Take two sail slides and firmly attach at each end of a 12" piece of
1/4" plywood x 1" wide. Wrap the plywood with soft cotton cloth til
slightly fatter than the depth of the slides. Soak the cloth with
liquid “Sail Kote”. Attach halyard and down haul and run the unit up
and down the track. You will need to remove the sail from the mast
track. Use it 2-3 times a season. works well.
