slipping V-belts
Posted by ron barr (rwhb@…>)
Interesting info. Does anyone know the correct belt tension
for the Yanmar on an F32?
I recall from my past experience with other motors that the
depression should be about ½”+
Ron
Hoyt F32
Newport RI
Posted by Al Lorman (ajl@…>)
Belts
can also slip become they become glazed. Just had a $53 belt replaced on my
car for that reason. Looked fine, tension fine, but the underside, the part
that contacts the pulleys, was slick.
Al
Lorman
Behalf Of ron barr
Sent: Saturday, August 09, 2008 1:48 PM
Subject: [FreedomOwnersGroup] slipping V-belts
Interesting
info. Does anyone know the correct belt tension for the Yanmar on an F32?
I
recall from my past experience with other motors that the depression should be
about ½”+
Ron
Hoyt
F32
Newport
RI
Posted by amarsib@… (amarsib@…)
Basic rule is if you can twist the belt more than 90 degrees its too loose, twist less than 90 too tight.From: “ron barr” <rwhb@…>Date: Sat, 9 Aug 2008 13:48:21 -0400To: <FreedomOwnersGroup@yahoogroups.com>Subject: [FreedomOwnersGroup] slipping V-belts Interesting info. Does anyone know the correct belt tension for the Yanmar on an F32? I recall from my past experience with other motors that the depression should be about ½”+ Ron Hoyt F32 Newport RI
