Posted by DAVE RODGERS (dav.rodgers@…>)
Has anyone been able to replace their stock Rope Clutch Handle after breaking one? I’ve been trying to source one out to no avail. Freedom Yachts (now known as Legacy Yachts) is working on finding out the manufacturer of the part, I am just curious if others here have gone the same route and already found an exact or suitable replacement.
Thank you in advance for any assistance you might be able to provide.
Dave Rodgers (Hull # 42)
Attachment: (image/pjpeg) Rope Clutch.jpg [not stored]
Posted by Joe Conron (joeconron@…>)
Rope clutches uses on F21 are EasyLock -1
– still available.
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of DAVE RODGERS
Sent: Thursday, August 28, 2008
11:53 AM
To: freedom21@yahoogroups.com
Subject: [freedom21] Rope Clutch
Handle
replacement.
able to provide.
Dave Rodgers (Hull
42)
They are now called Easy Lock… and can be bought at
http://www.rigrite.com/Hardware/Rope_Clutches/Easylock_Handles.html
They are better tahn the originals, as they seem to be fiberglas
reinforced, but no longer in green and red… just black.
A word of caution: try not to lose the little circlips that hold the
handles in place! They charge $4. for a unit no bigger than your pinky
nail! I told them they should be complementary! Good Luck
Posted by Art Quade (akquade@…>)
Hi Dave,
I currently have 2 broken levers on the clutches. Since
all I do for a living is fabricate and machine plastics, I plan on making a few
over the winter once I get my boat home and can take the specs off a WHOLE
one. I’m looking into which plastic will be best suited to handle
the task (tensile strength, heat resistance, UV stability etc.) If you
have time on your side I would be more than happy to make some.
Anyone else may take advantage of the offer if they wish. The
more I can make (hopefully on a CNC machine) the lower the nominal cost would
be.
Regards,
Art
Simple Thoughts
RODGERS
Sent: Thursday, August 28, 2008 11:53 AM
Subject: [freedom21] Rope Clutch Handle
replacement.
to provide.
Attachment: (image/jpeg) image001.jpg [not stored]
Attachment: (image/jpeg) image002.jpg [not stored]
Thanks so much to both of you! Their ordered and in the mail. Much appreciated.— On Thu, 8/28/08, Bob Broder <RABroder@…> wrote:
From: Bob Broder <RABroder@…>Subject: [freedom21] Re: Rope Clutch HandleTo: freedom21@yahoogroups.comReceived: Thursday, August 28, 2008, 4:29 PMThey are now called Easy Lock… and can be bought at http://www.rigrite.com/Hardware/Rope_Clutches/Easylock_Handles.html They are better tahn the originals, as they seem to be fiberglas reinforced, but no longer in green and red… just black.
A word of caution: try not to lose the little circlips that hold the handles in place! They charge $4. for a unit no bigger than your pinky nail! I told them they should be complementary! Good Luck
Yahoo! Groups Links
<> To visit your group on the web, go to:
http://groups.yahoo.com/group/freedom21/
<> Your email settings:
Individual Email | Traditional
<> To change settings online go to:
http://groups.yahoo.com/group/freedom21/join
(Yahoo! ID required)
<> To change settings via email:
mailto:freedom21-digest@yahoogroups.com mailto:freedom21-fullfeatured@yahoogroups.com
<> To unsubscribe from this group, send an email to:
freedom21-unsubscribe@yahoogroups.com
<> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
I agree rigrite.com I ordered the handles and in two days they were here. I would order at leat a couple of the little hold clips. They are small and easy to loose. — On Thu, 8/28/08, Bob Broder <RABroder@…> wrote:
From: Bob Broder <RABroder@…>Subject: [freedom21] Re: Rope Clutch HandleTo: freedom21@yahoogroups.comDate: Thursday, August 28, 2008, 11:29 AM
They are now called Easy Lock… and can be bought at http://www.rigrite. com/Hardware/ Rope_Clutches/ Easylock_ Handles.html They are better tahn the originals, as they seem to be fiberglas reinforced, but no longer in green and red… just black.A word of caution: try not to lose the little circlips that hold the handles in place! They charge $4. for a unit no bigger than your pinky nail! I told them they should be complementary! Good Luck— In freedom21@yahoogrou ps.com, DAVE RODGERS <dav.rodgers@ …> wrote:>> Has anyone been able to replace their stock Rope Clutch Handle after breaking one? I’ve been trying to source one out to no avail. Freedom Yachts (now known as Legacy Yachts) is working
on finding out the manufacturer of the part, I am just curious if others here have gone the same route and already found an exact or suitable replacement.> > Thank you in advance for any assistance you might be able to provide.> > Dave Rodgers (Hull # 42) >
