Re: Traveler Track & caulking
Posted by j32080 (j32080@…>)
Don’t use silicone. Silicone doesn’t hold up as to longevity.
Use a polyurethane such as Boatlife’s Life Seal or a polysulfide
(e.g., Boatlife Life Caulk) or equivalent such as Sikaflex depending
upon the materials being caulked. In other words, read the label as
to the proper caulk.
Sikaflex has a complete chart as to caulks and materials. Although
a bit more expensive, and sometimes harder to get, it is what is
used by boat builders. It is great for caulking the chainplates on
traditional wire-rigged boats. Jamestown carries the stuff.
-John
Former owner “Blue Merle” (#259)
J/32 “Liberty”
— In freedom21@yahoogroups.com, mitya fonin <mitbok1@…> wrote:
Going back on the subject, I also ordered bolts/nuts from
Jamestown as well and I did have some water in the strbrd traveler
track post ( adjacent to the hatch ). I poked at its side and…
well I crumbled half of the core in this post out because it was
wet, rotted and basically disintegrated. Filing it with epoxy will
not be a problem. I took the track off and found some silicone
bedding underneath it. There was some discussion and disappointment
how manufacturer attached the track in the first place without using
any sealant. My question is how do I seal the hole setup when
putting it back ? Marine silicone around and inside every bolt hole ?
Dmitry.
“Baltika”
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
I’ll add one more comment. Should you use a polysulfide or
polyurethane caulk make sure that you mask off any areas that you
don’t want to get caulk on BEFORE applying the caulk.
The stuff is as sticky and messy as pink bubble gum on a 95 degree day!
So I’d dry mount the traveler, mask, then caulk and remount the
traveler. Have plenty of paper towels to wipe up any oozing. If you
do wipe with a paper towel, wipe THEN TOSS (the paper towel)! As soon
as you try to use the paper towel sheet for a 2nd wipe, you’ll regret
it as somehow a bit of the caulk on the paper towel will magically
escape and you’ll be leaving caulking residue everywhere!
Posted by Clyde Wisner (clydewis@…>)
Does anybody have an interest (or know of somebody) in buying my “21”?
It"s a shoal draft in fair condition, on a Triad trailer (not
registered) on the Eastern Shore of Md. Has main, spin. and wrap jib.
Could be sailed to any location on the Bay. $3000. Clyde 410 221 0036
