Posted by ABC (oldbrochan@…>)
The “Y” valve on the toilet system on my F32 (Mull) appears to have seized, fortunately in the ‘Overboard’ position. Has anyone any similar experience and if “yes” how did you access the valve and then remove it for repair and/or replacement? It has been suggested to me by a marine sanitation company, that the valve may simply be seized and that removing the valve and soaking it in vinegar may solve this problem. Any help/assistance gratefully received. David F32#124
All new Yahoo! Mail “The new Interface is stunning in its simplicity and ease of use.” - PC Magazine
The Y valve of my Mull 30 seized when part of the handle stem broke off in it. I can’t get the broken piece out, but I haven’t exhausted all possibilities since it is seized in the position that directs waste to the holding tank, which is the only legal position inshore anyhow.
As to access, if your 32 is like my 30, the valve can be accessed in two ways. If you remove the toilet paper holder, you can reach most of the valve. From the door under the sink, I can just barely reach the valve. There are a few screws on the outside of the cabinet that affix the valve to the cabinet. Remove those and then remove the hoses by borrowing some long arms and going in via the under sink door.
Good luck.
Al Lorman
F30 Ab Initio
P.S. None of this may work if you have a Hoyt 32, which, from your boat’s number, may be the case.
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of ABCSent: Sunday, July 16, 2006 12:06 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Seized “Y” valve
David
F32#124
Posted by Kevin P. Taylor (kevin@…>)
I am curious what the main differences are between the Mull and Hoyt
32s?
Thx.
–Kevin
(Freedom Wannbe)
inshore anyhow.As to access, if your 32 is like my 30, the valve can be accessed
under sink door.Good luck.
Al Lorman
F30 Ab InitioP.S. None of this may work if you have a Hoyt 32, which, from your
boat’s number, may be the case.-----Original Message-----
Subject: [freedomyachts2003] Seized “Y” valveThe “Y” valve on the toilet system on my F32 (Mull) appears to have
seized, fortunately in the ‘Overboard’ position.Has anyone any similar experience and if “yes” how did you access
the valve and then remove it for repair and/or replacement?It has been suggested to me by a marine sanitation company, that
soaking it in vinegar may solve this problem.Any help/assistance gratefully received.
David
F32#124All new Yahoo! Mail “The new Interface is stunning in its
simplicity and ease of use.” - PC MagazineIRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax
taxpayers particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely
The Mull 32 is a Mull 30 with a 2’ sugar scoop added to the stern. The Hoyt 32 is a totally different boat, although both share essentially the same type of rigging. The Mull boats are pretty traditional-looking inside and out for a mid-1980’s boat. The Hoyt boats are a bit older and have a more eccentric design. I probably shouldn’t say this, but I’m told that the Hoyt boats sail better.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Kevin P. TaylorSent: Sunday, July 16, 2006 2:06 PMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] Seized “Y” valve
I am curious what the main differences are between the Mull and Hoyt 32s?Thx.–Kevin(Freedom Wannbe)On Jul 16, 2006, at 12:13 PM, Lorman, Alvin J. wrote:>> The Y valve of my Mull 30 seized when part of the handle stem broke > off in it. I can’t get the broken piece out, but I haven’t > exhausted all possibilities since it is seized in the position that > directs waste to the holding tank, which is the only legal position > inshore anyhow.>> As to access, if your 32 is like my 30, the valve can be accessed > in two ways. If you remove the toilet paper holder, you can reach > most of the valve. From the door under the sink, I can just barely > reach the valve. There are a few screws on the outside of the > cabinet that affix the valve to the cabinet. Remove those and then > remove the hoses by borrowing some long arms and going in via the > under sink door.>> Good luck.>> Al Lorman> F30 Ab Initio>> P.S. None of this may work if you have a Hoyt 32, which, from your > boat’s number, may be the case.>> -----Original Message-----> From: freedomyachts2003@yahoogroups.com > [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of ABC> Sent: Sunday, July 16, 2006 12:06 PM> To: freedomyachts2003@yahoogroups.com> Subject: [freedomyachts2003] Seized “Y” valve>>> The “Y” valve on the toilet system on my F32 (Mull) appears to have > seized, fortunately in the ‘Overboard’ position.