stain on hull/deck and starting of engine
Posted by msheehan1 (msheehan1@…>)
3 problems
  1. Rust stains on deck? Seems like someone in the boat yard send
    metal shaving around, this rust stains.
  2. I also have some stains on the hull. I have tried rubbing
    compound, grease remover, windex, softscrub etc etc. Nothing take it
    out.
  3. Last problem. My diesel engine will not start. I have had the
    same problem the last two years. I get it running. I run it for
    about 15-20 minutes and it will not start again. It turns over etc
    etc. Can the engine get flooded? I had to have the boat yard look at
    it last year and it started for them and everything work fine for the
    year. What am I doing wrong.
Mike Sheehan
85 Freedom 32
Posted by Fred Molden (fredmolden@…>)
Mike, I would check the shutdown cable for kinking or more particularly for
it returning the shut off lever to the proper start position. You may even
readjust it to be sure it is not shutting off the engine when you think it
is ok to start. I know mine has a fine edge where the engine runs or does
not run.
Sent: Monday, May 22, 2006 9:25 AM
Subject: [freedomyachts2003] stain on hull/deck and starting of engine
3 problems
    out.
Mike Sheehan
85 Freedom 32
Yahoo! Groups Links
Rust stains on deck ! Use Whink, available in grocery stores in with the laundry soaps. DO NOT get any on your fingers ! ! Or, Naval Gelly. Andre, " Scaramanga "Fred Molden <fredmolden@…> wrote: Mike, I would check the shutdown cable for kinking or more particularly for it returning the shut off lever to the proper start position. You may even readjust it to be sure it is not shutting off the engine when you think it is ok to start. I know mine has a fine edge where the engine runs or does not run.----- Original Message ----- From: “msheehan1” <msheehan1@…>To: <freedomyachts2003@yahoogroups.com>Sent: Monday, May 22, 2006 9:25 AMSubject: [freedomyachts2003] stain on hull/deck and
starting of engine>3 problems>> 1. Rust stains on deck? Seems like someone in the boat yard send> metal shaving around, this rust stains.>> 2. I also have some stains on the hull. I have tried rubbing> compound, grease remover, windex, softscrub etc etc. Nothing take it> out.>> 3. Last problem. My diesel engine will not start. I have had the> same problem the last two years. I get it running. I run it for> about 15-20 minutes and it will not start again. It turns over etc> etc. Can the engine get flooded? I had to have the boat yard look at> it last year and it started for them and everything work fine for the> year. What am I doing wrong.>> Thanks,>> Mike Sheehan> 85 Freedom
32>>>>>>>> Yahoo! Groups Links>>>>>>
Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail
1 and 2) Sometimes an acidic product made
for fiberglass can also be used where others fail.
3. air in the lines could also do it. You
could rebleed the system. I had one situation where the valves were set wrong
for the dual parallel Racor filter setup after recommissioning in the spring. the
engine initially started and ran for about 20 minutes then died and would not
restart or stay on more then a few seconds.
the reader of this message is not the intended recipient or an agent responsible
for delivering it to the intended recipient, you are hereby notified that you
have received this document in error and that any review, dissemination,
distribution, or copying of this message is strictly prohibited. If you have
received this communication in error, please notify us immediately by e-mail,
and delete the original message.
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of msheehan1
3 problems
    it
    out.
    at
Mike Sheehan
85 Freedom 32
on the ‘air in lines’ subject -
make sure to also check the return line from engine to fuel tank for
blockages. these can create a backpressure that ends up acting very
much like air in the lines and will starve the engine just as
thoroughly.
— In freedomyachts2003@yahoogroups.com, “Alan Kusinitz”
<akusinitz@…> wrote:
1 and 2) Sometimes an acidic product made for fiberglass can also
be used
where others fail.
  1. air in the lines could also do it. You could rebleed the
    system. I had
    one situation where the valves were set wrong for the dual
    parallel Racor
    filter setup after recommissioning in the spring. the engine
    initially
    restart or stay
The information contained in this e-mail and any attachments is
intended
named above
the reader
responsible for
that you
dissemination,
If you have
by
e-mail, and delete the original message.
engine
3 problems
    take it
    out.
    look at
Mike Sheehan
85 Freedom 32
SPONSORED LINKS
Sailing
<http://groups.yahoo.com/gads?
t=ms&k=Sailing+schools&w1=Sailing+schools&w2=S
ailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adv
enture&
w6=Sailing&c=6&s=122&.sig=nM_33Bwh2_UhuqSYWZR8Xw> schools
Sailing
t=ms&k=Sailing+instruction&w1=Sailing+schools&
w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing
+advent
ure&w6=Sailing&c=6&s=122&.sig=PLKTippWs7H3hJMQiiV1Dg> instruction
Sailing
t=ms&k=Sailing+lesson&w1=Sailing+schools&w2=Sa
iling+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adve
nture&w
6=Sailing&c=6&s=122&.sig=BW-ssa-AtK1bKwgxZtYhsg> lesson
Sailing
t=ms&k=Sailing+course&w1=Sailing+schools&w2=Sa
nture&w
6=Sailing&c=6&s=122&.sig=iJziK8qHrpaIJG_Q19twrg> course
Sailing
t=ms&k=Sailing+adventure&w1=Sailing+schools&w2
=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+a
dventur
e&w6=Sailing&c=6&s=122&.sig=luRjwGYgtoRAVO_RIh446A> adventure
Sailing
t=ms&k=Sailing&w1=Sailing+schools&w2=Sailing+i
nstruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adventure&w
6=Saili
ng&c=6&s=122&.sig=H5HiiLFUXHyIpCEv0TmINg>
YAHOO! GROUPS LINKS
Maybe you are aware, but this needs to be said for the record. If
you are having trouble starting your engine and you are cranking for
more than 15 sec., shut off your raw water intake. Reopen it upon
starting. The danger is hydrolock which can do severe and expensive
damage.
