Squeeze Bulb for Priming
Like many others, I have been using an outboard squeeze bulb in the line
before the filters. Has worked great on my 3GMD for over ten years.
Makes filling the Racors and priming so simple. John Jones F33
catketch 1982
Bob wrote:
I have the RACOR unit 500MA and it has worked to perfection. Knock on
wood but I have not had a dirty fuel issue yet using this filter and a
fuel funnel filter. And yes there has been water in the fuel but the
filter has separated and I just drain it off. I would like to get
another but that is a lot of lunch money to save, so I can switch off
when needed without an interruption in fuel delivery. However as
suggested below I am investing in a vaccum guage which screws into the
T handle hole and as someone else suggested maybe the fuel bulb (as on
outboard engine gas lines) would work nicely for a primer pump.
Bob
On Sun, Nov 30, 2008 at 11:19 AM, george huffman wrote:
They also make a “T” handle replacement that incorporates a vacuum
gauge. Expensive but effective and easily installed. A good
filtering system should incorporate a vacuum gauge and an easy method
of priming (in my opinion).
— On *Sun, 11/30/08, sgaber@tampabay. rr.com **/<sgaber@tampabay.
rr.com> /*wrote:
From: sgaber@tampabay. rr.com <sgaber@tampabay. rr.com>
Subject: RE: [FreedomOwnersGroup ] ReRacor fuel filters
To: FreedomOwnersGroup@ yahoogroups. com
Cc: “Al Lorman” <ajl@lormanlawdc. com>
Date: Sunday, November 30, 2008, 12:07 AM
Right.
The filters are particular within each brand. And even different
models of the same brand.
I replaced the entire filter unit with a Racor 500FG.
It cost around $180, but the filters are only about $8 each. And it is
much easier to change than all the other filter systems I’ve used on
mine and other boats.
Steve Gaber
Sanderling, 1967 C-31 #77
Oldsmar, FL
---- Al Lorman < ajl@lormanlawdc. com mailto:ajl@...>
Lola:
The standard filter on the 1987 F30 was a Fram. You cannot use a Racor
filter in the Fram housing. You’ll need to buy an entirely new unit -
filter and housing. I installed a series 200 Racor; they run
between $80
and $120 dollars; replacement cartridges run about $20-30.
Al
<mailto:FreedomOwnersGroup@yahoogroups.com>
[mailto: FreedomOwnersGroup@ yahoogroups. com
<mailto:FreedomOwnersGroup@yahoogroups.com>] On Behalf Of lolaltd
Sent: Tuesday, November 25, 2008 9:55 AM
Subject: [FreedomOwnersGroup ] ReRacor fuel filters
— In FreedomOwnersGroup@ yahoogroups. com
<mailto:FreedomOwne rsGroup%40yahoog roups.com> , “lolaltd”
<lolaltd@… >
Hello ,
Also on the Racor fuel filters, I currently use what was on the boat
Napa 3472 will a Racor convert? If so what number cross references
to that Napa?
Thank you…Any F30 folks know also?
Lola F30 1987
Checked by AVG - http://www.avg.com
Version: 8.0.176 / Virus Database: 270.9.12/1822 - Release Date: 12/1/2008
8:23 AM
Posted by katorpus (jrb@…>)
Heck, John…
If you’d installed it on the downstream end of the filters, you’d
have a ready-made vacuum gauge…when the bulb collapses, it’s time
to replace the filter
(Previous comment made with tongue firmly in cheek)
(Following comment is serious)
I bet that bulb doesn’t have a 2 minute fire-life at 1200 degrees,
however.
— In FreedomOwnersGroup@yahoogroups.com, John Jones <a1john@…>
line
years.
catketch 1982
I am sure that your concern is justified but since my bulb is under the
floor board(hatch) and actually lies on top of the fuel tank it is not
in the engine compartment. Oh well. I guess I need a review by a
higher authority. Regards, John Jones
katorpus wrote:
Heck, John…
however.
mailto:FreedomOwnersGroup%40yahoogroups.com, John Jones <a1john@…>
line
years.
catketch 1982
Version: 8.0.176 / Virus Database: 270.9.12/1823 - Release Date: 12/1/2008
7:59 PM
John
“Higher Authority” would likely be in the form of the surveyor on
your next insurance survey. I certainly don’t pretend to be a higher
authority, just an old sailor who spent 13 years as a firefighter &
paramedic.