>> Has anyone any similar experience and if “yes” how did you access > the valve and then remove it for repair and/or replacement?>> It has been suggested to me by a marine sanitation company, that > the valve may simply be seized and that removing the valve and > soaking it in vinegar may solve this problem.>> Any help/assistance gratefully received.>> David> F32#124>> All new Yahoo! Mail “The new Interface is stunning in its > simplicity and ease of use.” - PC Magazine>>> IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax > matters was neither written nor intended by the sender or Mayer, > Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer > for the purpose of avoiding tax penalties that may be imposed under > U.S. tax law. If any person uses or refers to any such tax advice > in promoting, marketing or recommending a partnership or other > entity, investment plan or arrangement to any taxpayer, then (i) > the advice was written to support the promotion or marketing (by a > person other than Mayer, Brown, Rowe & Maw LLP) of that transaction > or matter, and (ii) such taxpayer should seek advice based on the > taxpayers particular circumstances from an independent tax advisor>> This email and any files transmitted with it are intended solely > for the use of the individual or entity to whom they are addressed. > If you have received this email in error please notify the system > manager. If you are not the named addressee you should not > disseminate, distribute or copy this e-mail.>>
The Y valve on my '87 Mull 28 had a locking ring that prevented the
handle from rotating. This ring served to keep the valve in the
holding tank position. Before assuming that the valve is seized,
check it for the ring. Checking requires removal of the valve from
its mounting wall as per Al’s directions. Herm, F28 Impulse
inshore anyhow.As to access, if your 32 is like my 30, the valve can be accessed in
the hoses by borrowing some long arms and going in via the under sink door.Good luck.
Al Lorman
the valve and then remove it for repair and/or replacement?It has been suggested to me by a marine sanitation company, that the
David
F32#124<http://us.rd.yahoo.com/mail/uk/taglines/default/nowyoucan/pc_mag/*http://us.rd\
.yahoo.com/evt=40565/*http://uk.docs.yahoo.com/nowyoucan.html>All
particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely for
The “Y” valve on my Hoyt32 was located above the head unit, on the aft head bulkhead. I do not know if this is/was typical. After fighting with it (the Y valve) for over a year, I removed it and completely re-plumbed the head-to-holding tank system. On my Hoyt (again I don’t know if this is typical) the base of the holding tank is well above the waterline. This enabled me too dispense with the ridiculous “Rube Goldgerg” system that was in place (I hope TPI didn’t do it) and install a simple system that goes from the head directly into the holding tank. To empty the holding tank I simply open the dump seacock (where legal) and the tank drains in about 15 seconds. I also still have the option to dump shoreside via the deck fitting. I know this sounds too good to be true, but it has worked perfectly for the two years that I’ve had it installed, and the beauty of it is that it dispenses with trickery such as Y
valves (which seem to have a failure rate of about 1000%) and pumps. By the way, I installed a nice Marinco stainless waterproof 120v outlet in the hole left by the Y valve. Needed one in the head anyway (win win). If you need more info, let me know… PWMABC <oldbrochan@…> wrote: The “Y” valve on the toilet system on my F32 (Mull) appears to have seized, fortunately in the ‘Overboard’ position. Has anyone any similar experience and if “yes” how did you access the valve and then remove it for repair and/or replacement? It has been suggested to me by a marine sanitation company, that the valve may simply be seized and that removing the valve and soaking it in vinegar may solve this problem. Any help/assistance gratefully received. David F32#124 All new Yahoo! Mail “The new Interface is stunning in its simplicity and ease of use.” - PC Magazine
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
I did the same thing to retrofit my Hoyt 32. I added a macerator pump. It
was a fairly simple process, too.
