ReRacor fuel filters
Posted by lolaltd (lolaltd@…>)
— In FreedomOwnersGroup@yahoogroups.com, “lolaltd” <lolaltd@…> wrote:
Hello ,
Also on the Racor fuel filters, I currently use what was on the boat
Napa 3472 will a Racor convert? If so what number cross references
to that Napa?
Thank you…Any F30 folks know also?
Lola F30 1987
Posted by Robert (robert@…>)
Lola
Filters can be cross-referenced on the wix filters website www.wixfilters.com this is where napa source some of their filter, this website will also cross-refer racor filter elements. Yanmar use a variant of the Racor 200 series filter as a primary filter offering. The Racor 200 series offers the correct flow rates for smaller diesels as used in freedoms but also has disadvantages. The larger Racor 500FG or the 500MA (marine version with a metal heat shield) is a 3 stage filter.
Stage One: Separation - As fuel enters the filter assembly, it moves through the centrifuge and spins off large solids and water droplets which fall to the bottom of the collection bowl.
Stage Two: Coalescing - Small water droplets bead-up on the surface of the conical baffle and cartridge element. When heavy enough, they too fall to the bottom of the bowl.
Stage Three: Filtration - Proprietary Aquabloc®II cartridge elements repel water and remove contaminants from fuel down to 2 micron (nominal). They are waterproof andeffective longer then water absorbing elements.
Now the 500 series filters are bigger than our engines need and the fuel flow may not be sufficient to make full use of the advantages of the filter, but they ‘Top Loading’ which means that the possibility of spilling diesel in the bilge is much reduced and replacing a filter at sea is far easier, particularly if you have picked up a batch of bad fuel, which happens more often than you would believe, and have to change a filter several times before reaching a destination.
Note: I have no commercial interest in Racal-Parker but do recommend their products, the description of the processing stages is copied verbatim from Racor literature.
Robert
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of lolaltdSent: Tuesday, November 25, 2008 9:55 AMTo: FreedomOwnersGroup@yahoogroups.comSubject: [FreedomOwnersGroup] ReRacor fuel filters
— In FreedomOwnersGroup@yahoogroups.com, “lolaltd” <lolaltd@…> wrote:>>Hello ,Also on the Racor fuel filters, I currently use what was on the boat Napa 3472 will a Racor convert? If so what number cross referencesto that Napa?Thank you…Any F30 folks know also?Lola F30 1987
Posted by Al Lorman (ajl@…>)
Lola:
The
standard filter on the 1987 F30 was a Fram. You cannot use a Racor filter
in the Fram housing. You’ll need to buy an entirely new unit –
filter and housing. I installed a series 200 Racor; they run between $80
and $120 dollars; replacement cartridges run about $20-30.
Al
Behalf Of lolaltd
Hello ,
to that Napa?
Lola F30 1987
I suggest www.marinefilters.com for price-checking. Herm
At 10:58 AM 11/25/2008, you wrote:
Lola:
The standard filter on the 1987 F30 was a
Fram. You cannot use a Racor filter in the Fram
unit – filter and housing. I installed a series
200 Racor; they run between $80 and $120
Al
— In
Hello ,
to that Napa?
Lola F30 1987
Right.
The filters are particular within each brand. And even different models of the
same brand.
I replaced the entire filter unit with a Racor 500FG.
It cost around $180, but the filters are only about $8 each. And it is much
easier to change than all the other filter systems I’ve used on mine and other
boats.
Steve Gaber
Sanderling, 1967 C-31 #77
Oldsmar, FL
---- Al Lorman <ajl@…> wrote:
Lola:
The standard filter on the 1987 F30 was a Fram. You cannot use a Racor
filter in the Fram housing. You’ll need to buy an entirely new unit -
Al
mailto:FreedomOwnersGroup%40yahoogroups.com , “lolaltd” <lolaltd@…>
Hello ,
to that Napa?
Lola F30 1987
NAPA sells filter elements for Racor, Fram and many other filter system brands.
You have to tell them the filter model.
Steve Gaber
Oldsmar, FL
Hello ,
to that Napa?
