Re: Towing a dinghy vs towing an inflatable
Al,
Many suggestions done here were for towing inflatables or ribs.
Towing these is a drag, also litterally, and needs special
attention. Towing a hard dink that’s built for its purpose is a lot
easier. I have an 8’ Walker Bay and towed it across the North Sea
and back (120 NM crossing)without any problem. I’m installing an
automatic bailer now to get rid of spray and rain. A good dinghy for
towing has a long skeg (or two) to make it course-stable.
michel
<ajlorman@…> wrote:
OK, so I try anywhere from a 10’ to a 60’ line. Or a Dinghy-Tow
(which
I like). Or I saw the heck with it and buy a set of davits from
Garhauer.
Many thanks for all the suggestions.
Al
-----Original Message-----
[mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Jerome
Weinraub
Sent: Thursday, June 01, 2006 3:24 PM
Subject: Re: [freedomyachts2003] Re: Towing a dinghy
Absolutely-sometimes my inflatable is on a 60 ft line,sometimes 10
ft
aft.
Whatever works best.Wind,sea course and speed all figure into the
decision.
Also-tow it light.-the less weight in the dink,the better you can
handle
it.BTW,because it is always towed,my dink is
called"Shirley,Goodness,and
Mercy".
Sent: Thursday, June 01, 2006 2:32 PM
Subject: RE: [freedomyachts2003] Re: Towing a dinghy
You adjust it according to the size of the seas and how it rides
on it.
Reply-To: freedomyachts2003@yahoogroups.com
Subject: [freedomyachts2003] Re: Towing a dinghy
Date: Thu, 01 Jun 2006 17:41:09 -0000
I have a portabote, which I carry on a sailboard carrier ouside
life lines. You might want to check out “Dinghy Tow”
http://www.dinghy-tow.com/. No experience, but I’ve seen quite a
few. They have been installed on Freedoms and they have pictures
on
the website.
— In freedomyachts2003@yahoogroups.com, “ajlorman” <ajlorman@>
I recently took the plunge and bought a 9’ rigid dinghy. I’ve
never
towed a dinghy before and don’t have a clue as to how to do so
safely
(e.g., how long a tow rope do I use, etc.). I sail on the
generally
peaceful Chesapeake. Any suggestions?
Many thanks.
Al Lorman
F30 Ab Initio
Yahoo! Groups Links
Yahoo! Groups Links
SPONSORED LINKS
Sailing schools
<http://groups.yahoo.com/gads?
t=ms&k=Sailing+schools&w1=Sailing+schools&
w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing
+ad
venture&w6=Sailing&c=6&s=122&.sig=nM_33Bwh2_UhuqSYWZR8Xw>
Sailing
instruction
t=ms&k=Sailing+instruction&w1=Sailing+scho
ols&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sai
lin
g+adventure&w6=Sailing&c=6&s=122&.sig=PLKTippWs7H3hJMQiiV1Dg>
Sailing
lesson
t=ms&k=Sailing+lesson&w1=Sailing+schools&w
2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+
adv
enture&w6=Sailing&c=6&s=122&.sig=BW-ssa-AtK1bKwgxZtYhsg>
Sailing course
t=ms&k=Sailing+course&w1=Sailing+schools&w
adv
enture&w6=Sailing&c=6&s=122&.sig=iJziK8qHrpaIJG_Q19twrg>
Sailing
adventure
t=ms&k=Sailing+adventure&w1=Sailing+school
s&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Saili
ng+
adventure&w6=Sailing&c=6&s=122&.sig=luRjwGYgtoRAVO_RIh446A>
Sailing
t=ms&k=Sailing&w1=Sailing+schools&w2=Saili
ng+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adventu
re&
w6=Sailing&c=6&s=122&.sig=H5HiiLFUXHyIpCEv0TmINg>
YAHOO! GROUPS LINKS
IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax
matters was neither written nor intended by the sender or Mayer,
Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer
for the purpose of avoiding tax penalties that may be imposed under
U.S. tax law. If any person uses or refers to any such tax advice in
promoting, marketing or recommending a partnership or other entity,
investment plan or arrangement to any taxpayer, then (i) the advice
was written to support the promotion or marketing (by a person other
than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter,
and (ii) such taxpayer should seek advice based on the taxpayers
particular circumstances from an independent tax advisor
This email and any files transmitted with it are intended solely
for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system
manager. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail.
