Posted by j32080 (j32080@…>)
Once you get this replaced, put a stopper (figure eight) knot on
each traveler line end. This will prevent two things:
Preventing the traveler car from slamming down on the stops and
ripping them off. -
Most important! Preventing the boom from hitting the mast at the
gooseneck. Note that this also requires a stopper knot at the right
location in the mainsheet. So with the traveler down and the
mainsheet let out, nothing on the boom at the gooseneck should touch
the mast. Leave a little bit of space as rope will stretch. You
may think that you’re OK but then the massive force behind that
accidental/uncontrolled gybe will make the boom touch. It is how
the gooseneck gets ripped out of the mast.
-John
Former owner “Blue Merle” #259
— In freedom21@yahoogroups.com, “Nick Marino” <blueraven1@…>
Doug,
Mauri Pro Sailing, Toll Free 1-817-426-6264, says they will be
recieving a Harken #172 tomorrow or Thursday.
Nick
P.S. You will need to use the blocks on the old car or buy new
ones.— In freedom21@yahoogroups.com, “Nick Marino” <blueraven1@>
wrote:Hi Doug,
I think What you want is a Harken #172 small boat/high load
car.
They are discontinued BUT you can order one at pyacht.com (call
Kevin
at 877-379-2248. He says Harken still have them , 2 week
delivery,
they are blue).http://www.pyacht.net/cgi-local/SoftCart.exe/cgi-bin/pagegen.pl?
U+scstore+tgxy7812ff38d338+pr+HAR172Keep us posted on progress.
Nick
— In freedom21@yahoogroups.com, “Doug Chace” <ch47_av8r@>
wrote:Nick,
I appreciate the info. I need another traveller stop as well,
however… What I’m looking for is the actual traveller block
that
moves back and forth on the track connected to the fiddle
block
for
the main sheet. I took my broken one into a marine supply
shop
they just gave me the “RCA Dog” look.I can now order the stop that broke when my traveller broke,
but
I
must continue to “endure” sailing with a ridiculous home made
contraption holding my main sheet in place. At least I’m
sailing.
Could be worse.Doug
wrote:Doug,
The end peice (stop) at the end of your traveler is Harken
part
number 264 (2 screws) or 174 (1 screw). They are sold in
pairs
separate from the Harken track (part number 374 or 2725).
Remove
good one and go to West Marine (or your local marine store
that
has
Harken parts and you will be able to buy a pair.
Nick— In freedom21@yahoogroups.com, “Doug Chace” <ch47_av8r@>
wrote:I’m sure that it’s out there somewhere, but I’m not
finding
it.
What
is the part number for the Harken Traveller that our 21’s
use?
Mine
broke and the “jimmy-rig” that I’m using isn’t working.Thanks,
Doug
