Removing numbers
Hello Everyone,
I moved my boat from one state to another and need to remove the
numbers and stickers. One of my friends recommended a hairdryer to
loosen the glue on the old numbers. That didn’t work out. Anybody have
a suggestion for removing the old numbers?
Allen McClung
Posted by Patrick Weaver (patrick@…>)
We
use Goo-Gone to remove sticker grime from a lot of surfaces. Of course, we’re
usually working on horizontal surfaces.
Patrick
-----Original Message-----
[mailto:freedom21@yahoogroups.com] On Behalf
Of Allen McClung
Sent: Monday, March 31, 2008 10:12
PM
To: freedom21@yahoogroups.com
Subject: [freedom21] Removing
numbers
Hello Everyone,
Allen McClung
Posted by d m (remodelernc@…>)
Goo Gone works well, it’s a citrus based adhesive and latex remover and should not affect your finish. You can also try denatured alcohol.
----- Original Message ----From: Patrick Weaver <patrick@…>To: freedom21@yahoogroups.comSent: Monday, March 31, 2008 10:25:00 PMSubject: RE: [freedom21] Removing numbers
We use Goo-Gone to remove sticker grime from a lot of surfaces. Of course, we¢re usually working on horizontal surfaces.
Patrick
-----Original Message-----From: freedom21@yahoogrou ps.com [mailto:freedom21@ yahoogroups. com] On Behalf Of Allen McClungSent: Monday, March 31, 2008 10:12 PMTo: freedom21@yahoogrou ps.comSubject: [freedom21] Removing numbers
Hello Everyone,I moved my boat from one state to another and need to remove the numbers and stickers. One of my friends recommended a hairdryer to loosen the glue on the old numbers. That didn’t work out. Anybody have a suggestion for removing the old numbers?Allen McClung
You rock. That’s why Blockbuster’s offering you one month of Blockbuster Total Access, No Cost.
Posted by linsey (linseyjohnson6@…>)
Ever try peanut butter?
Sent: Monday, March 31, 2008 10:58 PM
Subject: Re: [freedom21] Removing numbers
----- Original Message ----From: Patrick Weaver <patrick@aplusnyc.com>To: freedom21@yahoogroups.comSent: Monday, March 31, 2008 10:25:00 PMSubject: RE: [freedom21] Removing numbers
Patrick
Posted by Paul Monette (plmonette@…>)
On thing that I have used is OOPs which is a latex paint remover. It has not had an ill effect on the gelcoat.
We use Goo-Gone to remove sticker grime from a lot of surfaces. Of course, we’re usually working on horizontal surfaces.
Patrick