Lola F30 1987
They also make a “T” handle replacement that incorporates a vacuum gauge. Expensive but effective and easily installed. A good filtering system should incorporate a vacuum gauge and an easy method of priming (in my opinion). George— On Sun, 11/30/08, sgaber@… <sgaber@…> wrote:From: sgaber@… <sgaber@…>Subject: RE: [FreedomOwnersGroup] ReRacor fuel filtersTo: FreedomOwnersGroup@yahoogroups.comCc: “Al Lorman” <ajl@…>Date: Sunday, November 30, 2008, 12:07 AM
Right.
The filters are particular within each brand. And even different models of the same brand.
It cost around $180, but the filters are only about $8 each. And it is much easier to change than all the other filter systems I’ve used on mine and other boats.
Steve Gaber
Oldsmar, FL
---- Al Lorman <ajl@lormanlawdc. com> wrote:
Lola:
Al
[mailto:FreedomOwnersGroup@ yahoogroups. com] On Behalf Of lolaltd
To: FreedomOwnersGroup@ yahoogroups. com
Subject: [FreedomOwnersGroup ] ReRacor fuel filters
— In FreedomOwnersGroup@ yahoogroups. com
<mailto:FreedomOwne rsGroup%40yahoog roups.com> , “lolaltd” <lolaltd@… >
Hello ,
to that Napa?
Lola F30 1987
Right.
Steve Gaber
Oldsmar, FL
Lola:
Al
Hello ,
to that Napa?
Lola F30 1987
I
could not fit a Racor 500, no less a 500 with the T handle vacuum gauge, in the
engine compartment of an F30. There isn’t enough vertical clearance.
Al
Lorman
Behalf Of george huffman
Sent: Sunday, November 30, 2008 11:19 AM
<sgaber@…>
Right.
the same brand.
other boats.
Steve Gaber
Oldsmar, FL
com> wrote:
Lola:
Al
lolaltd
yahoogroups. com
Hello ,
to that Napa?
Lola F30 1987
Posted by Bob (rweeks6508@…>)
I have the RACOR unit 500MA and it has worked to perfection. Knock on wood but I have not had a dirty fuel issue yet using this filter and a fuel funnel filter. And yes there has been water in the fuel but the filter has separated and I just drain it off. I would like to get another but that is a lot of lunch money to save, so I can switch off when needed without an interruption in fuel delivery. However as suggested below I am investing in a vaccum guage which screws into the T handle hole and as someone else suggested maybe the fuel bulb (as on outboard engine gas lines) would work nicely for a primer pump.BobOn Sun, Nov 30, 2008 at 11:19 AM, george huffman wrote:They also make a “T” handle replacement that incorporates a vacuum gauge. Expensive but effective and easily installed. A good filtering system should incorporate a vacuum gauge and an easy method of priming (in my opinion). George — On Sun, 11/30/08, sgaber@tampabay. rr.com <sgaber@tampabay. rr.com> wrote: From: sgaber@tampabay. rr.com <sgaber@tampabay. rr.com> Subject: RE: [FreedomOwnersGroup ] ReRacor fuel filters To: FreedomOwnersGroup@ yahoogroups. com Cc: “Al Lorman” <ajl@lormanlawdc. com> Date: Sunday, November 30, 2008, 12:07 AM Right. The filters are particular within each brand. And even different models of the same brand. I replaced the entire filter unit with a Racor 500FG. It cost around $180, but the filters are only about $8 each. And it is much easier to change than all the other filter systems I’ve used on mine and other boats. Steve Gaber Sanderling, 1967 C-31 #77 Oldsmar, FL ---- Al Lorman < ajl@lormanlawdc. com> wrote: > Lola: > > > > The standard filter on the 1987 F30 was a Fram. You cannot use a Racor > filter in the Fram housing. You’ll need to buy an entirely new unit - > filter and housing. I installed a series 200 Racor; they run between $80 > and $120 dollars; replacement cartridges run about $20-30. > > > > Al > > > > > > > > From: FreedomOwnersGroup@ yahoogroups. com> [mailto: FreedomOwnersGroup@ yahoogroups. com] On Behalf Of lolaltd > Sent: Tuesday, November 25, 2008 9:55 AM > To: FreedomOwnersGroup@ yahoogroups. com> Subject: [FreedomOwnersGroup ] ReRacor fuel filters > > > > — In FreedomOwnersGroup@ yahoogroups. com> <mailto:FreedomOwne rsGroup%40yahoog roups.com> , “lolaltd” <lolaltd@… > > wrote: > > > >Hello , > > Also on the Racor fuel filters, I currently use what was on the boat > Napa 3472 will a Racor convert? If so what number cross references > to that Napa? > > Thank you…Any F30 folks know also? > > Lola F30 1987 > > > –
