thanks for the geniker info
Hi George -
Thanks for the reply and glad to hear it was worth the installation.
If you have the time, would you clarify what you mean by “our jib was enlarged by 1/3” ? Have you gone to a bow sprit and head sail jib?
Where exactly does your geniker halyard come out? How much higher is it than the standard 3/5 camber spar rig’s jib box on the mast?
At the moment I am dealing with Doyle for some repairs and restitching on my Doyle sails. Any reason that you know of to not use them for a geniker?
Destiny will be in Warren River boat Works with Paul Dennis for the winter, starting in early october, Bor installation of running back stays, a second main halyard and a head sail halyard if that proves to be appropriate.
Thanks very much.
John Ernst
Hi John. While you’re doing business with Doyle, you should take a
look at their nylon UPS Sail if you’re a cruiser. It’s cut between a
spinnaker and a genoa, and has a straight luff with a high tech line
insert, so you can use a roller furler. It’ll fly downwind without a
pole. I have one for my F25, and had one for my F21. Charlie
— In freedomyachts2003@yahoogroups.com, JoanJohn@a… wrote:
Hi George -
installation.
was
jib?
is it tha
restitching on my
geniker?
the winter,
a second
appropriate.
Thanks very much.
John Ernst
Charlie
Do you pole out your UPS or do you tack it on the top of the gun mount tube.
Andre, " Scaramanga " F 25 round mast.“Charlie L.” <clivaday@…> wrote:
Hi John. While you’re doing business with Doyle, you should take a look at their nylon UPS Sail if you’re a cruiser. It’s cut between a spinnaker and a genoa, and has a straight luff with a high tech line insert, so you can use a roller furler. It’ll fly downwind without a pole. I have one for my F25, and had one for my F21. Charlie— In freedomyachts2003@yahoogroups.com, JoanJohn@a… wrote:> Hi George → > Thanks for the reply and glad to hear it was worth the installation.> > If you have the time, would you clarify what you mean by “our jib was > enlarged by 1/3” ? Have you gone to a bow sprit and head sail jib? > > Where exactly does your geniker halyard come out? How much higher is it tha> n the standard 3/5 camber spar
rig’s jib box on the mast?> > At the moment I am dealing with Doyle for some repairs and restitching on my > Doyle sails. Any reason that you know of to not use them for a geniker?> > Destiny will be in Warren River boat Works with Paul Dennis for the winter, > starting in early october, Bor installation of running back stays, a second > main halyard and a head sail halyard if that proves to be appropriate.> > Thanks very much.> > John Ernst__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Hi Andre. For convenience, and ease of using the furler,I mostly
tack the UPS to the top of the gunmoubt tube, but I do not like the
way that point swivels. Sometimes I tack it to the ring on the end
of the “retracted” pole. I have not tried “extending” the pole while
flying it–too much trouble for me. When I bought the UPS I chose
the shorter luff length of 26.5’ (I lose another foot because of the
furler), instead of the “I” length of 28.5’. Good to hear from you.
Charlie
— In freedomyachts2003@yahoogroups.com, andre laviolette
<andrelaviolette@y…> wrote:
Charlie
mount tube.
a
line
a
Hi George -
installation.
jib
was
jib?
higher
is it tha
restitching on my
geniker?
the winter,
stays,
a second
appropriate.
Thanks very much.
John Ernst
YAHOO! GROUPS LINKS
Visit your group "freedomyachts2003" on the web.
Service.
Do You Yahoo!?
Thanks Charlie,
 I have been toying with the idea of an assymetric spinnaker or UPS flying 4 to 6 ? feet out front of the bow from a short sliding on deck pole ( or articulating sprit ) when on a long run or reach.
 Love the way this boat flies.
Andre .
Hi Andre. For convenience, and ease of using the furler,I mostly tack the UPS to the top of the gunmoubt tube, but I do not like the way that point swivels. Sometimes I tack it to the ring on the end of the “retracted” pole. I have not tried “extending” the pole while flying it–too much trouble for me. When I bought the UPS I chose the shorter luff length of 26.5’ (I lose another foot because of the furler), instead of the “I” length of 28.5’. Good to hear from you. Charlie — In freedomyachts2003@yahoogroups.com, andre laviolette <andrelaviolette@y…> wrote:> Charlie> > Do you pole out your UPS or do you tack it on the top of the gun mount tube.> > Andre, " Scaramanga " F 25 round mast.> > “Charlie L.” <clivaday@y…> wrote:> Hi John. While you’re doing
business with Doyle, you should take a > look at their nylon UPS Sail if you’re a cruiser. It’s cut between a > spinnaker and a genoa, and has a straight luff with a high tech line > insert, so you can use a roller furler. It’ll fly downwind without a > pole. I have one for my F25, and had one for my F21. Charlie> > > — In freedomyachts2003@yahoogroups.com, JoanJohn@a… wrote:> > Hi George → > > > Thanks for the reply and glad to hear it was worth the > installation.> > > > If you have the time, would you clarify what you mean by “our jib > was > > enlarged by 1/3” ? Have you gone to a bow sprit and head sail > jib? > > > > Where exactly does your geniker halyard come out? How much higher > is it tha> > n the standard 3/5 camber spar rig’s jib box
on the mast?> > > > At the moment I am dealing with Doyle for some repairs and > restitching on my > > Doyle sails. Any reason that you know of to not use them for a > geniker?> > > > Destiny will be in Warren River boat Works with Paul Dennis for > the winter, > > starting in early october, Bor installation of running back stays, > a second > > main halyard and a head sail halyard if that proves to be > appropriate.> > > > Thanks very much.> > > > John Ernst> > > > > ---------------------------------> YAHOO! GROUPS LINKS > > > Visit your group “freedomyachts2003” on the web.> > To unsubscribe from this group, send an email to:>
freedomyachts2003-unsubscribe@yahoogroups.com> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ---------------------------------> > > > __________________________________________________> Do You Yahoo!?> Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Hi Andre and Charlie,
To avoid an off-set for my furler I had a tab welded on top of the
Gun Mount sleeve that is on the centerline when the yard is stowed.
Works great and allays my concern of the off-set (even though
performance wise probably is not greatly affected).
Nick
“Blue Raven” F-21, #295
Thanks Charlie,
reach.
Andre .
while
you.
Charlie
Charlie
mount tube.
a
between
a
line
without
a
Hi George -
installation.
jib
was
sail
jib?
higher
is it tha
restitching on my
a
geniker?
for
the winter,
stays,
a second
appropriate.
Thanks very much.
John Ernst
YAHOO! GROUPS LINKS
Service.
Do You Yahoo!?
YAHOO! GROUPS LINKS
Service.
Do You Yahoo!?
