Posted by Patrick Weaver (patrick@…>)
The instructions on how this is done are at Max’s “other” site:
http://www.freedom21.info/modifications.htm
In that same section is a detailed description of the aluminum mast.
After taking a long hard look at http://www.freedom21…info/f21tabernacle.pdf I believe that it could work IF one were a good machinist and could fabricate and assemble as proposed. Remember to allow some extra play for wiring! Has anyone out there actually done this and has photos?
Sean P. Mulligan - Emmylou
-----Original Message-----From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of Patrick WeaverSent: Saturday, January 13, 2007 2:56 PMTo: freedom21@yahoogroups.comSubject: [freedom21] Retrofitting a Mast Tabernacle Hinge to a Freedom 21 Mast & Aluminum Mast Specs
The instructions on how this is done are at Max’s “other” site: http://www.freedom21.info/modifications.htmIn that same section is a detailed description of the aluminum mast.
Don’t pick lemons.
See all the new 2007 cars at Yahoo! Autos.