On my F30 the filter is mounted under the sink high up so out of the way enough room to change filter and still have storage space under the sink.BobOn Sun, Nov 30, 2008 at 12:07 PM, Al Lorman wrote:I could not fit a Racor 500, no less a 500 with the T handle vacuum gauge, in the engine compartment of an F30. There isn’t enough vertical clearance. Al Lorman From: FreedomOwnersGroup@ yahoogroups. com [mailto:FreedomOwne rsGroup@yahoogro ups.com] On Behalf Of george huffman Sent: Sunday, November 30, 2008 11:19 AM To: FreedomOwnersGroup@ yahoogroups. com Subject: RE: [FreedomOwnersGroup ] ReRacor fuel filters They also make a “T” handle replacement that incorporates a vacuum gauge. Expensive but effective and easily installed. A good filtering system should incorporate a vacuum gauge and an easy method of priming (in my opinion). George — On Sun, 11/30/08, sgaber@tampabay. rr.com <sgaber@tampabay. rr.com> wrote: From: sgaber@tampabay. rr.com <sgaber@tampabay. rr.com> Subject: RE: [FreedomOwnersGroup ] ReRacor fuel filters To: FreedomOwnersGroup@ yahoogroups. com Cc: “Al Lorman” <ajl@lormanlawdc. com> Date: Sunday, November 30, 2008, 12:07 AM Right. The filters are particular within each brand. And even different models of the same brand. I replaced the entire filter unit with a Racor 500FG. It cost around $180, but the filters are only about $8 each. And it is much easier to change than all the other filter systems I’ve used on mine and other boats. Steve Gaber Sanderling, 1967 C-31 #77 Oldsmar, FL ---- Al Lorman < ajl@lormanlawdc. com> wrote: > Lola: > > > > The standard filter on the 1987 F30 was a Fram. You cannot use a Racor > filter in the Fram housing. You’ll need to buy an entirely new unit - > filter and housing. I installed a series 200 Racor; they run between $80 > and $120 dollars; replacement cartridges run about $20-30. > > > > Al > > > > > > > > From: FreedomOwnersGroup@ yahoogroups. com> [mailto: FreedomOwnersGroup@ yahoogroups. com] On Behalf Of lolaltd > Sent: Tuesday, November 25, 2008 9:55 AM > To: FreedomOwnersGroup@ yahoogroups. com> Subject: [FreedomOwnersGroup ] ReRacor fuel filters > > > > — In FreedomOwnersGroup@ yahoogroups. com> <mailto:FreedomOwne rsGroup%40yahoog roups.com> , “lolaltd” <lolaltd@… > > wrote: > > > >Hello , > > Also on the Racor fuel filters, I currently use what was on the boat > Napa 3472 will a Racor convert? If so what number cross references > to that Napa? > > Thank you…Any F30 folks know also? > > Lola F30 1987 > > > –
The original Racor 12 S was a lot smaller. There wasn’t enough vertical
clearance to mount the Racor 500 on mine either, so I moved it to another
location where it fit better. I’m much happier with the new setup.
Steve Gaber
Oldsmar, FL
Al Lorman
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of george huffman
opinion).
Right.
the same brand.
other boats.
Steve Gaber
Oldsmar, FL
---- Al Lorman <ajl@lormanlawdc. mailto:ajl%40lormanlawdc.com com> wrote:
Lola:
Al
mailto:FreedomOwnersGroup%40yahoogroups.com ] On Behalf Of lolaltd
To: FreedomOwnersGroup@ mailto:FreedomOwnersGroup%40yahoogroups.com
yahoogroups. com
Hello ,
to that Napa?
Lola F30 1987
There is also the Racor 200 FG that you can sometimes find, it’s discontinued but it is a turbine style coalescing filter and the replacement elements are still available.
