Re: The Race (and PHRF)
Posted by j32080 (j32080@…>)
A J/24, or any J/Boat for that matter, is a tough boat to beat. The pointing ability is supurb. I know as I have a J/32 (cruiser). I sailed a J/24 once (when I still owned my Freedom 21) and found that the windex (apparent wind indicator) was less than 5 degrees!
Additional info:
http://www.ussailing.org/phrf/what_is_phrf.asp
A common item is to use TOT (Time on Time) vs. TOD (Time on Distance). It evens things out a bit.http://www.ussailing.org/phrf/TOT.asp
The following article also gives of nice explanation of how it works with both TOD and TOT:http://aroundthebuoys.com/html/time_on_time.html
I also agree that you should get yourself the “Class” (overlapping) staysail and sail as a sloop vs. a cat. Take the PHRF “hit” for some better pointing ability. Having done some “Beer Can” racing under both, it is a lot better.
-JohnFormer owner Blue Merle (#259)J/32 Liberty
— In freedom21@yahoogroups.com, “Joe Conron” <joeconron@…> wrote:>> Doug,> > > > PHRF ratings are a form of time-on-distance handicapping. In this system,> each boat is given a provisional rating that estimates how much longer it> would take that boat to sail one nautical mile compared to some baseline> “imaginary” boat.> > > > The ratings take into account (among other things) waterline length,> displacement, sail area, and keel depth.> > > > Then, local PHRF organizations are supposed to record finish times for> sailed races and adjust the rating based on actual performance in that area> (ratings really vary based on local conditions*).> > > > So, the way finish position is computed is as follows:> > > > Take the smallest PHRF hdcp time from all competitors, and subtract that> value from every competitor’s hdcp.> > I’ll assume that the E22 was the fasted rated boat in the fleet, so, E22> rates about 120 and you rate about 240 (only if you hoist your staysail - if> not, then your PHRF should be about 255**). Hence, E22 gives you 120> seconds per mile, and gets zero seconds per mile from everyone else.> > > > Your race is 10 miles, so, your adjusted finish time gets adjusted by> subtracting 10*120 = 1200 seconds from your actual finish time. Similarly,> the J24 rates about 170, so it gives you 70 seconds per mile.> > > > * The F21 is a great light air PHRF competitor, or when most of the course> is off-wind. On the other hand, if wind is in the ideal sailing range (10 → 15), and much of the course is upwind, an F21 will find it very hard to> finish in the top half of a good fleet of sloop-rigged boats.> > > > ** In the north-east, F21 rates 255 as a cat rig, and 243 as a sloop rig> > > > Best regards,> > > > Joe Conron> > Former owner F21 #179> > > > > > > > _____ > > From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf> Of Doug> Sent: Tuesday, September 16, 2008 9:22 PM> To: freedom21@yahoogroups.com> Subject: [freedom21] The Race> > > > We sailed the race Saturday, it was a 10 mile race. My boat came in > fith place but with the handicap we were fourth. I got beat out by an > E22, and 2 J24’s. The race was a lot of fun, it was so much fun for my > wife that she can’t wait to enter the next race. I still don’t > understand how the handy cap is equated, is it 240 seconds for each > NM? and then is it subtracted from your over all time in seconds? > Could someone please clarify. > > 10 NM race> 2h 53m = 10380> 240s * 10 nm = 2400> 10380-2400=7980> > Is that the correct way to figure out your corrected time?> > Thanks,> Doug>
