Refrigeration
Hello all, I am considering replaceing my Adler Barbour refrigeration with something more effecient. I am on a mooring in Marathon this winter and find this older unit-that works, is using too much energy. It’s difficult keeping the batteries charged. I have solar panels and a battery charger, but would rather not put the battery charger on if not necessary. My volt meter is very low all the time. I have read about several. Of the air cooled/water cooled, which system do you think are the best. I am in Florida where the air temperatures are warm Have people changed out their systems to something more effecient and less taxing on the batteries? Do you have opinions about brand, cooling types-size. In the manual for my 32, it says the ice box is 7 cu.ft. I’d appreciate some help on this. “Life is a Reach, then you Jibe” SWARD
I added insulation (and reduced the space
a bit) of my icebox to increase its efficiency. I installed a Technautics cool
blue air cooled holding plate unit in place of my old adler barber and it has
worked quite well. I have heard from others that their Frigoboat with the heat
exchanger thru hull is very efficient.
Alan
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Sward
Sent: Wednesday, January 16, 2008
5:31 AM
Subject: [FreedomOwnersGroup]
Refrigeration
Hello all,
I am
I have read
Have people
I’d
Jibe”
SWARD
I don’t understand what a holding plate is Alan Kusinitz <akusinitz@…> wrote: I added insulation (and reduced the space a bit) of my icebox to increase its efficiency. I installed a Technautics cool blue air cooled holding plate unit in place of my old adler barber and it has worked quite well. I have heard from others that their Frigoboat with the heat exchanger thru hull is very
efficient. Alan From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of SwardSent: Wednesday, January 16, 2008 5:31 AMTo:
FreedomOwnersGroup@yahoogroups.comSubject: [FreedomOwnersGroup] Refrigeration Hello all, I am considering replaceing my Adler Barbour refrigeration with something more effecient. I am on a mooring in Marathon this winter and find this
older unit-that works, is using too much energy. It’s difficult keeping the batteries charged. I have solar panels and a battery charger, but would rather not put the battery charger on if not necessary. My volt meter is very low all the time. I have read about several. Of the air cooled/water cooled, which system do you think are the best. I am in Florida where the air temperatures are warm Have people changed out their systems to something more effecient and less taxing on the batteries? Do you have opinions about brand, cooling types-size. In the manual for my 32, it says the ice box is 7 cu.ft. I’d appreciate some help on this. “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD
According to the Frigoboat faq, their boatshow display is to keep ice
cream solid using a keel cooler in 85 deg. water. The system draws a
little over 3 amps.
What they don’t tell you is how long it will draw 3 amps at that
water temperature. No matter what system you use, the warmer the
transfer medium, the longer it will have to run to reduce
temperature. That being said, I installed a keel cooler system on
Bright Star and was very happy with it. Besides there being no way
for the system to fail in a way that might flood the boat, it was
very efficient and quiet. Even in the middle of summer when not only
the water was warm, but the air was too, it would probably run every
20 minutes or so for 3 - 5 minutes, drawing 3-5 amps.
On Glory, we replaced the “Ne’erCold” refrigeration with a Frigoboat
air cooled compressor, and it has also been fantastic, if slightly
louder than the keel cooler model. We have two air-cooled
compressors - the new Frigoboat for the refrigerator and an older ice
box compressor. Both work extremely well and relatively quietly.