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of sgaber@…Sent: Monday, December 01, 2008 10:13 PMTo: FreedomOwnersGroup@yahoogroups.comCc: Al LormanSubject: RE: [FreedomOwnersGroup] ReRacor fuel filters
The original Racor 12 S was a lot smaller. There wasn’t enough vertical clearance to mount the Racor 500 on mine either, so I moved it to another location where it fit better. I’m much happier with the new setup.–Steve GaberSanderling, 1967 C-31 #77Oldsmar, FL---- Al Lorman <ajl@lormanlawdc.com> wrote: > I could not fit a Racor 500, no less a 500 with the T handle vacuum gauge,> in the engine compartment of an F30. There isn’t enough vertical clearance.> > > > Al Lorman> > > > From: FreedomOwnersGroup@yahoogroups.com> [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of george huffman> Sent: Sunday, November 30, 2008 11:19 AM> To: FreedomOwnersGroup@yahoogroups.com> Subject: RE: [FreedomOwnersGroup] ReRacor fuel filters> > > > > They also make a “T” handle replacement that incorporates a vacuum gauge.> Expensive but effective and easily installed. A good filtering system> should incorporate a vacuum gauge and an easy method of priming (in my> opinion). > > George> > — On Sun, 11/30/08, sgaber@tampabay.rr.com <sgaber@tampabay.rr.com> wrote:> > From: sgaber@tampabay.rr.com <sgaber@tampabay.rr.com>> Subject: RE: [FreedomOwnersGroup] ReRacor fuel filters> To: FreedomOwnersGroup@yahoogroups.com> Cc: “Al Lorman” <ajl@lormanlawdc.com>> Date: Sunday, November 30, 2008, 12:07 AM> > Right.> > The filters are particular within each brand. And even different models of> the same brand.> > I replaced the entire filter unit with a Racor 500FG.> > It cost around $180, but the filters are only about $8 each. And it is much> easier to change than all the other filter systems I’ve used on mine and> other boats. > > Steve Gaber> Sanderling, 1967 C-31 #77> Oldsmar, FL> > ---- Al Lorman <ajl@lormanlawdc. mailto:ajl%40lormanlawdc.com com> wrote:> > > Lola:> > > > > > > > The standard filter on the 1987 F30 was a Fram. You cannot use a Racor> > filter in the Fram housing. You’ll need to buy an entirely new unit → > filter and housing. I installed a series 200 Racor; they run between $80> > and $120 dollars; replacement cartridges run about $20-30.> > > > > > > > Al> > > > > > > > > > > > > > > > From: FreedomOwnersGroup@ yahoogroups. com> mailto:FreedomOwnersGroup%40yahoogroups.com > > [mailto:FreedomOwnersGroup@ yahoogroups. com> mailto:FreedomOwnersGroup%40yahoogroups.com ] On Behalf Of lolaltd> > Sent: Tuesday, November 25, 2008 9:55 AM> > To: FreedomOwnersGroup@ mailto:FreedomOwnersGroup%40yahoogroups.com> yahoogroups. com> > Subject: [FreedomOwnersGroup ] ReRacor fuel filters> > > > > > > > — In FreedomOwnersGroup@ yahoogroups. com> mailto:FreedomOwnersGroup%40yahoogroups.com > > <mailto:FreedomOwne rsGroup%40yahoog roups.com> , “lolaltd” <lolaltd@… >> > wrote:> > >> > >Hello ,> > > > Also on the Racor fuel filters, I currently use what was on the boat > > Napa 3472 will a Racor convert? If so what number cross references> > to that Napa?> > > > Thank you…Any F30 folks know also?> > > > Lola F30 1987> > > > > > > > → > > > >
Only
the replacement elements are available; other parts are not. I wouldn’t
buy one of these today, even if you found one in decent shape.
Al
Lorman
Behalf Of Robert
Sent: Tuesday, December 02, 2008 8:43 AM
Cc: Al Lorman
the new setup.
Steve Gaber
Oldsmar, FL
clearance.
Al Lorman
vacuum gauge.
opinion).
<sgaber@…>
<sgaber@…>
Right.
the same brand.
much
other boats.
Steve Gaber
Oldsmar, FL
com> wrote:
Lola:
Racor
$80
Al
yahoogroups. com
Hello ,
to that Napa?
Lola F30 1987
