rope clutch''s
Posted by billpeggyweber (billpeggyweber@…>)
Has anyone replaced the rope cluth’s on the f21. If so any
suggestion’s or experience… If so what did you replace with???
Posted by Joe Conron (joeconron@…>)
EasyLock 1 should be an exact match. Here
is one possible source:
http://www.pyacht.com/online-store/scstore/h-easylock_1.htm
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of billpeggyweber
Sent: Monday, May 12, 2008 9:40 AM
To: freedom21@yahoogroups.com
Subject: [freedom21] rope clutch’s
any
When locked is the handle up in the air??? Like the original??Joe Conron <joeconron@…> wrote: EasyLock 1 should be an exact match. Here is one possible source: http://www.pyacht.com/online-store/scstore/h-easylock_1.htm From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of billpeggyweberSent: Monday, May 12, 2008 9:40 AMTo: freedom21@yahoogroups.comSubject: [freedom21] rope clutch’s Has anyone replaced the rope cluth’s on the f21. If so any
I’m reasonably sure that the original
locked with handle in down position. I have the same clutches on my
Quickstep 24 as I had on my F21.
I cannot imagine anyone ever designing a
rope clutch where locked position would be up – where it could snag a
lazy mainsheet on tack or gybe.
One of the nice feature of these clutches
is that you can haul in on the line while the clutch is engaged – allows you
to tighten the halyard without having to open clutch first.
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of bill weber
Sent: Monday, May 12, 2008 9:52 AM
Subject: RE: [freedom21] rope
clutch’s
When
Joe
Conron <joeconron@verizon.net>
size=2 width=“100%” align=center tabIndex=-1>
it now.
You can find Black Easylock 1 Handles and retaining clips at
http://www.rigrite.com/Hardware/Rope_Clutches/Easylock_Handles.html
If you want to replace an entire cluth (single or multiples)see
Nick
— In freedom21@yahoogroups.com, “billpeggyweber” <billpeggyweber@…>
Posted by David Garrison (sierrasmith71@…>)
The line clutches on my Freedom 21 (hull 234) lock in the up position. I
think this can be changed by moving the mounting pin from the “A” to the
“B” hole on the handle.
David Garrison
Reply-To: freedom21@yahoogroups.com
To: <freedom21@yahoogroups.com>
Subject: RE: [freedom21] rope clutch’s
Date: Mon, 12 May 2008 10:28:38 -0400
I’m reasonably sure that the original locked with handle in down position.
I have the same clutches on my Quickstep 24 as I had on my F21.
I cannot imagine anyone ever designing a rope clutch where locked position
would be up - where it could snag a lazy mainsheet on tack or gybe.
One of the nice feature of these clutches is that you can haul in on the
line while the clutch is engaged - allows you to tighten the halyard
without
Behalf
Of bill weber
http://www.pyacht.
Behalf
Of billpeggyweber
<http://us.rd.yahoo.com/evt=51733/*http:/mobile.yahoo.com/;_ylt=Ahu06i62sR8H
DtDypao8Wcj9tAcJ%20> it now.
I thought I was nut’s. I was rigging the lazy jacks and had the boom lifted using the main halyard held by the clutch. Something hit the clutch handle and it released the boom on top of my wrist and hand. Luckily I just got a bad bruise and cut’s. I’m changing the position tommorow. Thanks… David Garrison <sierrasmith71@…> wrote: The line clutches on my Freedom 21 (hull 234) lock in the up position. I think this can be changed by moving the mounting pin from the “A” to
the “B” hole on the handle.David Garrison>From: “Joe Conron” <joeconron@verizon.net>>Reply-To: freedom21@yahoogroups.com>To: <freedom21@yahoogroups.com>>Subject: RE: [freedom21] rope clutch’s>Date: Mon, 12 May 2008 10:28:38 -0400>>I’m reasonably sure that the original locked with handle in down position.>I have the same clutches on my Quickstep 24 as I had on my F21.>>>>I cannot imagine anyone ever designing a rope clutch where locked position>would be up - where it could snag a lazy mainsheet on tack or gybe.>>>>One of the nice feature of these clutches is that you can haul in on the>line while the clutch is engaged - allows you to tighten the halyard
