Syntron shaft seal
Posted by seychellois_lib (seychellois_lib@…>)
OK, I’ve owned my F30 hull #3 for six years. I have explored every
inch of her interior and exterior, touched every square inch of her
wood and glass and fiber and steel and yet I am still on a voyage of
discovery. How many surprises can a 30 foot fiberglass vessel hold??
The latest was a posting here regarding Syntron burping. I had heard
this before and discounted it. But the poster who mentioned the use of
the zerk fitting for burping just made it click in my mind, that makes
perfect sense!
For all these years and at the advice of both factory and the board I
have been greasing the shaft seal through the zerk. The good news is
that the seal is still performing well, the bad news is that it does
get hot. When I am steaming I always visit the engine compartment
every hour. One of my checks is Syntron temp. I put my fingers on it
to check. I can touch it but it’t too hot to leave my fingers on,
probably about 150 degrees (btw the Syntron spec. says the seal is
good to 300 degrees F). I also notice from time to time that it does
not heat up. I now realize that this is probably due to automatic
burping when a little water is able to sneak through the shaft seal
which it does from time to time at very low speed when there is a lot
of vibration.
Now, what to do. I have grease in the seal. Does the zerk fitting lead
to the outside world? Could I just flush some solvent through there to
melt the accumulated grease and allow the system to function as
designed?
Anyone have any recommendations?
Posted by svbagatelle (svbagatelle@…>)
I have had the dubious pleasure of replacing the Syntron seal twice
(the second time, just the innards) on my F30. It certainly does
lead to the outside world! The carbon rings within the seal grip
the shaft, but
there is water circulating around them (hence the ability to get
water to flow out through the vents when the allen nuts are
loosened). I don’t know how effective putting solvent down the
vents would be when your boat is in the water, however, unless
somehow you inject it under pressure.
Better, I think, to wait until you haul out. But actually
removing the seal would (I am told by FMC) destroy the water
tightness of the seal and make replacement necessary. So here, you
might just let the solvent soak in for a day or two, then flush it
out (making sure to clean up the mess as it dribbles out where the
shaft exits the hull).
Paul
F30 Bagatelle
— In freedomyachts2003@yahoogroups.com, “seychellois_lib”
of
hold??
heard
use of
makes
perfect sense!
board I
is
does
it
does
lot
of vibration.
lead
there to
designed?
The previous owner has used the zerk fitting to grease the seal, not
bleed it. He ruined the seal and scored the shaft. FMC quoted me
$350.00 to rebuild the seal and $450.00 to replace it. I still would
have had to replace the shaft. I installed a PSS Vented Shaft Seal
and have had no problems. If the shaft is not scored, you might want
to go back to the tried and true stuffing box with a modern dripless
packing.http://www.e-marine-inc.com/products/gfopacking/packing.html
— In freedomyachts2003@yahoogroups.com, “svbagatelle”
twice
the shaft, but
you
Paul
F30 Bagatelle
every
her
voyage
of
hold??
heard
use of
makes
perfect sense!
board I
news
is
does
on
it
is
does
seal
a
lot
of vibration.
fitting
lead
there to
designed?
correct link http://www.e-marine-
— In freedomyachts2003@yahoogroups.com, “macks011” <macks04@o…>
not
would
want
dripless
twice
does
grip
the shaft, but
you
it
Paul
F30 Bagatelle
every
of
her
voyage
of
hold??
heard
use of
that
makes
perfect sense!
board I
news
is
it
does
compartment
fingers
on
it
on,
seal
is
it
does
automatic
seal
is
a
lot
of vibration.
fitting
lead
there to
as
designed?
I assume you do not have a F30. At least on my boat, the PSS will
not fit–there’s not enough room between the shaft log and the
coupling.