*** commercial plug *** it may be worth your time to give Mark
Fruehoff a call at Great Water, Inc. They designed both my systems,
and they used to run Cay Electronics in the bahamas before they moved
to Maine. Mark is excellent to work with and will definitely have
sound recommendations to help you out. www.great-water.com
*** end plug ***
Lance
Glory
Thanks Lance, that was very helpfullance_ryley <lance_ryley@…> wrote: According to the Frigoboat faq, their boatshow display is to keep ice cream solid using a keel cooler in 85 deg. water. The system draws a little over 3 amps.What they don’t tell you is how long it will draw 3 amps at that water temperature. No matter what system you use, the warmer the transfer medium, the longer it will have to run to reduce temperature. That being said, I installed a keel cooler system on Bright Star and was very happy
with it. Besides there being no way for the system to fail in a way that might flood the boat, it was very efficient and quiet. Even in the middle of summer when not only the water was warm, but the air was too, it would probably run every 20 minutes or so for 3 - 5 minutes, drawing 3-5 amps.On Glory, we replaced the “Ne’erCold” refrigeration with a Frigoboat air cooled compressor, and it has also been fantastic, if slightly louder than the keel cooler model. We have two air-cooled compressors - the new Frigoboat for the refrigerator and an older ice box compressor. Both work extremely well and relatively quietly.*** commercial plug *** it may be worth your time to give Mark Fruehoff a call at Great Water, Inc. They designed both my systems, and they used to run Cay Electronics in the bahamas before they moved to Maine. Mark is excellent to work with and will definitely have sound recommendations to help you
out. www.great-water.com*** end plug ***LanceGlory"Life is a Reach, then you Jibe" SWARD
Some refrigeration systems have a large
and somewhat heavy liquid filled stainless steel plate. The liquid in it gets
cooled and then the condenser stops and the icebox is cooled for extended
periods by the holding plate. This can be useful to store up cooling when you
have electricity available from solar panels or other sources. Of course you
could just have larger battery storage. It was most common with engine driven
units.
Alan
8:15 AM
Refrigeration
Alan Kusinitz
Alan
On Behalf Of Sward
5:31 AM
Refrigeration
Hello all,
I am
I
Have
I’d
“Life is a
SWARD
SWARD
One quick fix on the older adler barber units is to get rid of the
high amp fan motor and replace it with a computer “pancake” style fan.
It’s a few screws a couple zip ties and two wires. If the fan motor
on the condensing unit is barrel shaped you might get away with
something. Do that and add the insulation before you whip out the big
bucks and see what happens.
BTW operating your batteries at below 50% charge on a normal basis
will kill them much faster than if you can keep them up there between
50% and 90%
— In FreedomOwnersGroup@yahoogroups.com, “Alan Kusinitz”
Some refrigeration systems have a large and somewhat heavy liquid filled
stainless steel plate. The liquid in it gets cooled and then the
condenser
stops and the icebox is cooled for extended periods by the holding
plate.
This can be useful to store up cooling when you have electricity
available
from solar panels or other sources. Of course you could just have larger
battery storage. It was most common with engine driven units.
Alan
Sent: Wednesday, January 16, 2008 8:15 AM
Subject: RE: [FreedomOwnersGroup] Refrigeration
increase
holding plate
have
hull is
very efficient.
Alan
Hello all,
something
keeping the
meter is
system do
are warm
and less
SWARD
SWARD