TW F32 #20 Anoush Koon
the head-to-holding tank system.On my Hoyt (again I don’t know if this is typical) the base of the holding
the option to dump shoreside via the deck fitting.I know this sounds too good to be true, but it has worked perfectly for
dispenses with trickery such as Y valves (which seem to have a failure
rate of about 1000%) and pumps.By the way, I installed a nice Marinco stainless waterproof 120v outlet in
the hole left by the Y valve. Needed one in the head anyway (win win).If you need more info, let me know…
PWM
seized, fortunately in the ‘Overboard’ position.Has anyone any similar experience and if “yes” how did you access the
David
F32#124
<http://groups.yahoo.com/gads;_ylc=X3oDMTJkbjVwNGg2BF9TAzk3MzU5NzE0BF9wAzEEZ3JwS\
WQDMTExNTIwNzEEZ3Jwc3BJZAMxNjAwMDY1NzkyBHNlYwNzbG1vZARzdGltZQMxMTUzMTYxNTE1?t=ms
&k=Sailing+schools&w1=Sailing+schools&w2=Sailing+instruction&w3=Sailing+lesson&w
4=Sailing+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.sig=7_oQ_b3q06osu
1SDl7MI5Q>Sailing<http://groups.yahoo.com/gads;_ylc=X3oDMTJkbjVwNGg2BF9TAzk3MzU5\
NzE0BF9wAzEEZ3JwSWQDMTExNTIwNzEEZ3Jwc3BJZAMxNjAwMDY1NzkyBHNlYwNzbG1vZARzdGltZQMx
MTUzMTYxNTE1?t=ms&k=Sailing+schools&w1=Sailing+schools&w2=Sailing+instruction&w3
=Sailing+lesson&w4=Sailing+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.
sig=7_oQ_b3q06osu1SDl7MI5Q>
schools
<http://groups.yahoo.com/gads;_ylc=X3oDMTJkdTZiMTY5BF9TAzk3MzU5NzE0BF9wAzIEZ3JwS\
&k=Sailing+instruction&w1=Sailing+schools&w2=Sailing+instruction&w3=Sailing+less
on&w4=Sailing+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.sig=cda0vzSDF
YSAxw6sgenW9Q>Sailing
instruction
<http://groups.yahoo.com/gads;_ylc=X3oDMTJkMXY0MGNzBF9TAzk3MzU5NzE0BF9wAzMEZ3JwS\
&k=Sailing+lesson&w1=Sailing+schools&w2=Sailing+instruction&w3=Sailing+lesson&w4
=Sailing+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.sig=PYsTac_hC0W7J2
lKCS-ysQ>Sailing
lesson
<http://groups.yahoo.com/gads;_ylc=X3oDMTJkOG0wcWxyBF9TAzk3MzU5NzE0BF9wAzQEZ3JwS\
&k=Sailing+adventure&w1=Sailing+schools&w2=Sailing+instruction&w3=Sailing+lesson
&w4=Sailing+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.sig=LHjFeInIcy7
sXTvQV545nw>Sailing
adventure
<http://groups.yahoo.com/gads;_ylc=X3oDMTJkcG5rNGlhBF9TAzk3MzU5NzE0BF9wAzUEZ3JwS\
&k=Sailing&w1=Sailing+schools&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailin
g+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.sig=Kbp6_9uyjLqwKcmiX7mra
g>Sailing
<http://groups.yahoo.com/gads;_ylc=X3oDMTJkY3VybzQwBF9TAzk3MzU5NzE0BF9wAzYEZ3JwS\
&k=Ocean+sailing&w1=Sailing+schools&w2=Sailing+instruction&w3=Sailing+lesson&w4=
Sailing+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.sig=ub5lbAqrGNiQ8ZE
RVX9wjA>Ocean
sailing
910a469.jpgNo virus found in this incoming message.
Checked by AVG Anti-Virus.
Version: 7.1.394 / Virus Database: 268.10.1/389 - Release Date: 7/14/2006
Attachment: (application/octet-stream) 910a469.jpg [not stored]
Attachment: None [not stored]
Posted by Larry Kraus (kracherlandl@…>)
Did any of you guys add a larger holding tank? We’ve got a 32 on the
Mississippi river and can’t dump overboard ever. A 12 gallon tank isn’t
large enough for 4 people for a week. We’re studying options but
haven’t found a solution yet.
LK
Thomas Wales wrote:
I did
it dispenses with trickery such as Y valves (which seem to have a
win).
PWM
position.
