Top of the Mast to ya!
Posted by Bob (rweeks6508@…>)
Ours has a cherry picker also but they have to do the work since they are not insured for someone outside the company to be in the bucket. I would like to do it myself so I know at least the first round is being done the way I want. I will most like replace what I think is a Perko anchor light with a LED and strobe combo, replace the VHF antenna, mount a TV antenna, and general inspection. I most like will give way and get them to do it all unless I can talk Fred (F35 Volant) into doing it…he’s old but still thinks he is young and foolish. Beers and a hugh steak may do it!BobOn Thu, Dec 4, 2008 at 1:44 PM, Herman and Gail Schiller wrote:Bob, One of our local marinas has a fixed mount cherry picker/bucket crane, specifically to work on sailboat masts. I’m sure there are other marinas near you that have similar arrangements. If you’re near North Carolina, then E-Mail me so that I can talk directions and the name of the marina. If you’re somewhere else, perhaps you can rent a truck-mounted cherry picker, and you then need to place your boat next to a solid bulkhead that’ll support the truck. In this way you can work safely and confidently on the masthead area. Herm At 11:22 AM 12/4/2008, you wrote: > >Hey a couple of things: > >1. Can someone desribe the top of the mast? I am too short to see >whats up there and its unnatural to be hanging from a string to see >whats up there! Are there holes for mounting things or do you have >the drag a drill up with you? And if you are hanging on for dear >live with two hands how do you use the drill? {:>) I am assuming >its SS…did Freedom using Perko anchoring lights not sure which >bulb to take up there with me…only want to go up once in my >lifetime. How are the sleeves (main halyard) taken out, is there a >pin to push out if they need to be replaced or do you have to take >the whole top off? It would be nice if young foolish person would >go up there with a camera and take some pictures… {:>) > >2. On the subject of Trawlers be careful of what you are asking >for! A friend of a friend has a 40’ trawler does 6 knots and does >not take the rough waters well! Also cost him !$700 to fill the >diesel tank. Of course you could get the more expensive model but I >have not seen anything under 50’ take the rough seas any better but >they are faster if thats what you really want. > >Bob > > > > > >On Thu, Dec 4, 2008 at 8:06 AM, Roger L. wrote: > >“> In fact, the only real disadvantage to using a sailboat as a motor >yacht is the tall pointy thing amidships.<”
Posted by amarsib@… (amarsib@…)
Hi Bob, I am curious as to what kind of tv antenna you will be using ThanksAnthony MarsibilioT SquareF 36/38Sent via BlackBerry by AT&TFrom: Bob Date: Thu, 04 Dec 2008 13:32:45 -0600 (CST)To: <FreedomOwnersGroup@yahoogroups.com>Subject: [FreedomOwnersGroup] Top of the Mast to ya! Ours has a cherry picker also but they have to do the work since they are not insured for someone outside the company to be in the bucket. I would like to do it myself so I know at least the first round is being done the way I want. I will most like replace what I think is a Perko anchor light with a LED and strobe combo, replace the VHF antenna, mount a TV antenna, and general inspection. I most like will give way and get them to do it all unless I can talk Fred (F35 Volant) into doing it…he’s old but still thinks he is young and foolish. Beers and a hugh steak may do it!BobOn Thu, Dec 4, 2008 at 1:44 PM, Herman and Gail Schiller wrote:Bob, One of our local marinas has a fixed mount cherry picker/bucket crane, specifically to work on sailboat masts. I’m sure there are other marinas near you that have similar arrangements. If you’re near North Carolina, then E-Mail me so that I can talk directions and the name of the marina. If you’re somewhere else, perhaps you can rent a truck-mounted cherry picker, and you then need to place your boat next to a solid bulkhead that’ll support the truck. In this way you can work safely and confidently on the masthead area. Herm At 11:22 AM 12/4/2008, you wrote: > >Hey a couple of things: > >1. Can someone desribe the top of the mast? I am too short to see >whats up there and its unnatural to be hanging from a string to see >whats up there! Are there holes for mounting things or do you have >the drag a drill up with you? And if you are hanging on for dear >live with two hands how do you use the drill? {:>) I am assuming >its SS…did Freedom using Perko anchoring lights not sure which >bulb to take up there with me…only want to go up once in my >lifetime. How are the sleeves (main halyard) taken out, is there a >pin to push out if they need to be replaced or do you have to take >the whole top off? It would be nice if young foolish person would >go up there with a camera and take some pictures… {:>) > >2. On the subject of Trawlers be careful of what you are asking >for! nbsp; A friend of a friend has a 40’ trawler does 6 knots and does >not take the rough waters well! Also cost him !$700 to fill the >diesel tank. Of course you could get the more expensive model but I >have not seen anything under 50’ take the rough seas any better but >they are faster if thats what you really want. > >Bob > > > > > >On Thu, Dec 4, 2008 at 8:06 AM, Roger L. wrote: > >“> In fact, the only real disadvantage to using a sailboat as a motor >yacht is the tall pointy thing amidships.<”
Posted by Fred Molden (fmolden@…>)
Beers and a steak, count me in!
If running a TV antenna you will need new
cable and a way to keep it from slapping. How long until spring gets
here?
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Bob
Sent: Thursday, December 04, 2008
2:33 PM
Cc: FreedomOwnersGroup@yahoogroups.com
of the Mast to ya!
Ours has a cherry
Bob
On
Bob,
One of
picker/bucket
there
you’re
directions
perhaps
to
truck.
masthead
area.
Herm
At
Hey
a couple of things:
whats
whats
live
its
bulb
lifetime.
pin
go
for!
not
diesel
have
they
Bob
On
yacht