There is a very simple, low tech, low budget solution…turn it off. My wife and I spent a winter on the hook in Florida last year without a day of refrigeration or ice. Our F30 had a very nice AB system but it could drain the batteries to half-charge (about 12.05V) in two days (and you should not routinely go lower). I didn’t want to install solar or wind systems, so we just turned off the refrig…and enjoyed life. Eggs, cabbage, onions, garlic, etc hold up very well. Buy small jars of things (like mayonaise and jam) and eat them in a few days. Eat what you cook. But, I do like the idea of changing the fan… and would change to LEDs for the few necessary lights you need to live. Keep it simple, enjoy the air and water. FargoGeorge Huffman <thatboatguy2@…> wrote: One quick fix on the older adler barber units is to get rid of the high amp fan motor and replace it with a computer “pancake” style fan. It’s a few screws a couple zip ties and two wires. If the fan motor on the condensing unit is barrel shaped you might get away with something. Do that and add the insulation before you whip out the big bucks and see what happens. BTW operating your batteries at below 50% charge on a normal basis will kill them much faster than if you can keep them up there between 50% and 90% George — In FreedomOwnersGroup@yahoogroups.com, “Alan Kusinitz” <akusinitz@…> wrote: > > Some refrigeration systems have a large and somewhat heavy liquid filled > stainless steel plate. The liquid in it gets cooled and then the condenser > stops and the icebox is cooled for extended periods by the holding plate. > This can be useful to store up cooling when you have electricity available > from solar panels or other sources. Of course you could just have larger > battery storage. It was most common with engine driven units. > > Alan > > > > _____ > > From: FreedomOwnersGroup@yahoogroups.com > [mailto:FreedomOwnersGroup@yahoogroups.com]
On Behalf Of Sward > Sent: Wednesday, January 16, 2008 8:15 AM > To: FreedomOwnersGroup@yahoogroups.com > Subject: RE: [FreedomOwnersGroup] Refrigeration > > > > I don’t understand what a holding plate is > > > > Alan Kusinitz <akusinitz@…> wrote: > > I added insulation (and reduced the space a bit) of my icebox to increase > its efficiency. I installed a Technautics cool blue air cooled holding plate > unit in place of my old adler barber and it has worked quite well. I have > heard from others that their Frigoboat with the heat exchanger thru hull is > very efficient. > Alan > > > > _____ > > > From: FreedomOwnersGroup@yahoogroups.com > [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Sward > Sent: Wednesday, January 16, 2008 5:31 AM > To: FreedomOwnersGroup@yahoogroups.com > Subject: [FreedomOwnersGroup] Refrigeration > > Hello all, > > I am considering replaceing my Adler Barbour refrigeration with something > more effecient. I am on a mooring in Marathon this winter and find this > older unit-that works, is using too much energy. It’s difficult keeping the > batteries charged. I have solar panels and a battery charger, but would > rather not put the battery charger on if not necessary. My volt meter is > very low all the time. > > I
have read about several. Of the air cooled/water cooled, which system do > you think are the best. I am in Florida where the air temperatures are warm > > > Have people changed out their systems to something more effecient and less > taxing on the batteries? Do you have opinions about brand, cooling > types-size. In the manual for my 32, it says the ice box is 7 cu.ft. > > I’d appreciate some help on this. > > “Life is a Reach, then you Jibe” > > SWARD > > > > > > “Life is a Reach, then you Jibe” > > > > SWARD >
Posted by Bob (rweeks6508@…>)
Whats really nice if you have access to SAMs or Costco you can get almost any
condiment in the packet size sleeves rather then jars. Of course you will have
enough for a century or two.
Bob
Date: 2008/01/16 Wed AM 08:49:02 CST
Subject: Re: [FreedomOwnersGroup] Re: Refrigeration
jam) and eat them in a few days. Eat what you cook.ÂÂ
few necessary lights you need to live.ÂÂ
Keep it simple, enjoy the air and water.ÂÂ
Fargo
50% and 90%
condenser
plate.
available
Alan
increase
holding plate
have
hull is
very efficient.
Alan
Hello all,
something
keeping the
meter is
system do
are warm
and less
SWARD
SWARD
I found a trick that works well on my trip up from Ft Myers. Several small
blocks of dry ice placed at the bottom of the icebox with a bag of ice (close
the drain value and dont keep you head in the icebox long). This will last at
least (min) two full days more like three full before the dry ice disappears but
the bag of ice is still going.
Bob
Fargo
50% and 90%
condenser
plate.
available
Alan
increase
holding plate
have
hull is
very efficient.
