Barry:
I don’t know if those exact bases are available in retail stores now or not. You
might be able to find some at marine consignment stores like Sailorman in Ft.
Lauderdale, Don’s Salvage in Clearwater, Bacon’s in Annapolis of Minnie’s in
California.
Worst Marine, Defender Industries and others have similar ones made of stainless
instead of chrome/bronze. The 2008 Worst Marine catalog shows the bases selling
for $69.99 EACH and two-hole stanchions (for double lifelines) at $59.99 each.
If I had gotten six of those, they would have cost me a total of $780, not
including the mounting hardware.
But why would you want them? I’ve always hated and distrusted them.
Do you really want your life of those of your crew to be dependent on those two
little set screws that are supposed to hold the stanchion in place? Just buying
one to match the others on your boat is, IMHO, not a good enough reason.
I replaced all of my wobbly and possibly cracked ones like yours with one-piece
welded stainless steel stanchions from Garhauer. They were $30 each a few years
ago. Probably a bit more now. I got six of 'em, plus they are mounted using
1/4"x3" stainless carriage bolts, which cost $1 each. I needed 24. So the whole
s etup cost me $204, not including the lifelines, which I had made by JSI. Just
two of the WM stanchions and bases cost more than that.
Lifelines are supposed to be a last resort, to catch a person who might
otherwise fall overboard. At least now I have a bit more peace of mind that if
mine ever really need to perform that function, the stanchions won’t pop out of
their bases at the worst possible moment. It’s worth spending the $206 to
replace all six stanchions and be secure than to spend $70 replace one and then
relying on two little screws to save your life
Something worth considering.
My next project is installing jacklines on deck to be even more secure.
Steve Gaber
Sanderling, 1967 C-31 #77
Oldsmar, FL
---- Barry Stellrecht <yak@…> wrote:
Our 1981 F33 has one stanchion base with a crack (appears to be corrosion),
and I’m wondering if a replacement is available, or if I just need to find
somebody to weld it up again…
This a a 4-bolt pattern base with a 1" socket in the top and two “bails”
facing forward and aft. It is angled about 10 degrees away from vertical.
(I’ll attach a small photo, but don’t know if the yahoo group will accept it or
not) I believe later boats had an aluminum toe rail with stanchions attached to
the rail, but mine are mounted slightly inboard of the teak toe rail.
Does anybody know who made these stanchion bases, or if anybody has some still
available?
Barry
s/v Flutterby, Freedom 33 cat ketch (becoming a junk rig)