Paul
F30 Bagatelle
<macks04@o…>
not
would
Seal
want
dripless
twice
does
grip
the shaft, but
get
here,
you
flush
it
Paul
F30 Bagatelle
every
of
her
voyage
of
vessel
hold??
had
heard
use of
that
makes
perfect sense!
board I
news
is
it
does
compartment
fingers
on
it
fingers
on,
seal
is
it
does
automatic
shaft
seal
is
a
lot
of vibration.
fitting
lead
through
there to
function
as
designed?
I have a F36 and yes, it was a very tight fit, but if you have
6.25"between the hull aft of the shaft log and the shaft coupling,
you can do it. Also, the std. Yanmar shaft coupling can be changed
out for a narrower one which will give you another .5" to 1.0". Talk
to PSS. their new rubber bellows can be compressed more than their
literature suggests.
coupling.
Paul
F30 Bagatelle
<macks04@o…>
<macks04@o…>
seal,
not
me
would
Seal
might
want
dripless
seal
twice
does
grip
the shaft, but
get
unless
here,
you
flush
it
where
Paul
F30 Bagatelle
explored
every
inch
of
her
voyage
of
vessel
hold??
had
heard
mentioned
use of
mind,
that
makes
perfect sense!
board I
good
news
is
that
it
does
compartment
fingers
on
it
fingers
on,
seal
is
that
it
does
automatic
shaft
seal
there
is
a
lot
of vibration.
fitting
lead
through
there to
function
as
designed?
You know, this actually looks like a good idea. I
like the low tech approach. A simple stuffing box that
you can check and fix without pulling the shaft. Other
than the occasional drip, very much reduced according
to the link, what other disadvantages are there to a
plain old stuffing box? What doe a stuffing box cost
not including install?
Mike
F 30 Jacqueine
<macks04@o…>
grease the seal,
not
FMC quoted me
it. I still
would
Vented Shaft Seal
scored, you might
want
a modern
dripless
“svbagatelle”
Syntron seal
twice
It certainly
does
within the seal
grip
the shaft, but
the ability to get
allen nuts are
solvent down the
however, unless
But actually
destroy the water
necessary. So here,
you
two, then flush
it
dribbles out where
Paul
F30 Bagatelle
“seychellois_lib”
have explored
every
every square inch
of
her
am still on a
voyage
of
fiberglass vessel
hold??
heard
who mentioned
use of
click in my mind,
that
makes
perfect sense!
factory and the
board I
zerk. The good
news
is
bad news is that
it
does
engine
compartment
I put my
fingers
on
it
leave my fingers
on,
spec. says the
seal
is
time to time that
it
does
probably due to
automatic
through the shaft
seal
speed when there
is
a
lot
of vibration.
Does the zerk
fitting
lead
solvent through
there to
system to function
as
designed?
Yahoo! for Good
Watch the Hurricane Katrina Shelter From The Storm concert
http://advision.webevents.yahoo.com/shelter
Checked out some on-line prices and the Buck Algonquin 1" packing
box goes for around $85.00. check out gotomarine.com,
onlinemarine.com
— In freedomyachts2003@yahoogroups.com, mike cunningham
Mike
F 30 Jacqueine
<macks04@o…>
grease the seal,
not
FMC quoted me
it. I still
would
Vented Shaft Seal
scored, you might
want
a modern
dripless
“svbagatelle”
Syntron seal
twice
It certainly
does
within the seal
grip
the shaft, but
the ability to get
allen nuts are
solvent down the
however, unless
But actually
destroy the water
necessary. So here,
you
two, then flush
it
dribbles out where
Paul
F30 Bagatelle
“seychellois_lib”
have explored
every
every square inch
of
her
am still on a
voyage
of
fiberglass vessel
hold??
heard
who mentioned
use of
click in my mind,
that
makes
perfect sense!
factory and the
board I
zerk. The good
news
is
bad news is that
it
does
engine
compartment
I put my
fingers
on
it
leave my fingers
on,
spec. says the
seal
is
time to time that
it
does
probably due to
automatic
through the shaft
seal
speed when there
is
a
lot
of vibration.
Does the zerk
fitting
lead
solvent through
there to
system to function
as
designed?
Yahoo! for Good