Alan
Hello all,
something
keeping the
meter is
system do
are warm
and less
SWARD
SWARD
  1. Does anyone have experience with portable freezers and portable refrigerators?2. Another thought… I have an RV and find my built in refrig stays pretty cold for a few days after leaving shore power. 3. Also another idea is to turn the refrigerator off a day?, while the battery can recharge?If anyone cares to comment, it would be appreciated.Lola F30Bob <rweeks6508@…> wrote: Whats really nice if you have access to SAMs or Costco you can get almost any condiment in the packet size sleeves
    rather then jars. Of course you will have enough for a century or two. Bob ===================== From: Fargo Rousseau <fargo_r@yahoo.com> Date: 2008/01/16 Wed AM 08:49:02 CST To: FreedomOwnersGroup@yahoogroups.com Subject: Re: [FreedomOwnersGroup] Re: Refrigeration There is a very simple, low tech, low budget solution…turn it off. My wife and I spent a winter on the hook in Florida last year without a day of refrigeration or ice. Our F30 had a very nice AB system but it could drain the batteries to half-charge (about 12.05V) in two days (and you should not routinely go lower). I didn’t want to install solar or wind systems, so we just turned off the refrig…and enjoyed life. Eggs, cabbage, onions, garlic, etc hold up very well. Buy small jars of things (like
    mayonaise and jam) and eat them in a few days. Eat what you cook. But, I do like the idea of changing the fan… and would change to LEDs for the few necessary lights you need to live. Keep it simple, enjoy the air and water. Fargo George Huffman <thatboatguy2@yahoo.com> wrote: One quick fix on the older adler barber units is to get rid of the high amp fan motor and replace it with a computer “pancake” style fan. It’s a few screws a couple zip ties and two wires. If the fan motor on the condensing unit is barrel shaped you might get away with something. Do that and add the insulation before you whip out the big bucks and see what happens. BTW operating your batteries at below 50% charge on a normal basis will kill them much faster than if you can keep them up there between 50%
    and 90% George — In FreedomOwnersGroup@yahoogroups.com, “Alan Kusinitz” <akusinitz@…> wrote: > > Some refrigeration systems have a large and somewhat heavy liquid filled > stainless steel plate. The liquid in it gets cooled and then the condenser > stops and the icebox is cooled for extended periods by the holding plate. > This can be useful to store up cooling when you have electricity available > from solar panels or other sources. Of course you could just have larger > battery storage. It was most common with engine driven units. > > Alan > > > > _____ > > From: FreedomOwnersGroup@yahoogroups.com > [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Sward > Sent: Wednesday, January 16, 2008 8:15 AM > To: FreedomOwnersGroup@yahoogroups.com > Subject: RE: [FreedomOwnersGroup] Refrigeration > > > > I don’t understand what a holding plate is > > > > Alan Kusinitz <akusinitz@…> wrote: > > I added insulation (and reduced the space a bit) of my icebox to increase > its efficiency. I installed a Technautics cool blue air cooled holding plate > unit in place of my old adler barber and it has worked quite well. I have > heard from others that their Frigoboat with the heat exchanger thru hull is > very efficient. > Alan > > > > _____ > > > From: FreedomOwnersGroup@yahoogroups.com > [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Sward > Sent: Wednesday, January 16, 2008 5:31 AM > To: FreedomOwnersGroup@yahoogroups.com > Subject: [FreedomOwnersGroup] Refrigeration > > Hello all, > > I am considering replaceing my Adler Barbour refrigeration with something > more effecient. I am on a mooring in Marathon this winter and find this > older unit-that works, is using too much energy. It’s difficult keeping the > batteries charged. I have solar panels and a battery charger, but would > rather not put the battery charger on if not necessary. My volt
    meter is > very low all the time. > > I have read about several. Of the air cooled/water cooled, which system do > you think are the best. I am in Florida where the air temperatures are warm > > > Have people changed out their systems to something more effecient and less > taxing on the batteries? Do you have opinions about brand, cooling > types-size. In the manual for my 32, it says the ice box is 7 cu.ft. > > I’d appreciate some help on this. > > “Life is a Reach, then you Jibe” > > SWARD > > > > > > “Life is a Reach, then you Jibe” > > > > SWARD >
    Never miss a thing. Make Yahoo your homepage.
Posted by katorpus (jrb@…>)
The dry ice works well, but be careful what goes in the box.
I did this several years ago, and was chagrined to discover that the
CO2 had insinuated itself through the “pores” in the plastic bottles
containing the milk and the orange juice, turning both
into “carbonated beverages”.
The orange juice wasn’t all that bad…think “non-alcoholic
Mimosas”…but the milk was awful.
The bag of red grapes didn’t fare well either. They swelled up. It
was really pretty strange biting into a “fizzy grape”…but they then
deflated and turned to a pulp pretty quickly (as if they’d been
frozen).
