Stack pack, Mack pack, Lazy Cradle sail covers
Good to keep in mind. I had never heard of a boom kicker until this conversation.
“Third reef”? Tell us more, tell us more. Much to my spouse’s chagrin, I had Harding fabricate a third reef point this fall. I ask for a design I saw at the Harken website.
My curiosity is based on how to rig the reef line. I was planning on sacrificing my first reef, when the need arises. So typically, my third reef will be naked.
Did not see any discussion regarding rigging a third reef on this thread
Isnt there 3 shives in the boom? Are you using one for the topping lift?
Put Garhouser rigid vangs on for boom control about 20 years ago as I usually single hand. Simplifies the entire process of raising and lowering sails as they carry all of the weight. Also with the hardtop they keep the boom off of the solar panels. Have had Mack Pack even longer as I am short and had to climb mast steps to put on sail covers on. Everything can be done from the deck.
Also, I have three reefs in the main. Normally I keep first and second rigged. I often set the first reef as White Wings is better balanced configured that way. I have a line running from the 2nd to the 3rd to assist getting the 3rd reef in reach if I had not rigged it earlier. When conditions warrant I rig the second and third before it gets bad.
I had one made for my F40/40 from Quantum in Richmond CA. Works great. Best investment I made. Putting the sail cover on used to take up to 45 minutes. Now we just release the halyard and zip it in.
If you have one made at Quantum I am sure that they can access the files from when they made mine.
Quantum measured my boat last month and am waiting to hear back from them on a quote. That is who I would use if I have one made. They’ve always been very reliable for any work they did for me. Good to hear their product worked well.
I don’t even take the halyard off. I go up on the mast steps and grab it and pull it down and loop it around a cleat that is mounted on the underside of my boom about 2’ back from the gooseneck. It keeps the halyard off the mast enough that it doesn’t “clank”
One downside that matters for shoulder issues: a stack pack doesn’t eliminate all tugging—you still have to flake/feed the sail and sometimes tension the lazy-jack lines, so check that the zipper is reachable from the deck and the lines are led aft. Also ask about zipper/thread UV life and whether the cover is designed to stay on while sailing; those are common wear points. TonyB’s experience suggests Quantum’s fit is good, but I’d confirm those details in the quote.
Thank you. That is helpful. I may solve the problem by getting a new shoulder. I am about to place an order for one. Black Friday sale.
