trailer info for f21
Posted by trekker149 (linseyjohnson6@…>)
Had my f21 on the hook, went there yesterday and she was gone, I
looked for her frantically on the causeways, asked the construction
workers, no one had seen her, found her a mile south, hard aground
on mud. Pulled her out with my j12 from the halyard. I had purchased
a trailer a week earlier, but it is not set up for sailboats, does
anyone have info on converting a trailer for sailboat use? Any
supplier have parts to raise the bunks? Any dimensions of the the
trailers or pictures of trailers would be appreciated, I have the
shallow draft f21.
Posted by Leslie Wilson (carlandsue@…>)
I have the same boat. Take a look at the following
site to see it on the bass boat trailer that I
modified for it. I will be glad to take any
measurments you want. Carl
was gone, I
the construction
south, hard aground
I had purchased
sailboats, does
sailboat use? Any
shallow draft f21.
Do you Yahoo!?
Yahoo! Mail - Helps protect you from nasty viruses.
http://promotions.yahoo.com/new_mail
Must be getting old. Forgot to include the site
address in the last email.
http://briefcase.yahoo.com/carlandsue
Click on My Photos and Freedom 21
was gone, I
the construction
south, hard aground
I had purchased
sailboats, does
sailboat use? Any
shallow draft f21.
Do You Yahoo!?
http://mail.yahoo.com
Thanks Carl for the pictures, do you know the span between the front
beams and the span between the rear beams? Also the depth from the
bunks to the bottom of the keel?
Thanks again.
— In freedomyachts2003@yahoogroups.com, Leslie Wilson
was gone, I
the construction
south, hard aground
I had purchased
sailboats, does
sailboat use? Any
shallow draft f21.
Do you Yahoo!?
Hi, Sorry to take so long getting the trailer
measurments to you. I will finally make it to my
storage area today take them. Carl
was gone, I
the construction
south, hard aground
I had purchased
sailboats, does
sailboat use? Any
shallow draft f21.
Do you Yahoo!?
Take Yahoo! Mail with you! Get it on your mobile phone.
http://mobile.yahoo.com/maildemo
The measurments are:
Span between rear bunk uprights is 5’ 9"
Span between front bunk uprights is 4’ 5"
Span between front and back uprights is 9’ 5"
Vertical distance between bottom of keel and top of
bunks at the front uprights is 24.5"
bunks at rear uprights is 20.5"
The back edge of the keel sits 2’ 7" forward of the
rear uprights.
Hope this helps. Carl
between the front
depth from the
Thanks again.
Do you Yahoo!?
Jazz up your holiday email with celebrity designs. Learn more.
http://celebrity.mail.yahoo.com
Thanks a lot Carl,
Now I can get started on setting the trailer up.
Linsey
rear uprights.
between the front
depth from the
Thanks again.
Do you Yahoo!?
