Posted by antoongoedecke (antoong@…>)
I have a Freedom 36/38 from 1988 (TSP36089H788) The portholes in the
main cabin (3) and 2 in the V berth are leaking. Where can I purchase
the rubber gaskets?
Antoon Goedecke
the rubber gaskets?
Antoon Goedecke
If they are the fuller brush ports (5/8
inch solid plexiglass and white frames like on my 33 you can order parts or
full portlights at www.fuller.com in the
marine section.
Alan
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of antoongoedecke
Sent: Wednesday, August 23, 2006
1:05 PM
Subject: [freedomyachts2003]
Rubber gaskets port holes
portholes in the
the rubber gaskets?
Antoon Goedecke
Assuming that you are talking about the opening ports, my boat (1986 F36) has two kinds:
Forward ports in head, salon and forward cabin are plastic with screw-in closers. West marine sells gasket material (weather stripping with sticky back) that you can bend around the edges of the ports.
The two midships ports are aluminum with lever closers. Gaskets for these are no longer made. If you find some please post the source. Someone on this group suggested that I treat the gaskets with Amoral to condition the rubber. This helped a little. This year I treated the gaskets with a generous application of Teflon grease and have not had leaks since then.
Bill
Sailing F36 “Hard Earned” out of New Bedford Yacht Club, Padanaram, MA
Sent: 08/23/2006 1:05 PM
Subject: [freedomyachts2003] Rubber gaskets port holes
I have a Freedom 36/38 from 1988 (TSP36089H788) The portholes in the main cabin (3) and 2 in the V berth are leaking. Where can I purchase the rubber gaskets?ThanksAntoon Goedecke
Thanks for the feed back. No the port holes are made of aluminium.
— In freedomyachts2003@yahoogroups.com, “Alan Kusinitz”
<akusinitz@…> wrote:
If they are the fuller brush ports (5/8 inch solid plexiglass and
white
frames like on my 33 you can order parts or full portlights at
www.fuller.com http://www.fuller.com/ in the marine section.Alan
The information contained in this e-mail and any attachments is
intended
named above
the reader
responsible for
delivering it to the intended recipient, you are hereby notified
that you
dissemination,
If you have
by
antoongoedecke
Sent: Wednesday, August 23, 2006 1:05 PM
Subject: [freedomyachts2003] Rubber gaskets port holesI have a Freedom 36/38 from 1988 (TSP36089H788) The portholes in
purchase
the rubber gaskets?
Antoon Goedecke
I have all aluminium with the lever closers. I will try the Teflon
grease.
Thanks.
Royal Albatross, Dana Point, CA
1… Forward ports in head, salon and forward cabin are plastic
the ports.
2… The two midships ports are aluminum with lever closers.
Bill
Padanaram, MA
purchase
the rubber gaskets?
Antoon Goedecke
Posted by mdurki (vaughan@…>)
I suspect that they are Beckson, which is what was used on the F30s of
about that time. I bought new gaskets from West Marine.
— In freedomyachts2003@yahoogroups.com, “antoongoedecke”
purchase
the rubber gaskets?
Antoon Goedecke
For gasket materials, I’d look at the gaskets (numerous shapes and
sizes) available through J.C. Whitney. Herm
— In
“Alan Kusinitz”
<akusinitz@…> wrote:If they are the fuller brush ports (5/8 inch solid plexiglass and
white
www.fuller.com <<http://www.fuller.com/>http://www.fuller.com/>
intended
named above
the reader
responsible for
that you
dissemination,
If you have
by
antoongoedecke
To:
purchase
the rubber gaskets?
Antoon Goedecke
Posted by seychellois_lib (seychellois_lib@…>)
Bill,
I think your plastic ports are Beckson. If so go to Pampenette.com to
get the real gasget if you care to. They carry new screens and glass
too. But, more importantly, they have a new fangled cam lock for the
ports that replaces the old screw down closers. The cam locks are a
huge improvement and make open/close a snap compared to the screws.
The cams cost about $8.oo per port when I bot them coupla years ago. I
highly recommend them.
I goop my port gasgets with a thin film of vasolene every time I wash
down. Never a leak and the gaskets are nice and soft and rubbery after
several years.
Mike
F36) has two kinds:
ports.
Bill
Subject: [freedomyachts2003] Rubber gaskets port holesI have a Freedom 36/38 from 1988 (TSP36089H788) The portholes in the
the rubber gaskets?
Antoon Goedecke
HI, I ordered my Beckson rubber gaskets and lenses through West Marine. BOW was almost 1/2 the price. West matched the BOW price. Nice to be able to see clearly through and stop the dripping . Ports had been overtightened by PO. Seals ( gaskets )are only a few $ each. Andre, " Scaramanga "seychellois_lib <seychellois_lib@…> wrote: Bill,I think your plastic ports are Beckson. If so go to Pampenette.com
toget the real gasget if you care to. They carry new screens and glasstoo. But, more importantly, they have a new fangled cam lock for theports that replaces the old screw down closers. The cam locks are ahuge improvement and make open/close a snap compared to the screws.The cams cost about $8.oo per port when I bot them coupla years ago. Ihighly recommend them.I goop my port gasgets with a thin film of vasolene every time I washdown. Never a leak and the gaskets are nice and soft and rubbery afterseveral years.Mike— In freedomyachts2003@yahoogroups.com, “William A. Cormack”<wacormack@…> wrote:>> Assuming that you are talking about the opening ports, my boat (1986F36) has two kinds:> 1… Forward ports in head, salon and forward cabin are plasticwith screw-in closers. West marine sells gasket material
(weatherstripping with sticky back) that you can bend around the edges of theports. > 2… The two midships ports are aluminum with lever closers. Gaskets for these are no longer made. If you find some please postthe source. Someone on this group suggested that I treat the gasketswith Amoral to condition the rubber. This helped a little. This yearI treated the gaskets with a generous application of Teflon grease andhave not had leaks since then. > Bill> Sailing F36 “Hard Earned” out of New Bedford Yacht Club, Padanaram, MA> _________________________________________________> > ----- Original Message ----- > From: antoongoedecke > To: freedomyachts2003@yahoogroups.com > Sent: 08/23/2006 1:05 PM> Subject: [freedomyachts2003] Rubber gaskets port holes> > > I have a
Freedom 36/38 from 1988 (TSP36089H788) The portholes in the > main cabin (3) and 2 in the V berth are leaking. Where can I purchase > the rubber gaskets?> Thanks> Antoon Goedecke>
The best gets better. See why everyone is raving about the All-new Yahoo! Mail.
Posted by Jim Demerest (jdemer@…>)
My F36/38 is the same vintage. My guess is that the port lights are Bomar. At that time Bomar ports had gaskets that couldn’t be replaced. I ended up replacing the portlights. The newer portlights have gaskets that can be replaced. Not a very user friendly solution. Try calling Bomar.
Jim Demerest
F36/38 Lady of Remes