I tend to be, perhaps, a little “aware” of things that can get you
burned up/blown up/chopped up etc.
You have no idea how many times firefighters arrive at some
conflagration to hear “I had no idea…”
not
katorpus wrote:
Heck, John…
time
however.
<a1john@>
line
years.
catketch 1982
12/1/2008 7:59 PM
I have heard of the gas squeeze bulb as a good primer, but was told that after awhile they can dry out and inject pieces of dry rubber into the system. Sounds like you haven’t had that problem.
I now have a small pump with toggle switch on the fuel line at the fuel tank that works great. After I change the oil, I turn the toggle switch on for a minute and the fuel line is full and the engine runs fine. I’ve spent many hours with the primer pump on the engine-one that was on it’s way out so know what a pain in the neck that can be. I now don’t have to fill the racor 500 full of fuel before I put the cover on.
I am embarrased to say, that I have the pressure T handle and don’t know how to read it. There are 3 needles-which is which-didn’t come with directions about that.
SWARD— On Mon, 12/1/08, John Jones <a1john@…> wrote:
From: John Jones <a1john@…>Subject: [FreedomOwnersGroup] Squeeze Bulb for PrimingTo: FreedomOwnersGroup@yahoogroups.comDate: Monday, December 1, 2008, 9:07 PM
Like many others, I have been using an outboard squeeze bulb in the line before the filters. Has worked great on my 3GMD for over ten years. Makes filling the Racors and priming so simple. John Jones F33 catketch 1982 Bob wrote:> I have the RACOR unit 500MA and it has worked to perfection. Knock on > wood but I have not had a dirty fuel issue yet using this filter and a > fuel funnel filter. And yes there has been water in the fuel but the > filter has separated and I just drain it off. I would like to get > another but that is a lot of lunch money to save, so I can switch off > when needed without an interruption in fuel delivery. However as > suggested below I am investing in a vaccum guage which screws into the > T handle hole and as someone else suggested maybe the fuel bulb (as on > outboard engine gas lines) would work nicely for a primer pump.>>
Bob>>> On Sun, Nov 30, 2008 at 11:19 AM, george huffman wrote:>> They also make a “T” handle replacement that incorporates a vacuum > gauge. Expensive but effective and easily installed. A good > filtering system should incorporate a vacuum gauge and an easy method > of priming (in my opinion). >> George>> — On *Sun, 11/30/08, sgaber@tampabay. rr.com **/<sgaber@tampabay . > rr.com> /*wrote:> From: sgaber@tampabay. rr.com <sgaber@tampabay. rr.com>> Subject: RE: [FreedomOwnersGroup ] ReRacor fuel filters> To: FreedomOwnersGroup@ yahoogroups. com> Cc: “Al Lorman” <ajl@lormanlawdc. com>> Date: Sunday, November 30, 2008, 12:07 AM>>> Right.>> The filters are particular within each brand. And even different > models of the same brand.>> I replaced the entire
filter unit with a Racor 500FG.>> It cost around $180, but the filters are only about $8 each. And it is > much easier to change than all the other filter systems I’ve used on > mine and other boats.>> Steve Gaber> Sanderling, 1967 C-31 #77> Oldsmar, FL>> ---- Al Lorman < ajl@lormanlawdc. com <mailto:ajl@lormanlawdc. com>> > wrote:> > Lola:> >> >> >> > The standard filter on the 1987 F30 was a Fram. You cannot use a Racor> > filter in the Fram housing. You’ll need to buy an entirely new unit → > filter and housing. I installed a series 200 Racor; they run > between $80> > and $120 dollars; replacement cartridges run about $20-30.> >> >> >> > Al> >>
