selden retractable bowsprits.> > > > > > >> > > > > > > We just finished fitting this rig a couple of weeks ago, > and> > > have> > > > > now> > > > > > > sailed with it 3 times. Verdict is great! Extremely > simple to> > > fit,> > > > > > > and very easy to hoist and drop using North’s clever> > “Snuffer”.> > > > Only> > > > > > > possible drawbacks are that it is obviously not legal for > F21> > > > Class> > > > > > > racing, which we do not have in Australia; and that one > cannot> > > > sail> > > > > > > as square as with conventional spinnaker. This > necessitates a> > > bit>
of> > > > > > > downwind tacking, which is fun as the boat is dead easy to> > gybe.> > > > > > > For anyone interested, the Selden pole is not cheap, but > is> > very> > > > > well> > > > > > > designed, and constructed, and worth the cost. We used > their> > > > > smallest> > > > > > > pole (2 meters long), and shortened it to approx 1.5 > meters.> > > This> > > > is> > > > > > > about the right length to be able to store the retracted > pole> > on> > > > > deck> > > > > > > between the bow and mast; and gives approx 700mm extension> > > beyond> > > > > the> > > > > > > bow
when extended through the special ring bowfitting.> > > > > > > We also fitted an new North mainsail with a loose foot, > this> > > > > > > is also a big improvement, with much better and more > accurate> > > > > control> > > > > > > of sailshape with the outhaul, compared to the previous > bolt> > > rope.> > > > > > >> > > > > > > I have just added photos of the rig to the “At Last” > section> > of> > > > the> > > > > > > photos page on this F21 Forum site.> > > > > > >> > > > > > > Derek Plante.> > > > > > > “At Last”, Lake Macquarie, New South Wales, Australia.> > > > > > >> > > > > >> >
Posted by Clark Myers (cdmyers1@…>)
Charlie,
Have you actualy tried this idea on your boat? It sounds a lot
easier than John’s well documented replacement? No glue involved?
Clark
Teke’s Pride
Lengthwise,
to
— In freedom21@yahoogroups.com, “Clark Myers” <cdmyers1@> wrote:
Thomas,
gave
of
Clark Myers
Teke’s Pride
F21 #345
didnt
see? [:-?]
T
<kaikouravoyager@>
Thanks Clark
T
Thomas,
picks
up
more
he
looses
with a
rightly
races
(I
know,
also
like
to
there
are
no
isn’t
rather
than
your
gun
mount
try
it!
links to
Clark Myers
Teke’s Pride
F21 #345
kaikouravoyager@
mount
concept,
Faster is better!
T
derek.plante@
Hi Thomas,
This
is
2080mm
so
that it
fitting
just
also
allows
approx
700mm
Selden
distributor
high
price
back
to
you.
Alloy
mast;
so
may
essential
to
measure
sailmaking.
mount
spinnaker
so
performance
handle,
(the
miles
of
Happy sailing,
Derek Plante.
Derek
which
dimension.
Tom
<derek.plante@
Hi All,
about
seen
from
“Down
Under”!
aware of
in
in
Sydney;
until my
son
that a
simpler,
flown
from
one
of
ago,
have
now
simple to
fit,
“Snuffer”.
Only
for
F21
Class
one
cannot
sail
necessitates a
bit
of
easy
to
gybe.
but
is
very
well
used
their
smallest
meters.
This
is
retracted
pole
on
deck
extension
beyond
foot,
this
accurate
control
previous
bolt
rope.
section
of
Derek Plante.
Yes, on a previously owned F21. No glue. You could use pvc 1" wider
than the tube (instead of 1/2") for a tighter fit. Charlie
Charlie,
Clark
Teke’s Pride
a
Lengthwise,
to
Thomas,
you
gave
of
edge
of
Clark Myers
Teke’s Pride
F21 #345
I
didnt
see? [:-?]
T
<kaikouravoyager@>
Thanks Clark
T
Thomas,
picks
up
more
rig;
he
looses
with a
also
rightly
races
(I
know,
also
like
to
rig
there
are
no
racing
isn’t
rather
than
your
gun
mount
try
it!
has
links to
Clark Myers
Teke’s Pride
F21 #345
kaikouravoyager@
mount
concept,
Faster is better!
T
derek.plante@
Hi Thomas,
This
is
2080mm
so
that it
fitting
just
starboard
also
allows
approx
700mm
Selden
distributor
high
price
get
back
to
you.
Alloy
mast;
so
may
essential
to
measure
sailmaking.
mount
spinnaker
so
with
performance
handle,
(the
avoiding
miles
of
Happy sailing,
Derek Plante.
Gennakers
Derek
which
dimension.
Tom
<derek.plante@
Hi All,
Forum
about
seen
from
“Down
Under”!
am
aware of
in
Spunspar
in
Sydney;
spinnaker,
until my
son
suggested
that a
simpler,
flown
from
one
of
ago,
have
now
simple to
fit,
“Snuffer”.
Only
legal
for
F21
Class
one
cannot
sail
necessitates a
bit
of
easy
to
gybe.
cheap,
but
is
very
well
used
their
smallest
1.5
meters.
This
is
retracted
pole
on
deck
extension
beyond
bowfitting.
foot,
this
more
accurate
control
previous
bolt
rope.
Last”
section
of
Derek Plante.
Australia.