Several small blocks of dry ice placed at the bottom of the icebox
with a bag of ice (close the drain value and dont keep you head in
the icebox long). This will last at least (min) two full days more
like three full before the dry ice disappears but the bag of ice is
still going.
Bob
LEDs for the few necessary lights you need to live.ÂÂ
Fargo
fan.
motor
big
between
50% and 90%
liquid filled
condenser
holding
plate.
available
have larger
Alan
increase
holding plate
well. I
have
thru
hull is
very efficient.
Alan
Hello all,
something
find this
keeping the
but would
meter is
system do
temperatures
are warm
and less
cooling
cu.ft.
SWARD
SWARD
Goodpoint! But I did not notice the extra carbonation in the beer! {;>) All
kidding aside we did not notice the milk (only for coffee or cereal) or fruit
being much different but what you say sounds logical. We did not close the drain
value some what later in the trip maybe that helped. Is CO2 heavier or lighter
then air?
Bob
Date: 2008/01/16 Wed AM 09:24:45 CST
Subject: [FreedomOwnersGroup] Re: Refrigeration
frozen).
still going.
Bob
etc
cook.ÂÂÂÂ
LEDs for the few necessary lights you need to live.ÂÂÂÂ
Keep it simple, enjoy the air and water.ÂÂÂÂ
Fargo
fan.
motor
big
between
50% and 90%
liquid filled
condenser
holding
plate.
available
have larger
Alan
increase
holding plate
well. I
have
thru
hull is
very efficient.
Alan
Hello all,
something
find this
keeping the
but would
meter is
system do
temperatures
are warm
and less
cooling
cu.ft.
SWARD
SWARD
C02 is one and a half times as “heavy” as “air”. Dry ice is CO2 in
solid form. The “smoke” which comes off of dry ice is C02 in gaseous
form.
The gas “sinks”…in your case, right out the hole in the bottom of
the icebox, through the valve and into the bilge.
The reason that your “stuff” didn’t carbonate is that the gaseous C02
never attained the concentration inside the box which would have
allowed it to displace the air inside the box (much less inside the
milk jug or fruit)…it simply sank out through the hole without
dispersing…
If the valve had been closed, the increased pressure inside the box
(caused by the melting dry ice) would have increased to the point of
raising the lid on the icebox off of its seal enough to allow the
equalization of the pressure inside the box with that of the air in
the boat…if you were ABLE to seal it up absolutely, either the dry
ice would never melt or the box would explode! Since it would
require “perfect insulation” to accomplish the former, then the
latter would be the most likely result.
If there was still dry ice remaining after you closed the valve
and “carbonation” did not occur, then you probably have bad seals on
your icebox.
In my case, the weight of the box lid was sufficient to provide
enough additional pressure within the box that the “path of least
resistance” was through the skins of the grapes and through the walls
of the jugs containing the milk and juice (or, more likely, around
the seals of the caps on the jugs). Once the box lid was opened, the
pressure inside & outside the box equalized, but the higher pressure
remained within the not-originally-carbonated food items…until the
pressure and carbonation in them moved out, and they became “flat”
again.
It’s really no different than shaking up a warm bottle of soda and
opening it…only in reverse.
{;>) All kidding aside we did not notice the milk (only for coffee
or cereal) or fruit being much different but what you say sounds
logical. We did not close the drain value some what later in the trip
maybe that helped. Is CO2 heavier or lighter then air?
Bob
bottles
then
frozen).
still going.
Bob
Florida last
had a very
(about
lower). I
onions, garlic, etc
mayonaise and
cook.ÂÂÂÂ
to
Fargo
style
fan.
motor
big
basis
between
50% and 90%
liquid filled
condenser
holding
plate.
electricity
available
have larger
Alan
to
increase
holding plate
well. I
have
thru
hull is
very efficient.
Alan
Hello all,
something
find this
difficult
keeping the
but would
volt
meter is
which
system do
temperatures
are warm
effecient
and less
cooling
cu.ft.
SWARD
SWARD