From: FreedomOwnersGroup @ yahoogroups. com > <mailto:FreedomOwnersGroup@ yahoogroups. com>> > [mailto: FreedomOwnersGroup @ yahoogroups. com > <mailto:FreedomOwnersGroup@ yahoogroups. com>] On Behalf Of lolaltd> > Sent: Tuesday, November 25, 2008 9:55 AM> > To: FreedomOwnersGroup @ yahoogroups. com > <mailto:FreedomOwnersGroup@ yahoogroups. com>> > Subject: [FreedomOwnersGroup ] ReRacor fuel filters> >> >> >> > — In FreedomOwnersGroup @ yahoogroups. com > <mailto:FreedomOwnersGroup@ yahoogroups. com>> > <mailto:FreedomOwne rsGroup%40yahoog roups.com> , “lolaltd” > <lolaltd@… >> > wrote:> > >> > >Hello ,> >> > Also on the Racor fuel filters, I currently use what was on the boat> > Napa 3472 will a Racor convert? If so what number cross references> > to that Napa?> >> > Thank you…Any F30 folks know also?> >> > Lola F30 1987> >> >> >>> – >> > ------------ --------- --------- --------- --------- --------- ->>> No virus found in this incoming message.> Checked by AVG - http://www.avg. com > Version: 8.0.176 / Virus Database:
270.9.12/1822 - Release Date: 12/1/2008 8:23 AM>>
The following link (ridiculously long) is to the pdf file for one of
the Racor T-Handles.
http://www.parker.com/portal/site/PARKER/menuitem.734d2913eb3c11da13576f
849420d1ca/?
vgnextoid=d195f87357e28110VgnVCM10000048021dacRCRD&vgnextfmt=default&div
ision=5a13d1bea018f010VgnVCM10000032a71dacRCRD&literaturetype=Technical%
20/%
20Service&searchAttr=searchResult&languages=EN&parentCh=Division#results
If you can’t get there, just navigate through the parker.com website
Three needles as follows:
  1. Black needle is Restriction Pointer which shows the restriction in
    the system at any given point WHILE the engine is running
  2. Red #1 rotates as you turn the clear bezel on the gauge…you set
    this one to the point at which you “want” to change out the filter
    (they say most pumps have trouble at 7" > 10" of mercury…or
    earlier…or later.
  3. Red #2 follows the black needle as it rises, but then stays at the
    highest attained reading (even after engine is off and black needle has
    gone back to zero) until you reset it with the button in the center of
    the gauge
They suggest you pay attention to the point at which your engine shows
signs of filter clogging and then set your change out point accordingly.
Deals here I have not bought from these folks before but they seem to have some good deals.George— In FreedomOwnersGroup@yahoogroups.com, “katorpus” <jrb@…> wrote:>> The following link (ridiculously long) is to the pdf file for one of > the Racor T-Handles.> > http://www.parker.com/portal/site/PARKER/menuitem.734d2913eb3c11da13576f> 849420d1ca/?> vgnextoid=d195f87357e28110VgnVCM10000048021dacRCRD&vgnextfmt=default&div> ision=5a13d1bea018f010VgnVCM10000032a71dacRCRD&literaturetype=Technical%> 20/%> 20Service&searchAttr=searchResult&languages=EN&parentCh=Division#results> > If you can’t get there, just navigate through the parker.com website> > Three needles as follows:> > 1) Black needle is Restriction Pointer which shows the restriction in > the system at any given point WHILE the engine is running> > 2) Red #1 rotates as you turn the clear bezel on the gauge…you set > this one to the point at which you “want” to change out the filter > (they say most pumps have trouble at 7" > 10" of mercury…or > earlier…or later. > > 3) Red #2 follows the black needle as it rises, but then stays at the > highest attained reading (even after engine is off and black needle has > gone back to zero) until you reset it with the button in the center of > the gauge> > They suggest you pay attention to the point at which your engine shows > signs of filter clogging and then set your change out point accordingly.> > > > I am embarrased to say, that I have the pressure T handle and don’t > know how to read it. There are 3 needles-which is which-didn’t come > with directions about that.> > > >>
