Ditto on flushing twice for the chageover.
Posted by isleblues (milo.militello@…>)
An FYI regarding switching from Green to Red anti-freeze . . .
According to several sources, the Green anti-freeze must be COMPLETELY
flushed out before switching to Red. I have been told horror stories
regarding the smallest amount of Green left in the cooling system
turning to a gummy hard substance when combine with the red in high
temperatures. I was told that it can ruin your engine. Please
investigate with your own sources when switching anti-freeze.
Milo
Island Blues (F32 Hoyt)
I switched without apparent ill effect by draining the green stuff, then running clean water through several times before putting the orange in.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of islebluesSent: Monday, August 22, 2005 9:53 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Use caution when switching anti-freezeAn FYI regarding switching from Green to Red anti-freeze . . .According to several sources, the Green anti-freeze must be COMPLETELY flushed out before switching to Red. I have been told horror stories regarding the smallest amount of Green left in the cooling system turning to a gummy hard substance when combine with the red in high temperatures. I was told that it can ruin your engine. Please investigate with your own sources when switching anti-freeze.MiloIsland Blues (F32 Hoyt)IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Posted by George E. Herchenroether (g.herk@…>)
I suggest each
boat considering a change in the antifreeze type have a yard remove the cooling
unit and have it cleaned thoroughly. We
did this in 2003 when we changed to the orange antifreeze. Could be just luck, but the Yanmar always runs
just this side of 80 degrees.
E. Herchenroether
4
Bush St
Newport, RI 02840
401.847.2028
401.338.5329
mobile