without>having to open clutch first.>>>> _____>>From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On >Behalf>Of bill weber>Sent: Monday, May 12, 2008 9:52 AM>To: freedom21@yahoogroups.com>Subject: RE: [freedom21] rope clutch’s>>>>When locked is the handle up in the air??? Like the original??>>Joe Conron <joeconron@verizon.net> wrote:>>EasyLock 1 should be an exact match. Here is one possible source:>>http://www.pyacht.>http://www.pyacht.com/online-store/scstore/h-easylock_1.htm>com/online-store/scstore/h-easylock_1.htm>>>> _____>>size=2 width=“100%” align=center tabIndex=-1>>>From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On >Behalf>Of billpeggyweber>Sent: Monday, May 12, 2008 9:40 AM>To: freedom21@yahoogroups.com>Subject: [freedom21] rope clutch’s>>Has anyone replaced the rope cluth’s on the f21. If so any>suggestion’s or experience… If so what did you replace with???>>>>>> _____>>Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try><http://us.rd.yahoo.com/evt=51733/*http:/mobile.yahoo.com/;_ylt=Ahu06i62sR8H>DtDypao8Wcj9tAcJ%20> it now.>>>
I started to play with the cluthces. A fellow sailor suggested I spray the clutch’s with silicon, all of a sudden the clutch would lock/close in the down position. Try that on your clutch’s. I did not mess with the handle…Thanks to all for the input David Garrison <sierrasmith71@…> wrote: The line clutches on my Freedom 21 (hull 234) lock in the up position. I think this can be changed by moving the mounting pin from the “A” to the “B” hole on the
handle.David Garrison>From: “Joe Conron” <joeconron@verizon.net>>Reply-To: freedom21@yahoogroups.com>To: <freedom21@yahoogroups.com>>Subject: RE: [freedom21] rope clutch’s>Date: Mon, 12 May 2008 10:28:38 -0400>>I’m reasonably sure that the original locked with handle in down position.>I have the same clutches on my Quickstep 24 as I had on my F21.>>>>I cannot imagine anyone ever designing a rope clutch where locked position>would be up - where it could snag a lazy mainsheet on tack or gybe.>>>>One of the nice feature of these clutches is that you can haul in on the>line while the clutch is engaged - allows you to tighten the halyard >without>having to open
How did you keep the silicone (spray?) from getting on ropes? Did you remove them first? I have gotten used to my handles always being about 30 degrees up when “locked” - what would G. Hoyt say?
307 Sean— On Tue, 5/13/08, bill weber <billpeggyweber@…> wrote:
From: bill weber <billpeggyweber@…>Subject: RE: [freedom21] rope clutch’sTo: freedom21@yahoogroups.comDate: Tuesday, May 13, 2008, 5:41 PM
I started to play with the cluthces. A fellow sailor suggested I spray the clutch’s with silicon, all of a sudden the clutch would lock/close in the down position. Try that on your clutch’s. I did not mess with the handle… .Thanks to all for the input David Garrison <sierrasmith71@ hotmail.com> wrote:
The line clutches on my Freedom 21 (hull 234) lock in the up position. I think this can be changed by moving the mounting pin from the “A” to the “B” hole on the handle.David Garrison>From: “Joe Conron” <joeconron@verizon. net>>Reply-To: freedom21@yahoogrou ps.com>To: <freedom21@yahoogrou ps.com>>Subject: RE: [freedom21] rope clutch’s>Date: Mon, 12 May 2008 10:28:38 -0400>>I’m reasonably sure that the original locked with handle in down position.>I have the same clutches on my Quickstep 24 as I had on my F21.>>>>I cannot imagine anyone ever designing a rope clutch where locked position>would be up - where it
could snag a lazy mainsheet on tack or gybe.>>>>One of the nice feature of these clutches is that you can haul in on the>line while the clutch is engaged - allows you to tighten the halyard >without>having to open clutch first.>>>> ___>>From: freedom21@yahoogrou ps.com [mailto:freedom21@yahoogrou ps.com] On >Behalf>Of bill weber>Sent: Monday, May 12, 2008 9:52 AM>To: freedom21@yahoogrou ps.com>Subject: RE: [freedom21] rope clutch’s>>>>When locked is the handle up in the air??? Like the original??>>Joe Conron <joeconron@verizon. net> wrote:>>EasyLock 1 should be an exact match. Here is one possible source:>>http://www.pyacht.><http://www.pyacht. com/online- store/scstore/ h-easylock 1.htm>>com/online- store/scstore/ h-easylock 1.htm>>>> _____>>size=2 width=“100%” align=center tabIndex=-1>>>From: freedom21@yahoogrou ps.com [mailto:freedom21@yahoogrou ps.com] On >Behalf>Of billpeggyweber>Sent: Monday, May 12, 2008 9:40 AM>To: freedom21@yahoogrou ps.com>Subject: [freedom21] rope clutch’s>>Has anyone replaced the rope cluth’s on the f21. If so any>suggestion’ s or experience… If so what did you replace with???>>>>>> _____>>Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try><http://us.rd. yahoo.com/ evt=51733/ *http:/mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8H>DtDypao8Wcj9tAcJ% 20> it now.>>>
