Anyone out there ever forget to take the plugs out of the transom after boating?
I did two weeks ago and went back to the boat today. I was surprise
by the cockpit being full of water, and the cabin having 2 inches on
water in it. Maybe it is time to install a bilge pump. Anyone have
advice on how install an automatic bilge pump?
Also, what sort of ingenuous ways have people come up with to
remember to pull the plugs? All I’ve come up with so far is to tie a
string from the plugs to the outboard in hopes that while raising the
outboard I will remember the plugs.
I used scupper “flaps” rather than plugs. They mount on the outboard side
of the transom and cover the scupper with a rubber flap that is held in a
closed position by tension.
When water enters the cockpit and migrates towards the stern, it pushes the
flap open and the water runs out.
I found these reasonably effective. On occasion they will let water in, but
always worked to let the water out.
West Marine calls them “scupper valves”. The 2 3/4 inch size is perfect for
the F21 scuppers.
boating?
after boating?
on
a
after boating?
on
a