Thanks to all who provided advice on towing a dinghy. I have just returned from a four day cruise on the Chesapeake and I’m pleased to report that my dinghy, a Dyer Dhow, performed admirably, including gracefully navigating a thunderstorm with 30 knot winds. She rarely wandered and usually tracked better than I could helm.
Since I could not quickly find the tow rope I wanted, New England Rope’s water rescue rope, I bought a Worst Marine 60’ polypropylene tube tow rope with a breaking strength of 4100 lbs. It had eyes on both ends and I used a carabiner to attached one end to the bow eye and the other was cleated off on my midship cleat. The length of the tow rope at any given time was adjusted by tying off on the stern cleat.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of michel.capelSent: Monday, June 05, 2006 5:49 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Towing a dinghy vs towing an inflatableAl,Many suggestions done here were for towing inflatables or ribs. Towing these is a drag, also litterally, and needs special attention. Towing a hard dink that’s built for its purpose is a lot easier. I have an 8’ Walker Bay and towed it across the North Sea and back (120 NM crossing)without any problem. I’m installing an automatic bailer now to get rid of spray and rain. A good dinghy for towing has a long skeg (or two) to make it course-stable. michel— In freedomyachts2003@yahoogroups.com, “Lorman, Alvin J.” <ajlorman@…> wrote:>> OK, so I try anywhere from a 10’ to a 60’ line. Or a Dinghy-Tow (which> I like). Or I saw the heck with it and buy a set of davits from> Garhauer. > > Many thanks for all the suggestions.> > Al> > -----Original Message-----> From: freedomyachts2003@yahoogroups.com> [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Jerome Weinraub> Sent: Thursday, June 01, 2006 3:24 PM> To: freedomyachts2003@yahoogroups.com> Subject: Re: [freedomyachts2003] Re: Towing a dinghy> > > Absolutely-sometimes my inflatable is on a 60 ft line,sometimes 10 ft> aft. > Whatever works best.Wind,sea course and speed all figure into the> decision. > Also-tow it light.-the less weight in the dink,the better you can handle> > it.BTW,because it is always towed,my dink is called"Shirley,Goodness,and> > Mercy".> ----- Original Message ----- > From: “LINSEY JOHNSON” <linseyjohnson6@…>> To: <freedomyachts2003@yahoogroups.com>> Sent: Thursday, June 01, 2006 2:32 PM> Subject: RE: [freedomyachts2003] Re: Towing a dinghy> > > You adjust it according to the size of the seas and how it rides on it.> > > >From: “macks011” <macks04@…>> >Reply-To: freedomyachts2003@yahoogroups.com> >To: freedomyachts2003@yahoogroups.com> >Subject: [freedomyachts2003] Re: Towing a dinghy> >Date: Thu, 01 Jun 2006 17:41:09 -0000> >> >I have a portabote, which I carry on a sailboard carrier ouside the> >life lines. You might want to check out “Dinghy Tow”> >http://www.dinghy-tow.com/. No experience, but I’ve seen quite a> >few. They have been installed on Freedoms and they have pictures on> >the website.> >> >> >> >— In freedomyachts2003@yahoogroups.com, “ajlorman” <ajlorman@>> >wrote:> > >> > > I recently took the plunge and bought a 9’ rigid dinghy. I’ve> >never> > > towed a dinghy before and don’t have a clue as to how to do so> >safely> > > (e.g., how long a tow rope do I use, etc.). I sail on the> >generally> > > peaceful Chesapeake. Any suggestions?