Running Radar Cable
I’m getting ready to install a new Raymarine radome on my carbon fiber
mast. I’m replacing the existing Furuno radome. It appears the radar
cable is bundled with all other mast wiring, so I’m going to fish the
new radar cable seperate from this bundle. At the bottom of the mizzen
mast is a hole approximately 1.5" in diameter, where all mast wiring
exits. There is not enough room for the new cable. Considering there
is no mast compression on an unstayed mast, can I cut another hole for
this new radar cable? It would make fishing the new cable easier, but
I do not want to weaken the mast base by drilling this new hole. Your
comments would be appreciated.
Jay Glen F-40 “Fantasy” San Francisco Bay
Jay,
If there is a radar cable now, then there should be room for the new
cable as well, isn’t it? If you ducttape the head of the new cable
to the head of the old one, can’t you pull the new cabel in? I would
be hesitant to drill a large hole in the mast base. There are no
compression loads on the mast, but there is a bending moment.
good luck,
michel
— In freedomyachts2003@yahoogroups.com, “Jay Glen” <svfantasy@…>
fiber
radar
mizzen
wiring
there
for
but
Your
Posted by svfantasy@… (svfantasy@…)
Michel,
Thank you for your response. Because the existing radar cable is bundled (tied) to the other mast wiring I cannot remove it without without pulling the mast and seperating the bundle of wires. Therefore, I was going to run the new radar cable seperate from the bundle. Although I will be leaving the original cable in place, I can push each end into the existing holes to get the ends out of the way. I may be able to fish the new cable through the existing holes, but because the existing cable bundle is so tight fitting I thought it would be easier to just use a new hole right above the mast step.
----- Original Message -----From: “michel.capel” To: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Running Radar CableDate: Wed, 15 Mar 2006 18:46:48 -0000Jay,If there is a radar cable now, then there should be room for the new cable as well, isn’t it? If you ducttape the head of the new cable to the head of the old one, can’t you pull the new cabel in? I would be hesitant to drill a large hole in the mast base. There are no compression loads on the mast, but there is a bending moment.good luck,michel — In freedomyachts2003@yahoogroups.com, “Jay Glen” <svfantasy@…> wrote:>> I’m getting ready to install a new Raymarine radome on my carbon fiber > mast. I’m replacing the existing Furuno radome. It appears the radar > cable is bundled with all other mast wiring, so I’m going to fish the > new radar cable seperate from this bundle. At the bottom of the mizzen > mast is a hole approximately 1.5" in diameter, where all mast wiring > exits. There is not enough room for the new cable. Considering there > is no mast compression on an unstayed mast, can I cut another hole for > this new radar cable? It would make fishing the new cable easier, but > I do not want to weaken the mast base by drilling this new hole. Your > comments would be appreciated.> > Jay Glen F-40 “Fantasy” San Francisco Bay>
YAHOO! GROUPS LINKS
Visit your group “freedomyachts2003” on the web.
To unsubscribe from this group, send an email to: freedomyachts2003-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Jay,
On my F33 I had no holes in the masts at all; the wiring just went
down through a hole in the mast base and up again through another
hole (outside the mast) in the mast base. Perhaps that’s an idea you
can work with for the new radar cable.
— In freedomyachts2003@yahoogroups.com, svfantasy@… wrote:
Michel,
bundled
was
Although I
into the
fish the
cable
use a new
Jay,
new
cable
would
good luck,
michel
— In freedomyachts2003@yahoogroups.com, “Jay Glen” <svfantasy@>
carbon
fiber
radar
fish
mizzen
wiring
there
hole
for
easier,
but
hole.
Your
SPONSORED LINKS
Sailing schools Sailing instruction Sailing lesson
Sailing course Sailing adventure Sailing
YAHOO! GROUPS LINKS
*  Visit your group "freedomyachts2003" on the web.
*  To unsubscribe from this group, send an email to:
*  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
  Service.
