I think this is what you are looking for Scott. This is a copy of an email a friend sent to me recentlyHere is the software I was talking about. Turns your PC, with GPS attached, into a fantastic realtime Chart Plotter. Download free charts (I have secured about 2 thousand this way) from NOAA or USCG or Maptech and you are good to go. PC Chart plotter and GPS Navigation software SeaClear is a PC based chart plotter for Windows 2000/XP/NT/95/98/ME. With a GPS connected it displays the current position, speed, heading and other data on the screen. The chart is repositioned and new charts are loaded automatically as needed. Tracks may be saved to file for later reviewing and log book
entries can be manually and automatically entered. Unlimited number of routes and waypoints can be created and used to assist the navigation. The screen area for charts is maximized with most functions accessed with the right mouse button. Zooming is provided with support for IntelliMouse wheel. SeaClear is created for nautical navigation but can probably be used for other navigation needs. Features License Downloads History Features and Requirements: SeaClear works on most PC’s running Windows 95 and up, but as Windows 95/98/ME has many limitations, Windows 2000/XP/Vista is recommended. No Linux version is available but SeaClear is reported to work well with Wine, see WineHQ for more details. GPS: The GPS must be capable of transmitting NMEA 0183 1.5 or higher messages. Most
modern GPS units with PC communication will work. Virtual serial ports, such as USB GPS units with serial drivers, are supported. Optionally other NMEA instruments may be connected. Depth, Compass and Wind is displayed if present. With AIS receiver connected targets are displayed on screen. On units capable of receiving NMEA waypoint and route data, uploading from the PC is supported. Charts: SeaClear II uses raster charts and can use most BSB/KAP version 1 - 3 and GEO/NOS commercial charts. Encrypted charts, like BSB/CAP can not be used. Most common projections are supported. Chart datum’s are supported. You can add your own charts, scan or capture them, save as PNG, BMP or other common
format. Skewed and rotated charts can be calibrated. Chart border can be set to reduce the actual chart area. Routes: Unlimited number of routes are easily created. Maximum number of route points limited by memory only. Several routes may be joined. Tracks can be imported. Cross track error alarm. Calculation of time to go, total time to go, bearings, steering indicator and output to NMEA. Waypoints: Unlimited number of waypoint files can be created. Maximum number of waypoints limited by memory only. Multiple files can be merged. Quick locate of waypoint loads map and centers waypoint on screen. Tracks: Tracks are saved to file and plotted. Saved tracks can later be plotted and used to create routes. Logbook: Automatic and manual log book entries into a text file. Import / Export: Import and export of routes, waypoints and tracks using G7ToWin and to G7T and Waypoint+ text file format. Export of waypoints and routes to supporting NMEA devices. Language independent: Most text and menus can be user translated to any language without any special tools. Several languages are included (Documentation file in English). Other: NMEA Depth, Wind, Compass and AIS. GPS based Log, Hours and estimated fuel consumption. Night modes with shaded charts. SeaClear License: You are granted a free non-exclusive license to use the SeaClear software subject to the following terms and conditions:You read and agree to the full license text in the included SeaClear manual.SeaClear is provided ‘as-is’, without any warranty or support, expressed or implied. In no event will the author
or Sping be held liable for any damages arising from the use of this software. All SeaClear software and documentation is the property of and copyrighted by Sping. Local law and regulation may restrict the use of electronic navigation software. Always follow local regulations, have original charts and use appropriate navigation equipment when using SeaClear.SeaClear must never unattended send information to any device controlling the boat.SeaClear is only a navigational aid, not a replacement for navigational knowledge, nor can it navigate by it self. Downloads: SeaClear II Full install sc_setup.exe ~ 2 Mb. With English Manual. SeaClear II Files in zip archive ~1.5 MbSeaClear II Spanish Manual (2002.07.01, Thanks to Juan Pablo Pileggi. ~460k)SeaClear II Swedish Manual (2006.08.14, Thanks to Bengt Wannerheim. ~300k)SeaClear II German Manual (2005.12.02, Thanks to Udo Wyklicky . ~300k)SeaClear II French Manual (2002.06.30, Thanks to René Massia. ~430k)SeaClear II Finnish Manual (2005.02.20, Thanks to Sakari Nylund. Link)SeaClear II Dutch Manual (2005.08.08, Thanks to Egenolf v Stein Callenfels. ~1200k)SeaClear II Hebrew Manual (2005.07.15, Thanks to Isaac Engelberg & Jonathan Schafer. ~300k) SeaClear II Turkish Manual (2007.12.12, Thanks to Mustafa Pultar. Link) Previous Versions: SeaClear for Windows 95 (2001.03.12, ~800k) Old version, lacking many features. SeaClear for Windows 3.x (1996.11.20, ~365k) Old version, lacking many features.Basic Charts (~215k)SeaClear Swedish manual (2001.03.17, Supplied by Bengt Wannerheim, Thanks. ~310k) Utilities: Screen Capture Utility (2002.06.16, ~230k. Capture, Crop & Stitch, help for map making)SeaTrack and SeaTrace (link, SeaClear II Track utility and add-on,
by Philip Beekman) Information: How to scan charts & much more (2002.05.07. By Anders Nilsson, Thanks. ~150k)German SeaClear II training guide (2003.02.12. Thanks to Udo Wyklicky . ~1100k) History: 1995: Got a boat, needed navigation software, couldn’t find any I liked with charts for my area, so the SeaClear project started… (lot’s of work)Current release history. Links: GPS, NMEA and navigation related information and links: Peter Bennett’s GPS directoryGPS up/downloading and managing waypoints: G7ToWin or Waypoint+ Windows XP/2000 GPS detected as mouse / Jumping mouse fix: MicrosoftShare your Tracks and Routes: TracksMaster Free US BSB charts at NOAA or Freeboatingcharts SeaClear was created for personal needs, without any commercial connection, and is maintained and supported on spare time only. The
“to-do” list is quite long, and it tends to grow much faster than time to implement it. Reliability and simplicity (not saying everyone find it simple) is always top priority. And as spare time is rather limited, all emails are read but time doesn’t permit all to be answered, many ideas and “to-do’s” are still to be implemented and some probably never will be. But if you find SeaClear useful, find any bugs, have some new ideas, or any other reason, you are always welcome to send an email. Navigate safe and have fun.Send comments to: XX.seaclear@… (Replace XX with “06”. Spam protection) “Life is a Reach, then you Jibe” SWARD
Attachment: (image/gif) sc_logo2.gif [not stored]
I’m using this excellent and free piece of software from Sweden
since perhaps 5 years with commercial charts of my region. Many
sailors I know use it and it is supplied with the NASA Target AIS
black box receiver as SIS plotter. Works fine. It can run on an old
laptop. I have the best experiences with a real DB-9 serial port,
although a USB GPS mouse works also if you’re capable of configuring
the USB port to a com port.
Michel Capel
— In FreedomOwnersGroup@yahoogroups.com, Sward <swardfullsail@…>
or Maptech and you are good to go.PC Chart plotter and GPS Navigation software SeaClear is a PC based chart plotter for Windows
Tracks may be saved to file for later reviewing and log book entries
needs.
Features
License
Downloads
HistoryFeatures and Requirements: SeaClear works on most PC's running Windows 95 and up,
higher messages. Most modern GPS units with PC communication will
supported.
capture them, save as PNG, BMP or other common format. Skewed and
waypoint on screen.
Other:
and estimated fuel consumption. Night modes with shaded charts.SeaClear License: You are granted a free non-exclusive license to use the
SeaClear manual.
expressed or implied. In no event will the author or Sping be held
navigational knowledge, nor can it navigate by it self.Downloads: SeaClear II Full install sc_setup.exe ~ 2 Mb. With
English Manual.
Pileggi. ~460k)
Wannerheim. ~300k)
~300k)
~430k)
Link)
Callenfels. ~1200k)
Link)
Previous Versions:
many features.
Thanks. ~310k)
Utilities:
by Philip Beekman)
Information:
Wyklicky . ~1100k)History: 1995: Got a boat, needed navigation software, couldn't
started.
… (lot’s of work)
Current release history.Links: GPS, NMEA and navigation related information and links:
Microsoft
Free US BSB charts at NOAA or FreeboatingchartsSeaClear was created for personal needs, without any
only. The “to-do” list is quite long, and it tends to grow much
protection)“Life is a Reach, then you Jibe”
SWARD
