Re: Windows
Posted by j32080@…> (j32080@…>)
The wrap-around plexiglass was discontinued by 1984 and 4 Beckson ports were used instead. -John Former owner “Blue Merle” #259Jake Kiehl <jake@…> wrote: I am also interested in hearing people’s advice on sealing the Plexiglass windows. I have tried silicon sealant, and even with using masking tape I am unsatisfied with the results. Only doomed to repeat the same experience in a couple of years when it deteriorates. I’ve been considering sealing
from the inside, hoping the plexiglass will protect from the UVs.I’ve seen some boats (Blue Raven in person) have more traditional port-hole windows. While my boat just has the wrap-around plexiglass Max describes. As far as I know the plexiglass is factory installed. Are the different windows aftermarket? Or just differences in model years?Regards,JakeMax Lent wrote:> Hi All,>> Thank you all again for the great advice that you have provided. The> following is an update on my restoration of Top Cat.>> Mast Rail>> Thanks to the advice provided here, I bought a rivet tool and> discovered as predicted that the nose of the rivet tool would not> fit within the rail guides. Again, following advice provided here, I> bought a file and filed down the sides of the rivet gun nose so that> it would fit.>> What didn’t work was the suggestion
for drilling out the existing> rivets. Instead I used a punch and just pushed the broken rivets> through.>> This was my first time using a pop rivet tool, so my success rate> with the rivets was about 50%. Eventually, I was able to glue the> rail to the mast and replace all of the broken rivets. What a> feeling of success.>> Mast Light>> Work in progress. I bought some three stranded wire from West Marine> and I am still contemplating how to relieve stress on wire that will> be hanging 36 feet from the top of the mast. I’m thinking that I> might make a coil and use plastic ties to attach the coil to the> radio antenna coaxial cable.>> Windows>> A friend of mine who is both a boat owner and a window installer> suggested using butyl tape to seal the wrap around Plexiglas to the> boat. Have you used this method? If not, what did
you use to seal> your windows? I’ve heard many negative reports about using silicon> sealant.>> Thank you again,>> Max>>
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
Hi,
According to my Home Window Contractor and Installer, any good
Plexiglass store can cut and form a replacement for the existing
unit. I was also told that white toothpaste used on a buffer will
make the windows shine like new. As an after treatment, Pledge, is
supposed to make them sparkle.
The place to purchase the butyl tape is an RV repair center. This
tape is used routinely on RVs for the same purpose as we are
considering. I plan to buy some tomorrow and install it within a few
days. I will share my experience here.
Max
-John
sealing the
using
repeat
been
considering sealing from the inside, hoping the plexiglass will
protect
from the UVs.
plexiglass
installed.
years?
Regards,
Jake
Max Lent wrote:
Hi All,
The
Mast Rail
here, I
that
it would fit.
What didn’t work was the suggestion for drilling out the existing
through.
feeling of success.
Mast Light
Marine
will
Windows
boat. Have you used this method? If not, what did you use to seal
sealant.
Thank you again,
Max
