I have someone working on the boat on the hard today. He is trying to
take the strut out. Does anyone know how to access the bolts on the
inside of the hull?
inside of the hull?
Posted by esfogel@… (esfogel@…)
Funny you should ask. I just had my strut reglassed. The bolts are accessed (on
an F25) via the cockpit lazarettes. The fuel tank is just above the bolts but
you should have enough clearance to work.
-------------- Original message ----------------------
inside of the hull?
inside of the hull?
Thanks for that but my boat is a 32-don’t think that is the answer.
SWARD— On Mon, 9/22/08, esfogel@… <esfogel@…> wrote:
From: esfogel@… <esfogel@…>Subject: Re: [FreedomOwnersGroup] Strut removalTo: FreedomOwnersGroup@yahoogroups.comDate: Monday, September 22, 2008, 1:09 PM
Funny you should ask. I just had my strut reglassed. The bolts are accessed (on an F25) via the cockpit lazarettes. The fuel tank is just above the bolts but you should have enough clearance to work.------------ – Original message ------------ --------- -From: “Sward” <swardfullsail@ yahoo.com>> I have someone working on the boat on the hard today. He is trying to > take the strut out. Does anyone know how to access the bolts on the > inside of the hull?> >
Posted by Dwight Escalera (descalera1@…>)
I don’t specifically recall the F-32, but the F-36 has a “pocket” molded in the the port side of the hull to accept the strut. The bolts pass thru the strut, thru the side of this pocket into the interior under the aft berth were the nuts area accessed. After the bolts are tight, the pocket is filled with putty and faired to match the hull. Good Luck,Dwight On Sep 22, 2008, at 1:42 PM, Sward wrote:Thanks for that but my boat is a 32-don’t think that is the answer.“Life is a Reach, then you Jibe” SWARD— On Mon, 9/22/08, esfogel@comcast.net <esfogel@comcast.net>wrote:From: esfogel@comcast.net <esfogel@comcast.net>Subject: Re: [FreedomOwnersGroup] Strut removalTo: FreedomOwnersGroup@yahoogroups.comDate: Monday, September 22, 2008, 1:09 PMFunny you should ask. I just had my strut reglassed. The bolts are accessed (on an F25) via the cockpit lazarettes. The fuel tank is just above the bolts but you should have enough clearance to work.------------ – Original message ------------ --------- -From: “Sward” <swardfullsail@ yahoo.com>> I have someone working on the boat on the hard today. He is trying to > take the strut out. Does anyone know how to access the bolts on the > inside of the hull?> >
Posted by Robert (robert@…>)
Sward,
If your batteries are still in the small
cupboard under the companion way stairs, you have to remove the batteries,
trays and the supporting floor panel below. You will find your bolts there……
Best Regards
Robert
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Sward
Sent: Monday, September 22, 2008
1:43 PM
To:
Strut removal
Jibe”
SWARD
inside of the hull?
Posted by Ed Doran (skyebyrd2003@…>)
Yes. I know exactly where the bolts are on the F-32, if you’re talking about the 1983-1985 model. A marina owner punched my stut through the hull when he pulled my boat to put it on the hard. You are not going to like the answer but here it is: The bolts are located in the battery compartment, under the battery boxes. The only way to get to the bolts is to remove the batteries, cut the battery box and remove and then move the cables and hoses out of the way.
God Bless and Good Luck
Ed— On Mon, 9/22/08, Sward <swardfullsail@…> wrote:
From: Sward <swardfullsail@…>Subject: [FreedomOwnersGroup] Strut removalTo: FreedomOwnersGroup@yahoogroups.comDate: Monday, September 22, 2008, 12:04 PM
I have someone working on the boat on the hard today. He is trying to take the strut out. Does anyone know how to access the bolts on the inside of the hull?
Thank you-got it done.
SWARD— On Mon, 9/22/08, Robert <robert@…> wrote:
From: Robert <robert@…>Subject: RE: [FreedomOwnersGroup] Strut removalTo: FreedomOwnersGroup@yahoogroups.comDate: Monday, September 22, 2008, 2:06 PM
Sward,
If your batteries are still in the small cupboard under the companion way stairs, you have to remove the batteries, trays and the supporting floor panel below. You will find your bolts there……
Best Regards
Robert
From: FreedomOwnersGroup@ yahoogroups. com [mailto:FreedomOwne rsGroup@yahoogro ups.com] On Behalf Of SwardSent: Monday, September 22, 2008 1:43 PMTo: FreedomOwnersGroup@ yahoogroups. comSubject: Re: [FreedomOwnersGroup ] Strut removal
SWARD
— On Mon, 9/22/08, esfogel@comcast. net <esfogel@comcast. net> wrote:
From: esfogel@comcast. net <esfogel@comcast. net>Subject: Re: [FreedomOwnersGroup ] Strut removalTo: FreedomOwnersGroup@ yahoogroups. comDate: Monday, September 22, 2008, 1:09 PM
