Re: staysail (Clivaday''s message 30)
Hi Charlie,
I am thinking about adding a 3rd halyard for my spinnaker. I have a
Harken furler for my jib. The only F-21 3rd Halyard Mast Hound that
I have seen is what Matt Dwyer put on his F-21, “Engineered”. It is
a very small eye strap (which I could not identify the manufacture)
and feel it may not be adequate. Also he installed it with sheet
metal screws instead of rivets. I would appreciate if you could
describe what you used and how you installed your 3rd halyard.
Thanks in advance,
Nick,
Blue Raven, F-21, #295
— In freedom21@yahoogroups.com, “Charlie L.” <clivaday@b…> wrote:
I’ve owned, used and raced with the small and the large F21
staysail.
The smaller one is not of much use, because you would use it only
in
very strong wind, and would be just as well off with no staysail.
For
me, it was a waste of money. The large one is great from 0-12 knots
of
wind. I used a small Harken staysail furler for my jibs, and
strongly
recommend doing that. I could furl in the large staysail a few
turns,
and still use it in 12-17 knots. Once you use the furler, you’ll
wonder
how you ever did without it. Happy sailing. Charlie
— In freedom21@yahoogroups.com, “billpeggyweber”
<billpeggyweber@y…> wrote:
I,m thinking about buying a sraysail. Hoyt has two 65 and 100
sq.
ft. any suggestions or thoughts about the choice and when to use.
Hi Nick. I set up my additional spinnaker halyard just as Matt did
his. I use the original (lower) sheave for the staysail, which I
winch up pretty tight for racing. Happy sailing. Charlie
— In freedom21@yahoogroups.com, “Nick Marino” <blueraven1@c…>
Hi Charlie,
a
that
is
Thanks in advance,
Nick,
staysail.
in
For
knots
of
strongly
turns,
wonder
sq.
use.