> > >> > > Many thanks.> > >> > > Al Lorman> > > F30 Ab Initio> > >> >> >> >> >> >> >> >> >> >> >Yahoo! Groups Links> >> >> >> >> >> >> >> > > > > > > Yahoo! Groups Links> > > > > > > > > > > > > SPONSORED LINKS > Sailing schools> http://groups.yahoo.com/gads?t=ms&k=Sailing+schools&w1=Sailing+schools& w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+ad> venture&w6=Sailing&c=6&s=122&.sig=nM_33Bwh2_UhuqSYWZR8Xw> Sailing> instruction> http://groups.yahoo.com/gads?t=ms&k=Sailing+instruction&w1=Sailing+scho ols&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailin> g+adventure&w6=Sailing&c=6&s=122&.sig=PLKTippWs7H3hJMQiiV1Dg> Sailing> lesson> http://groups.yahoo.com/gads?t=ms&k=Sailing+lesson&w1=Sailing+schools&w 2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adv> enture&w6=Sailing&c=6&s=122&.sig=BW-ssa-AtK1bKwgxZtYhsg> > Sailing course> http://groups.yahoo.com/gads?t=ms&k=Sailing+course&w1=Sailing+schools&w 2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adv> enture&w6=Sailing&c=6&s=122&.sig=iJziK8qHrpaIJG_Q19twrg> Sailing> adventure> http://groups.yahoo.com/gads?t=ms&k=Sailing+adventure&w1=Sailing+school s&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+> adventure&w6=Sailing&c=6&s=122&.sig=luRjwGYgtoRAVO_RIh446A> Sailing> http://groups.yahoo.com/gads?t=ms&k=Sailing&w1=Sailing+schools&w2=Saili ng+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adventure&> w6=Sailing&c=6&s=122&.sig=H5HiiLFUXHyIpCEv0TmINg> > > _____ > > YAHOO! GROUPS LINKS > > > > * Visit your group "freedomyachts2003> http://groups.yahoo.com/group/freedomyachts2003 " on the web.> > * To unsubscribe from this group, send an email to:> freedomyachts2003-unsubscribe@yahoogroups.com> <mailto:freedomyachts2003-unsubscribe@yahoogroups.com?subject=Unsubscrib> e> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of> Service http://docs.yahoo.com/info/terms/ . > > > _____> > IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisor> > This email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.>IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Al,
I hope you have a screw carabiner. Non-screw carabiners are famous
for opening on unexpecting moments when they are not under constant
force. I always use two painters, one main and one spare that is a
little less tight than the other.
to
rarely
Rope’s
tow
ends and
other was
Al Lorman
F30 Ab Initio
michel.capel
inflatable
Al,
lot
for
michel
(which
Garhauer.
Al
Weinraub
10
ft
aft.
decision.
can
handle
Mercy".
on it.
a
pictures
on
the website.
I’ve
never
so
safely
generally
Many thanks.
Al Lorman
F30 Ab Initio
Yahoo! Groups Links
Yahoo! Groups Links
SPONSORED LINKS
Sailing schools
+ad
Sailing
instruction
lin
Sailing
lesson
adv
Sailing course
adv
Sailing
adventure
ng+
Sailing
re&
YAHOO! GROUPS LINKS
  •  Visit your group "freedomyachts2003
  •  To unsubscribe from this group, send an email to:
subject=Unsubscrib
e>
  •  Your use of Yahoo! Groups is subject to the Yahoo! Terms
of
taxpayer
under
in
entity,
advice
other
addressed.
SPONSORED LINKS
Sailing schools
+ad
Sailing
instruction
lin
Sailing
lesson
adv
Sailing course
adv
Sailing
adventure
ng+
Sailing
re&
YAHOO! GROUPS LINKS
Michel:
I plead guilty. The only carabiner we had at hand was a heavy duty, spring-loaded climbing carabiner. I promise to buy a screw on type.
Many thanks.
