Posted by Skipper Skip (skipperf33@…>)
Alan, thanks for the Heads-Up! I’ll see what turns up back there:) I too have the High Roach sails and just never felt the need to add sail off the wind. This thing COOKS as it is:) I had thought that it would probably be of help in very light air. I guess I’ll just have to break the thing out and give her a try!
Skip
1982 F33 CK, Fixed Shoal Keel
Southern CA.
— On Sat, 10/18/08, Alan Kusinitz <akusinitz@…> wrote:
From: Alan Kusinitz <akusinitz@…>Subject: RE: [FreedomOwnersGroup] Rigging QuestionTo: FreedomOwnersGroup@yahoogroups.comDate: Saturday, October 18, 2008, 4:28 AM
If you search the archives (may be on the old yahoo group) for mizzen staysail you should find some detailed posting from Michel Capel . He loved using the larger mizzen staysails and said it made a huge difference off the wind and in light air.
Of course to tack or jibe you have to lower it.
You run the sheet through a block at the end of the mizzen boom.
Michel had the original wishbone rig.
I don¢t use mizzen staysails but have a converted rig and much larger roach sails then the original so I¢m not sure if the difference would be as much.
Alan F-33 Hull #33 1982
From: FreedomOwnersGroup@ yahoogroups. com [mailto:FreedomOwne rsGroup@yahoogro ups.com] On Behalf Of James FitchSent: Saturday, October 18, 2008 1:12 AMTo: FreedomOwnersGroup@ yahoogroups. comSubject: Re: [FreedomOwnersGroup ] Rigging Question
Here’s something worth a thousand words— Capn jimy
2008/10/17 Skipper Skip <skipperf33@yahoo. com>
Thanks for the input folks!
OK, I have the sail, the sheet, the running back stay, and the padeyes:) Now all I have to do is give it a try!
Has anyone used this sail? What are the points of sail they are designed for? Have you found it to be worth the effort to fly it? If it is effective at all, It looks like it would be a good one to fly in light air, if you are not going to be doing a lot of tacking! Am I right on this?
Thanks agian:)
Skip
Southern CA.
— On Fri, 10/17/08, Alan Kusinitz <akusinitz@yahoo. com> wrote:
From: Alan Kusinitz <akusinitz@yahoo. com>Subject: RE: [FreedomOwnersGroup ] Rigging QuestionTo: FreedomOwnersGroup@ yahoogroups. comDate: Friday, October 17, 2008, 2:19 PM
They are for the mizzen staysails regardless of whether it’s the original rig or not. And there should be padeyes further aft on the coaming for the running backstays when fliying a mizzen staysail .
Alan F-33 Hull #51 1982
From: FreedomOwnersGroup@ yahoogroups. com [mailto:FreedomOwne rsGroup@yahoogro ups.com] On Behalf Of Skip Turpin
Sent: Friday, October 17, 2008 4:15 PMTo: FreedomOwnersGroup@ yahoogroups. comSubject: [FreedomOwnersGroup ] Rigging Question
My 1982 F33 CK has been modified from its original wishbone configuration to standard sails, tracks and booms.My question is this; I have two winches mounted on the teak combing at each side of the cockpit. It seems to me that I have seen wishbone rigs with and without these winches, so what were they for originally?Could it be that they have nothing to do with the wishbones at all, but rather the Sail that flies from the mizzen masthead forward. Which I have yet to fly! (I am embarrassed to admit, the name of that sail escapes me at the moment! GOD, growing old is HELL!) Drifter?.. … That just doesn’t sound right?! Well anyway, I am sure you get the gist of my question!Thanks All :)Skip1982 F33 CK, Fixed Shoal KeelSouthern CA.
____________ _________ _________ _________ _________ __Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail. yahoo.com
__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
