Removing masts/transporting a freedom 39
Posted by davidwysen (davidwysen@…>)
Hello:
Just purchased a 1984 39 pilothouse in Cortez, Florida. Bristol
condition in and out, and masts look good. GHave to move it to Seattle.
I can either truck it or put it on the floating transport ship. More
money to float it, but would not have to remove masts.
Any opinions/experiences out there??
David Wysen
Posted by Ketch 22 (ketch_22@…>)
I would avoid removing masts if feasible. Lots of details need to be addresses
when you remove the masts. All the masthead wiring has to be cut and
re-assembled. The mast collar may (or may not) be watertight when you
re-install. If they leak, you need to replace with a new collar or Spar-tite.
I removed main and mizzen in 98, it took me 3 months to get everything back to
normal - after the yard was finished re-installing. Removal and re-installation
has yard costs at both ends, in addition to delivery costs.
Good luck,
tm
-----Original Message-----
Sent: Apr 21, 2005 4:35 AM
Subject: [freedomyachts2003] Removing masts/transporting a freedom 39
Hello:
David Wysen
Yahoo! Groups Links
I know fellow Freedom owners who take out their masts after every
season when the boat goes in storage. My own experience is that is
takes you a full day plus a crane to get your two masts out of the
hull. And another day to get them in again.
Regards,
mike
— In freedomyachts2003@yahoogroups.com, “davidwysen”
<davidwysen@y…> wrote:
Hello:
Seattle.
David Wysen
I’m one of those owners who has to unstep his mast (only one in my case) in
order to transport the boat to winter storage. The process can be fairly
painless. I also like the advantage of being able to inspect everything
while not dangling from a chair.
Find a facility that has a crane dedicated to waterfront use or get a group
together to share costs. In my case the waterfront crane charge is $125
each way (step and unstep), this is in Padanaram Harbor, South Dartmouth, MA
a place known for high prices but not in this case because it is a simple,
fast process.
Build supports on deck for the mast(s). Mine are made of 2X8s and are
braced both fore & aft and port & starboard to withstand over the road
delivery to my yard.
Before arrival at the yard I remove the bolted down collar and the silicone
caulk around the mast and place the mast supports to receive the mast.
The yard crew goes up the mast in a bosun’s chair and removes antenna and
wind instruments. I unbolt the angle bracket at the bottom of the mast and
disconnect wires while they rig the lift strap.
The actual lift takes only a few minutes and the mast is laid into the
waiting supports. Time at the yard’s dock is about 1/2 hour. I lead the
halyards (tied off to the gooseneck) to the winches and tighten them for
further resistance to fore & aft movement during shipment.
Stepping the mast in the spring is just the reverse of the above.
Bill
Sailing F-36 (1986) Hard Earned out of
New Bedford Yacht Club, Padanaram Village, South Dartmouth, MA
William A. Cormack, CPA
Principal and Chief Financial Officer
Whelan Associates, LLC, a Corporate Real Estate Service Firm
100 Faunce Corner Executive Center, Suite 150
500 Faunce Corner Road
North Dartmouth, MA 02747
Voice: 508-984-4100, Fax: 508-984-4101, Cell 508-254-5828
MailTo:wacormack@…
Sent: 04/22/2005 3:45 AM
Subject: [freedomyachts2003] Re: Removing masts/transporting a freedom 39
Regards,
mike
Hello:
Seattle.
David Wysen
Yahoo! Groups Links