Al
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of michel.capelSent: Monday, June 12, 2006 5:19 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Towing a dinghy vs towing an inflatable
Al,I hope you have a screw carabiner. Non-screw carabiners are famous for opening on unexpecting moments when they are not under constant force. I always use two painters, one main and one spare that is a little less tight than the other.Michel— In freedomyachts2003@yahoogroups.com, “Lorman, Alvin J.” <ajlorman@…> wrote:>> Thanks to all who provided advice on towing a dinghy. I have just> returned from a four day cruise on the Chesapeake and I’m pleased to> report that my dinghy, a Dyer Dhow, performed admirably, including> gracefully navigating a thunderstorm with 30 knot winds. She rarely> wandered and usually tracked better than I could helm.> > Since I could not quickly find the tow rope I wanted, New England Rope’s> water rescue rope, I bought a Worst Marine 60’ polypropylene tube tow> rope with a breaking strength of 4100 lbs. It had eyes on both ends and> I used a carabiner to attached one end to the bow eye and the other was> cleated off on my midship cleat. The length of the tow rope at any> given time was adjusted by tying off on the stern cleat. > > Al Lorman> F30 Ab Initio> > -----Original Message-----> From: freedomyachts2003@yahoogroups.com> [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of michel.capel> Sent: Monday, June 05, 2006 5:49 AM> To: freedomyachts2003@yahoogroups.com> Subject: [freedomyachts2003] Re: Towing a dinghy vs towing an inflatable> > > Al,> > Many suggestions done here were for towing inflatables or ribs. > Towing these is a drag, also litterally, and needs special > attention. Towing a hard dink that’s built for its purpose is a lot > easier. I have an 8’ Walker Bay and towed it across the North Sea > and back (120 NM crossing)without any problem. I’m installing an > automatic bailer now to get rid of spray and rain. A good dinghy for > towing has a long skeg (or two) to make it course-stable. > michel> > > — In freedomyachts2003@yahoogroups.com, “Lorman, Alvin J.” > <ajlorman@> wrote:> >> > OK, so I try anywhere from a 10’ to a 60’ line. Or a Dinghy-Tow > (which> > I like). Or I saw the heck with it and buy a set of davits from> > Garhauer. > > > > Many thanks for all the suggestions.> > > > Al> > > > -----Original Message-----> > From: freedomyachts2003@yahoogroups.com> > [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Jerome > Weinraub> > Sent: Thursday, June 01, 2006 3:24 PM> > To: freedomyachts2003@yahoogroups.com> > Subject: Re: [freedomyachts2003] Re: Towing a dinghy> > > > > > Absolutely-sometimes my inflatable is on a 60 ft line,sometimes 10 > ft> > aft. > > Whatever works best.Wind,sea course and speed all figure into the> > decision. > > Also-tow it light.-the less weight in the dink,the better you can > handle> > > > it.BTW,because it is always towed,my dink is > called"Shirley,Goodness,and> > > > Mercy".> > ----- Original Message ----- > > From: “LINSEY JOHNSON” <linseyjohnson6@>> > To: <freedomyachts2003@yahoogroups.com>> > Sent: Thursday, June 01, 2006 2:32 PM> > Subject: RE: [freedomyachts2003] Re: Towing a dinghy> > > > > > You adjust it according to the size of the seas and how it rides > on it.> > > > > > >From: “macks011” <macks04@>> > >Reply-To: freedomyachts2003@yahoogroups.com> > >To: freedomyachts2003@yahoogroups.com> > >Subject: [freedomyachts2003] Re: Towing a dinghy> > >Date: Thu, 01 Jun 2006 17:41:09 -0000> > >> > >I have a portabote, which I carry on a sailboard carrier ouside > the> > >life lines. You might want to check out “Dinghy Tow”> > >http://www.dinghy-tow.com/. No experience, but I’ve seen quite a> > >few. They have been installed on Freedoms and they have pictures > on> > >the website.> > >> > >> > >> > >— In freedomyachts2003@yahoogroups.com, “ajlorman” <ajlorman@>> > >wrote:> > > >> > > > I recently took the plunge and bought a 9’ rigid dinghy. I’ve> > >never> > > > towed a dinghy before and don’t have a clue as to how to do so> > >safely> > > > (e.g., how long a tow rope do I use, etc.). I sail on the> > >generally> > > > peaceful Chesapeake. Any suggestions?> > > >> > > > Many thanks.