David
F32#124
<[http://groups.yahoo.com/gads;_ylc=X3oDMTJkbjVwNGg2BF9TAzk3MzU5NzE0BF9wAzEEZ3JwSWQDMTExNTIwNzEEZ3Jwc3BJZAMxNjAwMDY1NzkyBHNlYwNzbG1vZARzdGltZQMxMTUzMTYxNTE1?t=ms&k=Sailing+schools&w1=Sailing+schools&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.sig=7_oQ_b3q06osu1SDl7MI5Q>Sailinghttp://groups.yahoo.com/gads;_ylc=X3oDMTJkbjVwNGg2BF9TAzk3MzU5NzE0BF9wAzEEZ3JwSWQDMTExNTIwNzEEZ3Jwc3BJZAMxNjAwMDY1NzkyBHNlYwNzbG1vZARzdGltZQMxMTUzMTYxNTE1?t=ms&k=Sailing+schools&w1=Sailing+schools&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.sig=7_oQ_b3q06osu1SDl7MI5Q](http://groups.yahoo.com/gads;_ylc=X3oDMTJkbjVwNGg2BF9TAzk3MzU5NzE0BF9wAzEEZ3JwSWQDMTExNTIwNzEEZ3Jwc3BJZAMxNjAwMDY1NzkyBHNlYwNzbG1vZARzdGltZQMxMTUzMTYxNTE1?t=ms&k=Sailing+schools&w1=Sailing+schools&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.sig=7_oQ_b3q06osu1SDl7MI5Q>Sailing<http://groups.yahoo.com/gads;_ylc=X3oDMTJkbjVwNGg2BF9TAzk3MzU5NzE0BF9wAzEEZ3JwSWQDMTExNTIwNzEEZ3Jwc3BJZAMxNjAwMDY1NzkyBHNlYwNzbG1vZARzdGltZQMxMTUzMTYxNTE1?t=ms&k=Sailing+schools&w1=Sailing+schools&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+adventure&w5=Sailing&w6=Ocean+sailing&c=6&s=121&g=2&.sig=7_oQ_b3q06osu1SDl7MI5Q)
schools
7/14/2006
I didn’t install a larger holding tank because we don’t need to as we sail
offshore in Maine regularly. There should be plenty of room to retrofit a
bigger tank down there. There is a guy in Maine here that “welds” plastic
and can custom make a tank for you to fit the space. I’m sure you could
find someone near the Mississippi who could do the same for you if you
can’t find a stock tank to fit. Saltwater sailing is simpler in this regard.
Good luck,
TW
large enough for 4 people for a week. We’re studying options but haven’t
found a solution yet.LK
pump. It was a fairly simple process, too.
I also still have the option to dump shoreside via the deck fitting.I know this sounds too good to be true, but it has worked perfectly for
failure rate of about 1000%) and pumps.By the way, I installed a nice Marinco stainless waterproof 120v outlet
in the hole left by the Y valve. Needed one in the head anyway (win win).If you need more info, let me know…
PWM
David
F32#124
schools
instruction
lKCS-ysQ>Sailing
lesson
sXTvQV545nw>Sailing
adventure
g>Sailing
RVX9wjA>Ocean
sailing
Version: 7.1.394 / Virus Database: 268.10.1/389 - Release Date: 7/14/2006No virus found in this outgoing message.
Version: 7.1.394 / Virus Database: 268.10.1/389 - Release Date: 7/14/2006No virus found in this incoming message.
Version: 7.1.394 / Virus Database: 268.10.1/390 - Release Date: 7/17/2006
Attachment: (application/octet-stream) e169ad5.jpg [not stored]
Attachment: (application/octet-stream) e169b32.jpg [not stored]
Thanks for the suggestions.
LK
Thomas Wales wrote:
I didn’t
retrofit a bigger tank down there. There is a guy in Maine here that
“welds” plastic and can custom make a tank for you to fit the space.
I’m sure you could find someone near the Mississippi who could do the
same for you if you can’t find a stock tank to fit. Saltwater sailing
Good luck,
TW
tank? We’ve got a 32 on the Mississippi river and can’t dump overboard
ever. A 12 gallon tank isn’t large enough for 4 people for a week.
We’re studying options but haven’t found a solution yet.
LK
32. I added a macerator pump. It was a fairly simple process, too.
win).
PWM
position.
David
F32#124
schools
7/14/2006
7/14/2006
7/17/2006
