Posted by Skip Turpin (skipperf33@…>)
Thought I would weigh in on this one.
Stainless back stays have been used for years. They have been used
primarily because they are there! Stainless does work, but it is not
a great antenna material for SSB use.
As I primarily cruise my F33 Cat/ketch, I opted to go with a standard
length of real SSB antenna wire. It is attached to the top of the
main mast and runs down to the tip of the bowsprit and then into the
chain locker where my tuner is located. The antenna has a bungee at
the sprit for flex. This also allows me to move the antenna out of
the way should I host a Bar-B-Q on the massive foredeck. (RIGHT!)
As the part of the antenna that runs to the tuner is also still part
of the transmitting antenna, you want to keep your tuner as close as
possible to the vertical part of the antenna!
I don’t suggest putting the bungee at the top of the antenna. With
time and sun, your bungee WILL fail. When this happens your antenna
will be in the water and God knows where else. If it fails at the
bottom, you get a little extra play. No big deal. BTW don’t wire
tie the antenna along the edge of the bowsprit. You will lose
valuable transmitting power. The rule of thumb is never run the
antenna parallel to any metal. Try to cross at 90* if possible.
Most all tuners today are mounted in self contained weather prof
boxes, so the dampness in the chain locker should not be a factor.
On my F33 there is a PVC conduit below the toe rail that runs from
the Nav Station to the chain locker. This would be the most direct
root for your cable from the SSB radio to the tuner.
A word to the wise: You do need to get your Amateur Radio Licence
(HAM) in order to us that SSB radio to talk. You can listen all you
like, but no talk. The exception being that anyone in a “Declared
Emergency” can talk on ANY frequency to get help!
I personally think an SSB for cruising is a must. Even if you don’t
us it to talk. There is a wealth of info given out over hundreds of
NETs all over the world. When the chips are down, don’t be shy, KEY
the thing and get the needed help!
You will want to get some help on installing and setting up your
SSB! They can be a little tricky, so take the time to learn how to
use the thing before you are in that “PICKLE”! We all suffer from
some “BRAIN FREEZE” when the poop hits the fan. That is no time to
be trying to figure out how to use the damn thing!!!
Good luck!
Skip