> > > >> > > > Al Lorman> > > > F30 Ab Initio> > > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >Yahoo! Groups Links> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > Yahoo! Groups Links> > > > > > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS > > Sailing schools> > http://groups.yahoo.com/gads? t=ms&k=Sailing+schools&w1=Sailing+schools&> > > w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing> +ad> > venture&w6=Sailing&c=6&s=122&.sig=nM_33Bwh2_UhuqSYWZR8Xw> > Sailing> > instruction> > http://groups.yahoo.com/gads? t=ms&k=Sailing+instruction&w1=Sailing+scho> > > ols&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sai> lin> > g+adventure&w6=Sailing&c=6&s=122&.sig=PLKTippWs7H3hJMQiiV1Dg> > Sailing> > lesson> > http://groups.yahoo.com/gads? t=ms&k=Sailing+lesson&w1=Sailing+schools&w> > > 2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+> adv> > enture&w6=Sailing&c=6&s=122&.sig=BW-ssa-AtK1bKwgxZtYhsg> > > Sailing course> > http://groups.yahoo.com/gads? t=ms&k=Sailing+course&w1=Sailing+schools&w> > > 2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+> adv> > enture&w6=Sailing&c=6&s=122&.sig=iJziK8qHrpaIJG_Q19twrg> > Sailing> > adventure> > http://groups.yahoo.com/gads? t=ms&k=Sailing+adventure&w1=Sailing+school> > > s&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Saili> ng+> > adventure&w6=Sailing&c=6&s=122&.sig=luRjwGYgtoRAVO_RIh446A> > Sailing> > http://groups.yahoo.com/gads? t=ms&k=Sailing&w1=Sailing+schools&w2=Saili> > > ng+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adventu> re&> > w6=Sailing&c=6&s=122&.sig=H5HiiLFUXHyIpCEv0TmINg> > > > > _____ > > > > YAHOO! GROUPS LINKS > > > > > > > > * Visit your group "freedomyachts2003> > http://groups.yahoo.com/group/freedomyachts2003 " on the web.> > > > * To unsubscribe from this group, send an email to:> > freedomyachts2003-unsubscribe@yahoogroups.com> > <mailto:freedomyachts2003-unsubscribe@yahoogroups.com?> subject=Unsubscrib> > e> > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of> > Service http://docs.yahoo.com/info/terms/ . > > > > > > _____> > > > IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax > matters was neither written nor intended by the sender or Mayer, > Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer > for the purpose of avoiding tax penalties that may be imposed under > U.S. tax law. If any person uses or refers to any such tax advice in > promoting, marketing or recommending a partnership or other entity, > investment plan or arrangement to any taxpayer, then (i) the advice > was written to support the promotion or marketing (by a person other > than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter, > and (ii) such taxpayer should seek advice based on the taxpayers > particular circumstances from an independent tax advisor> > > > This email and any files transmitted with it are intended solely > for the use of the individual or entity to whom they are addressed. > If you have received this email in error please notify the system > manager. If you are not the named addressee you should not > disseminate, distribute or copy this e-mail.> >> > > > > > > > > SPONSORED LINKS > Sailing schools> http://groups.yahoo.com/gads?t=ms&k=Sailing+schools&w1=Sailing+schools& w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+ad> venture&w6=Sailing&c=6&s=122&.sig=nM_33Bwh2_UhuqSYWZR8Xw> Sailing> instruction> http://groups.yahoo.com/gads?t=ms&k=Sailing+instruction&w1=Sailing+scho ols&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailin> g+adventure&w6=Sailing&c=6&s=122&.sig=PLKTippWs7H3hJMQiiV1Dg> Sailing> lesson> http://groups.yahoo.com/gads?t=ms&k=Sailing+lesson&w1=Sailing+schools&w 2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adv> enture&w6=Sailing&c=6&s=122&.sig=BW-ssa-AtK1bKwgxZtYhsg> > Sailing course> http://groups.yahoo.com/gads?t=ms&k=Sailing+course&w1=Sailing+schools&w 2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adv> enture&w6=Sailing&c=6&s=122&.sig=iJziK8qHrpaIJG_Q19twrg> Sailing> adventure> http://groups.yahoo.com/gads?t=ms&k=Sailing+adventure&w1=Sailing+school s&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+> adventure&w6=Sailing&c=6&s=122&.sig=luRjwGYgtoRAVO_RIh446A> Sailing> http://groups.yahoo.com/gads?t=ms&k=Sailing&w1=Sailing+schools&w2=Saili ng+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adventure&> w6=Sailing&c=6&s=122&.sig=H5HiiLFUXHyIpCEv0TmINg> > > _____ > > YAHOO! GROUPS LINKS > > > > * Visit your group "freedomyachts2003> http://groups.yahoo.com/group/freedomyachts2003 " on the web.> > * To unsubscribe from this group, send an email to:> freedomyachts2003-unsubscribe@yahoogroups.com> <mailto:freedomyachts2003-unsubscribe@yahoogroups.com?subject=Unsubscrib> e> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of> Service http://docs.yahoo.com/info/terms/ . > > > _____ > > > >
