Posted by jamesbrianorr (james.orr@…>)
Folks,
First posting, but was hoping someone had some ideas re: a repair I am
contemplating on
my shaft strut before it goes back in the water. I’ve got a Mull designed
Freedom 32
(1988) (acquired just under 2 years ago for sailing out of Rochester on Lake
Ontario) with
the Yanmar 2GM. It is currently on the hard, and the shaft is in the process of
being
replaced (along with some other drive train related assemblies). In addition, I
also had the
engine folks remove the lobster pot cutter (not many of those on the Great
Lakes, besides
which it was going to need some repair work as well), but am now left with 3
holes which
went straight through the casting.
I am going to need to do something to fill them in before I fit a new strut
bearing (or
replace the strut – which I really don’t want to do, nor do I think is
necessary). My current
thought would be to clean the holes up and braze in some replacement bronze rod,
then fair as appropriate. One of the unknowns is the original material they used
for the
casting. I am guessing it might be silicon or manganese bronze, but don’t know
for sure,
and for that matter, would it make much of a difference re: the rod type I use
as well as
the brazing flux and filler material.
Does anyone have any detailed information on the struts that Tillotson might
have been
using in the 1988 timeframe?
