Posted by john reed (john-reed@…>)
It looked
to me like the insulators would interfere with eyesnaps (or whatever they’re
called) that hold the jib to the
forestay. If you think not, I’d be very
interested in considering your solution.
J&K
Langsam
-----Original
Message-----
[mailto:freedomyachts2003@yahoogroups.com]On
Behalf Of Dennis
Sent: Saturday, July 30, 2005
10:46 AM
To:
Single Side Band
A traditional rigged boat uses the back stay with insulators as
SSB antenna – has anyone ever considred putting insulators on the
Freedom forestay and using it as an SSB antenna?
— In freedomyachts2003@yahoogroups.com, Sward <swardfullsail@y…>
Thank you so much for your suggestions and help. Please let me
know how you make out.
Sward
john reed <john-reed@c…> wrote:
v:* {behavior:url(#default#VML);}o:* {behavior:url
(#default#VML);}w:* {behavior:url(#default#VML);}.shape
Sward,
I’ve just bought an icom M700 SSB for our F32. I’ve been looking
at the Shakespeare 390 whip but it’s not recommended for heavy seas.
Since one of the reasons for having the SSB is to scream for help
on 2182 having to ship the antenna when things get rough seems to be
a real limitation. I’ve considered running a 23 foot cable with
insulators up the pennant line and seeing how that does. Another
possibility,
mentioned by a sailor/ham was to antenna inside the mast. The
mast is a conductor and is grounded so it should shield the
antenna. I’m
going to give it a try while the boats in the yard and see if it
works. I seriously doubt it.
Another possibility is to drop the antenna from the masthead to
the deck, mount insulators and turnbuckles at both ends and run the
antenna
lead through the coach top. I should be getting around to this
part of the refit in a week or two and I’ll let you know what seems
to work best.
The other real pain is the ground. There is a ground plat on the
bottom of the keel and it should work. I’m going to run a lead from
a grounding
rod to it and see if the existing system ground works. There are
a bunch of other possibilities including counterpoise (see the
book), trailing
a length of copper mesh from the transom and encasing the keel in
copper sheeting. I hope the keel plat work!
By the by, I purchased an automatic tuner along with the radio.
It was highly recommended by all of the ham folks I talked with.
John & Karen Reed
Langsam
-----Original Message-----
[mailto:freedomyachts2003@yahoogroups.com]On Behalf Of Sward
Sent: Thursday, July 28, 2005 8:19 AM
To: Freedomyachts2003@yahoogroups.com
Subject: [freedomyachts2003] Single Side Band
Hello all,
I am considering installing a SSB-given to me by a friend. He
said it is difficult mounting the antenna, and grounding it.
Does anyone have any solutions to those problems or had experience
installing a SSB
Sward
s/v “Dream On”
Freedom32 #88
SPONSORED LINKS
Sailing Boating Boating magazine Boating safety Caribbean sailing
Sailing schools
YAHOO! GROUPS LINKS
Visit your group "freedomyachts2003"
on the web.
To unsubscribe from this group, send an email
to:
Your use of Yahoo! Groups is subject to the
Yahoo! Terms of
Service.
