I want to replace the rudder cable-have this panic feeling that soon it will go. Can anyone help with tips on how to do it? Measuring etc/ I asked about a jeniker (spelling?) the other day=no responses. No one has tried one?“Life is a Reach, then you Jibe” SWARD
Posted by Borelmfg (borelmfg@…>)
Sward,
I took them off, went to a rigging shop and said " Make two like these" I kept the old ones a back up. The project is quite simple from a mechnical point of view. Access is the real problem.
regards,
van
Sent: Friday, May 09, 2008 8:22 AM
Subject: [FreedomOwnersGroup] Rudder Cable
SWARD
Van, Are there 2? I’m not referring to the shift and throttle cables-which I already replaced - yes it wasn’t easy. I’m referring to the cable with the chain-looks like a bicycle chain with cable attached, I think, that goes around the rudder postBorelmfg <borelmfg@…> wrote: Sward, I took them off, went to a rigging shop and said " Make two like these"
I kept the old ones a back up. The project is quite simple from a mechnical point of view. Access is the real problem. regards, van ----- Original Message ----- From: Sward To: FreedomOwnersGroup@yahoogroups.com Sent: Friday, May 09, 2008 8:22 AM Subject: [FreedomOwnersGroup] Rudder Cable I want to replace the rudder cable-have this panic feeling that soon it will go. Can anyone help with tips on how to do it? Measuring etc/ I asked about a jeniker (spelling?) the other day=no responses. No one has tried one? “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD
Correct there are two. You have to remove the compass to access the chain to disconnect the cables from the chain.
I would budget one day and several curse words for the entire project. Also the cables cross inside the steering pedestal. I didn’t do this on the first go, only to find out that the rudder action was oppsite the way the steering wheel turned. Had to remove it all and start over (more curse words). I don’t know if this is standard on all Freedoms. So study what you have before taking it all apart.
Best of luck
van
Sent: Friday, May 09, 2008 9:04 AM
Subject: Re: [FreedomOwnersGroup] Rudder Cable
Van,
Are there 2? I’m not referring to the shift and throttle cables-which I already replaced - yes it wasn’t easy. I’m referring to the cable with the chain-looks like a bicycle chain with cable attached, I think, that goes around the rudder postBorelmfg <borelmfg@earthlink.net> wrote:
Sward,
regards,
van
SWARD
SWARD
Posted by Weeks MD, Andrew (aweeks@…>)
If you’re into the pedestal,
you might consider R&R of the throttle and clutch cables. They are a royal
pain to replace and if they break during a sail, it makes for an exciting time.
Andy
-----Original Message-----
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Borelmfg
Sent: Friday, May 09, 2008 12:15
PM
To:
Rudder Cable
Best of luck
van
Sent: Friday, May
09, 2008 9:04 AM
Subject: Re:
Van,
Sward,
the real problem.
regards,
van
Sent: Friday, May
09, 2008 8:22 AM
Subject:
I
I
tried one?
“Life
SWARD
“Life
SWARD
Thanks Andy, yes, they did break when I was anchoring-thankfully, and I replaced them-that was fun!!! Ron, This next project sounds worse than I had imagined. Definately a two person job. I’ll have to get help"Weeks MD, Andrew" <aweeks@…> wrote: If you’re into the pedestal, you might consider R&R of the throttle and clutch cables. They
are a royal pain to replace and if they break during a sail, it makes for an exciting time. Andy -----Original Message-----From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of BorelmfgSent: Friday, May 09, 2008 12:15 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] Rudder Cable Correct there are two. You have to remove the compass to access the chain to disconnect the cables from the chain. I would budget one day and several curse words for the entire project. Also the cables cross inside the steering pedestal. I didn’t do this on the first go, only to find out that the rudder action was oppsite the way the steering wheel
turned. Had to remove it all and start over (more curse words). I don’t know if this is standard on all Freedoms. So study what you have before taking it all apart. Best of luck van ----- Original Message ----- From: Sward To: FreedomOwnersGroup@yahoogroups.com Sent: Friday, May 09, 2008 9:04
AM Subject: Re: [FreedomOwnersGroup] Rudder Cable Van, Are there 2? I’m not referring to the shift and throttle cables-which I already replaced - yes it wasn’t easy. I’m referring to the cable with the
chain-looks like a bicycle chain with cable attached, I think, that goes around the rudder postBorelmfg <borelmfg@earthlink.net> wrote: Sward, I took them off, went to a rigging shop and said " Make two like these" I kept the old ones a back up. The project is quite simple from a mechnical point of view. Access is the real problem. regards, van ----- Original Message ----- From: Sward To: FreedomOwnersGroup@yahoogroups.com Sent: Friday, May 09, 2008 8:22 AM Subject: [FreedomOwnersGroup] Rudder Cable I want to replace the rudder cable-have this panic feeling that soon it will go. Can anyone help with tips on how to do it? Measuring etc/ I asked about a jeniker (spelling?) the other day=no responses. No one has tried one? “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD
Posted by Scott Forgey (jsforgey@…>)
I too had my cable break…and luckily while at dock.
I got it done, fished it through. Took it sailing only to
find out the controls were reversed.
My son could steer perfectly, but I was useless.
So…cross those cables, and grease them well while you are
at it.
Scott
Girlfriend
F-32
Scott Forgey
21362 Summertrace Circle
Boca Raton, FL 33428
561.445.5179
skype: sforgey1
“Nothing is ever wrong in the universe, there is only
what’s missing!”
W. Erhard
Behalf Of Sward
Sent: Friday, May 09, 2008 12:34 PM
Subject: RE: [FreedomOwnersGroup] Rudder Cable
the throttle and clutch cables. They are a royal pain to replace and if they
Andy
-----Original
Message-----
Correct
I
Also the
it all apart.
Best
of luck
van
9:04 AM
Subject: Re:
Van,
Sward,
I
regards,
van
8:22 AM
Rudder Cable
I want to
I asked
one?
Jibe”
SWARD
Jibe”
SWARD
Jibe”
SWARD
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.23.11/1422 - Release Date: 5/8/2008 5:24
PM
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.23.11/1422 - Release Date: 5/8/2008 5:24 PM
Gennaker, a corruption of “spinnaker”. Herm
it will go. Can anyone help with tips on how to do it? Measuring etc/I asked about a jeniker (spelling?) the other day=no responses. No
SWARD
Gennaker is a composite word. Made up (like the rest of language
isn’t?!)
Genoa + Spinnaker = Gennaker.
Spinoa sounds too much like an Italian dish best served with a
light wine sauce and a chianti.
A Gennaker has the parachute ballooniness of a spinnaker and the
tied down ends of a Genoa.
Good read: When a loose cannon flogs a dead cat….
Scott Forgey
561.445.5179
skype: sforgey1
what’s missing!”
W. Erhard
Behalf Of Herman and Gail Schiller
Sent: Saturday, May 10, 2008 12:34 PM
“spinnaker”. Herm
SWARD
Checked by AVG.
PM
Checked by AVG.
