Posted by valkyrie_1996 (akuehne@…>)
I recently bought a Kiwi Prop for my F-35. I have tried removing the
old fixed two blade prop with a wheel puller and as hard as I could
crank the puller, the prop won’t budge. I’m considering heating the
prop and was wondering if that could harm the cutlass bearing? Also,
if I try hitting the prop with a hammer will I harm the shaft seal or
transmission? I’m not concerned about saving the old prop, but I don’t
want to damage anything else in the removal process.
Art
Posted by vincet55 (vinceT55@…>)
— In freedomyachts2003@yahoogroups.com, “valkyrie_1996”
<akuehne@…> wrote:
Art,
I have found that a little WD-40 and lots of time (24hrs) works
wonders. I have sprayed it on very rusted bolts that I thought would
never come off, waited 24hrs and they came right off. WD-40 was
developed for NASA, so you might as well get the most of your already
spend tax dollars!
Best of luck, Vince.
Also,
or
don’t
Art
Posted by fredmolden@…> (fredmolden@…>)
I just pulled the prop off my 1996 F35. I loosened the nut a few turns then
applied as much torque to the puller as possible and struck the puller bolt.
The bolt was aligned with and up against the nut and shaft. I then heated
the brass prop shaft housing with a propane torch and again applied torque
to the puller and it slid off. I was told to not strike the prop with a
hammer, may be because of damage to the prop. I would avoid any lateral
impact or stress to the prop or shaft.
-----Original Message-----
[mailto:freedomyachts2003@yahoogroups.com] On Behalf Of valkyrie_1996
Sent: Monday, March 05, 2007 10:38 PM
Subject: [freedomyachts2003] stubborn prop removal
Art
Yahoo! Groups Links
Posted by svfantasy@… (svfantasy@…>)
Try heating the prop with a torch (not red hot). Then drip some cold water onto the shaft itself (not the prop), the shaft will cool quickly breaking free from the prop. Usually works every time.
Jay
