Separate bildges on Freedom 40?
Hi everyone,
We have a 1979 Freedom 40, hull #18, with a centerboard, and we have some questions about our bilge layout and ballast.
From what we understand now, it seems like we have two separate bilges. I tried to show this on the sketch as Bilge 1 and Bilge 2.
Bilge 1 starts in the aft cabin, where water from the prop shaft drips into it. It runs forward under the engine and through the engine room. When it reaches the centerboard trunk, the trunk divides the bilge into two narrow sections, port and starboard. These run around the trunk, under mizzen mast area and then join back together near the galley in main cabin once the centerboard trunk ends. At the forward end of this bilge, in the main cabin, it gets deeper - I tried to show the different depths with different shades of blue on the sketch.
Bilge 2 starts in the forward cabin. It is narrow at first and runs under the berth, then under the head/shower area, and a small part of it reaches into the main cabin. It also has a deeper area in the main cabin, and then it ends.
A while ago we spent a lot of time testing this by filling both bilges with water. The water never moved from one bilge to the other, so that is how we realized they seem to be separate.
Between these two bilges there is ballast sealed under fiberglass. In a few places the fiberglass structure is damaged/open, and we can see the ballast. It looks like small lead pellets or another metal, I’m not sure. Visually, honestly, it looks like pellets mixed with dirt, but I assume it is supposed to be metal pellets mixed with resin?
Recently we noticed that in Bilge 2, at the very bottom, there is a hole where water drains down. But it does not drain completely: some amount of water collects there and then just stands. We tried pushing a hose into it, flushing it, and putting an endoscope in. There seems to be some kind of pipe or tube continuing from that hole. Draw it with pink on my sketch. It is impossible to get our head in there to see properly, but based on how much hose fits inside, the pipe seems long enough that it should reach toward Bilge 1. But it stops at the end, and in Bilge 1 we cannot find any matching hole, opening, or exit at all.
We also tried pouring warm water into that hole and checking with a thermal camera to see whether anything warmed up in Bilge 1. We thought maybe the two bilges used to be connected and were later glassed over. But the thermal camera did not show anything. We are afraid to pour very hot water in because we do not know what that pipe is made of or what is inside.
So our questions are:
Does anyone have a similar layout or experience with this? How is this supposed to be?
If the two bilges are supposed to be separate, then what is this pipe/hole in Bilge 2 for? Where was it supposed to go, and what was the original design idea?
We also have questions about the ballast. Can someone who understands this construction explain why it was built this way? Do we need to plan any future repair, considering that some of the fiberglass covering over the ballast has opened up?
I am pretty sure water has gotten into that ballast area at times, and maybe some water is still trapped in there.
I have heard of people removing loose lead pellets, melting them into ingots, and placing them back in the keel/ballast area. Does that make any sense in this case, or is it unnecessary?
I can take more photos and videos if needed. I am just not sure how to explain this clearly, so I hope this description makes sense. What do you think?
Thanks for your detailed bilge description. I intend to investigate our bilge arrangement over coming month as refitting f40 after cockpit no60. I will post findings in due course, but your drawing and explanation a good indication of what to expect… Best of luck with your investigations. Sorry cant be more help today.
Thank you!:blush:
I will wait for your findings
Hi Anna. I have been looking in my bilge and spent hours cleaning old oil etc from both bilges.
Using your referencing my bilge 1 is like yours, ending in the central section in what I call the sump. This is the deepest part of the bilge where the bilge pump and manual bilge suction hose is located. Bilge 2, the forward bilge drains through the central pipe…1.5 inch? Or there abouts…all the way into the sump. So on my 40 CK aft cockpit, both bilges are connected by the pipe…as makes sense. My ballast box, spanning the whole width of the underfloor beam, prehaps 4 ft? fore to aft is sealed and without destruction cannot identify the contents.
I hope that helps in some way.
All the best.
Thank you so much for getting back to me. Would it be possible for you to take a few photos for me? I would really like to see how everything is arranged on your boat. Maybe we could also somwhow recreate that pipe as well, which would make sense.
For convenience, you can send the photos to me by email or Instagram: nozzhkina@gmail.com or @anna.please
Hi Anna.
I not on board Asterix ( ex Fantasy no60) at moment but found a photo.
This shows where the pipe from bilge 2 goes into bilge 1 at the deepest part, just aft of the ballast, which i call the sump. This is where bilge water is extracted by the pumps.
If you look closely, you can see the 1.5? or 2? inch pipe hole.
It’s pretty difficult technically to glass in a flush pipe end successfully for decades. It’s probably easier if a protrusion exists. It’s likley a safe assumption to say water from the bilge was getting into the ballast, so the pipe exit was glassed over as a seal.
Today we have epoxy resin that cures in wet areas or underwater so re instating the pipe and bilge 2 drain is an easier job…fiddly and boring, but doable.
If you had any photos of the ballast it would be great to post them here.
At some point its enivetable ill be in that area with an angle grinder.
All the best
(attachments)
Wow, in your photo the pipe outlet is exactly where we expected it to be, but on our boat it just isn’t there. We would try to cut it open again, but I don’t understand how to start cutting exactly where the pipe should be. There are no visible traces at all, the fiberglass is very smooth and flat there, and we really don’t want to start cutting everything blindly.
I’m adding a few photos. Our ballast “ fiberglass cover” is damaged a bit, and you can see the filler inside - little balls (I think lead shot) mixed with resin. There is also a little water standing at the bottom. Do you think that is a serious problem? What should we do about it?
In the photo where I marked a scheme of ballast and bildges, I used a green marker to show the cracks in the fiberglass through which I have a little access to peek inside the ballast.
Hi Anna
So I suppose these boats are about 50 years old. People will have fone various jobs over the period, some better than others. In principle you want the ballast area dry and sealed with a through pipe from bilge 1 to 2 so all bilges drain from a central point .
So considering the condition of your fibreglass balast cover I would plan to do that job properly at a point in the future. If it was me I would seal the ballast area with some basic fibreglass so no water can get in then leave it for a proper go at a refit in the future. I dont think it would get worse over a year or two.
A proper job would be to expose the ballast and remove it to ensure no water in there, area in good condition and dry. While removed, glass a pipe in between bilge 1 and 2 and seal so no bilge water can get in ballast area. Replace ballast snd make good sealing it in for another 50 years.
It may be that the ballast is in resin and sealed when you get the first couple inches of loose out. That would be good. So I wouldn’t expose any more as I would know it’s dry. I would then resin the old blast back in, make good, then grind/sand out where I thought the pipe end should be and expose it, make the pipe end good to the bilge, then reglass the blast tank to create a good seal etc.
It’s probably fine as it is for a while but I would want to expose it all and see what was done, and why it was done. There will be something in there that didn’t allow the previous repair to be done properly. That could be a significant difficulty in the access, futher damage or lack of location and availability of funds? knowledge? Tools? materials? You’ll find out when it gets to the top of the jobs list …please do post some photos when you do surgery as its a great record…best of luck.
Thank you! That’s pretty much what we were leaning toward too. Hopefully we’ll get around to doing it at some point!