Hydrolock is the condition which arises when the aqua muffler and
exhaust hose fill up with water from the action of the raw water
pump. Normally this water is expelled by the force of the exhaust
gasses, but with a non starting engine, the water will back up
through the exhaust valves into the cylinders. Since water is not
compressable, the resulting shock load can damage many moving parts
and some non moving ones. Head Gasket, Valve train, piston, con rod,
rings, to name a few. All expensive.
— In freedomyachts2003@yahoogroups.com, “msheehan1”
<msheehan1@…> wrote:
3 problems
    take it
    out.
    look at
Mike Sheehan
85 Freedom 32
— In freedomyachts2003@yahoogroups.com, “msheehan1” <msheehan1@…>
3 problems
    it
    out.
    at
Mike Sheehan
85 Freedom 32
1 and 2) Try “Sno-Bowl” toilet bowl cleaner. It’s a strong bleach of
some sort. It’s at the Dollar stores. For tougher stuff
try “Barkeeper’s Friend.” It’s in many grocery or hardware stores.
It’s powdered oxalic acid, it’s sorta looks like “Comet” but it
doesn’t have abrasives. Make a paste of it directly on the stain and
rub (and rub, and rub, and rub…) with a damp sponge. With enough
patience almost every stain will come out. It only works on smooth
surfaces though, not on non-skid.
  1. How do you get it going again? There’s an old mechanic’s saying
    that I`ve found to be true: “A running diesel that stops has a fuel
    problem.”
I’d go over the fuel system, bit by bit, start to finish, being
completely anal about it. Consider everything in the fuel system to
be guilty until proven innocent. Is air getting in the fuel line? If
it’s not air getting in and there’s no fuel leaking out, I’d check
for fuel starvation (a clog.) Originally there was a screen in the
bottom of the pick-up tube of the tank. I’d definitely pull that out
and leave it out. Round up the usual suspects after that: clogged
filters, collapsed or deteriorating hoses, loose fuel fitting bolts,
those (#$%*@^) little copper “crush” washers at the joints of the
metal fuel lines, etc. I’d just get rid of the old fuel, too, and
clean out the inside of the tank through the inspection port with a
plastic scrubby pad soaked in alcohol-based fuel dryer, using elbow
grease and paper towels. Get all the gunk out of the bottom. Get the
inside of the tank shiny bright. Refill with fresh fuel. Pump enough
fuel through the lines to insure that there’s fresh fuel everywhere.
Be obsessive. Go nuts. In my F32, I have more trouble with the fuel
system than everything else combined. It’s almost always fuel.
Beyond fuel I’d look at the exhaust elbow. It clogs up with rust over
time and the engine can’t expel the exhaust. It’s a consumable part,
I just change mine every 4 years or so. If you can’t find one,
Mastery Engines in St. Petersburg FL has them. (Unfortunately,
everything will probably be rusted together so hard you’ll have to
buy the exhaust tail piece and the pipe nipple that connects them,
too.)
Rick
Tallahassee
The stains will come out with Oxalic acid,available from any hardware
store… Make a solution of i cup to 1.5 gallons,brush on,and the iron stain
should come out . Rinse with fresh water. Good for waterline stains as well.
3 problems
    out.
Mike Sheehan
85 Freedom 32
Yahoo! Groups Links
Check the mixing elbow. Mine gets clogged and then shuts the engine down. I clean it and it runs fine!
Scott
Mixing elbow needs to be replaced once in a while, otherwise you will wind up with water in the cylinders, sooner or later.jsforgey@… wrote: Check the mixing elbow. Mine gets clogged and then shuts the engine down. I clean it and it runs fine! Scott
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
Posted by Jack George (chamela7@…>)
Hi Frank, Iam back in the USA, do you want me to send you the 100 back Ive got the booms and its no problem storing them. Let me know what you want? well Ive been fooling around with sails and have come up with some new ideas so far I have a prototype mizzen up, Its working better then the main!! Talk to me Jack.Frank Minelli <myslo@…> wrote: Mixing elbow needs to be replaced once in a while, otherwise you will wind up with water in the cylinders, sooner or later.jsforgey@… wrote: Check the mixing elbow. Mine gets clogged and then shuts the
engine down. I clean it and it runs fine! Scott Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
Sneak preview the all-new Yahoo.com. It’s not radically different. Just radically better.
