This post chronicles work on the Frankenmaker MK II Marine Public Works Department.
First view is of the Kubota 6HP Diesel motor partially stripped down.
Here’s a picture of the template I made of the alternator bracket when I was building the MK I.
Here is the bracket partially made up.
Here is the alternator mount finished and ready for primer.
This is the motor, it’s been degreased. The Ospho is settling in and it will be ready for paint tomorrow.
So here is a couple shots at the end of today. It was warm, dry and sunny for a change so the Ospho cured fast enough for me to paint.
They did not supply a template for making a mounting bracket for our Giant pumps. You are not seeing double here, I put the pump on our scanner and used that image for a template to cut the slots for the mounting plate. I know the engineers are cringing but really… you don’t need a cad drawing and a computer operated milling machine to get the job done right… you just need to be clever.
Here she is with the tacked up high pressure pump. I’ve adjusted for a good straight belt run and I can weld the supports and do the final welding on it now.
Next up is the refrigeration pump bracket and that’s going to take some cogitation.
You can also see that I’m starting to build a frame to mount the motor on. This is because I now need to install a device (that refrigeration pump) over on the cyl head side of the motor.
Here is the base frame with the refer pump mocked up.
Here is the Frankemaker in place getting the alignment sorted.
She’s really starting to look like a Frankenmaker now!
Adapter welded onto the exhaust flange to form the first part of the manifold/mixing arrangement.
Here is the fiberglass in the mold to make the air cowl.
And the mold popped off.
And the frame painted.
They say the devil is in the details and I’m down to the details now.
Here is the fuel pump and water pump relay installed. The relay keeps the water pump from coming on when there is no oil pressure (for obvious reasons).
Over here on this side you can see the completed air cowl with the blower attached to it. Also the completed exhaust arrangement with the water injection nipple. It’s all heat wrapped and ready.
I have the mounting tabs and rubber shock mounts installed now and will post a photo when I find my camera.
