sheaves
Posted by wink50109 (jlittle@…>)
anyone know of a source for roller bearing mast head sheaves for a 39
express. the size is 3/4" thick x 3 1/2" o.d. with 3/8" center hole.
also i just purchased and used for the first time the milwaukee 1/2"
18v cordless right angle drill to go up the mast. i weigh 185 and
went up like i was in an elevator. after the work was complete i put
a meter on the battery and still had 19.88 volts. i made a bit to fit
the winch from a 5/8" stainless bar and turned the chuck end down to
3/8"
Check with Garhauer Marine. They have a good selection of masthead sheaves, good prices, and can/will custom fabricate. their number is 909-985-9993.wink50109 <jlittle@…> wrote:
anyone know of a source for roller bearing mast head sheaves for a 39express. the size is 3/4" thick x 3 1/2" o.d. with 3/8" center hole.also i just purchased and used for the first time the milwaukee 1/2"18v cordless right angle drill to go up the mast. i weigh 185 andwent up like i was in an elevator. after the work was complete i puta meter on the battery and still had 19.88 volts. i made a bit to fitthe winch from a 5/8" stainless bar and turned the chuck end down to3/8"
Do you Yahoo!?
Yahoo! Mail is new and improved - Check it out!
