Traveller
Posted by Doug Chace (ch47_av8r@…>)
I’m sure that it’s out there somewhere, but I’m not finding it. What
is the part number for the Harken Traveller that our 21’s use? Mine
broke and the “jimmy-rig” that I’m using isn’t working.
Doug
Doug,
The end peice (stop) at the end of your traveler is Harken part
number 264 (2 screws) or 174 (1 screw). They are sold in pairs and
separate from the Harken track (part number 374 or 2725). Remove the
good one and go to West Marine (or your local marine store that has
Harken parts and you will be able to buy a pair.
Nick
Doug
Nick,
I appreciate the info. I need another traveller stop as well,
however… What I’m looking for is the actual traveller block that
moves back and forth on the track connected to the fiddle block for
the main sheet. I took my broken one into a marine supply shop and
they just gave me the “RCA Dog” look.
I can now order the stop that broke when my traveller broke, but I
must continue to “endure” sailing with a ridiculous home made
contraption holding my main sheet in place. At least I’m sailing.
Could be worse.
Doug
— In freedom21@yahoogroups.com, “Nick Marino” <blueraven1@…>
Doug,
Nick
What
Mine
Doug
Doug, it’s the traveler car that you need. The best place for small boat parts is www.apsltd.com They have small boat parts you need.There store in Annapolis is really well stocked and you can order online.Toll free # 1-800-729-9767 BiffDoug Chace <ch47_av8r@…> wrote: Nick,I appreciate the info. I need another traveller stop as well, however… What I’m looking for is the actual traveller block that
moves back and forth on the track connected to the fiddle block for the main sheet. I took my broken one into a marine supply shop and they just gave me the “RCA Dog” look.I can now order the stop that broke when my traveller broke, but I must continue to “endure” sailing with a ridiculous home made contraption holding my main sheet in place. At least I’m sailing. Could be worse.Doug— In freedom21@yahoogroups.com, “Nick Marino” <blueraven1@…> wrote:>> Doug,> The end peice (stop) at the end of your traveler is Harken part > number 264 (2 screws) or 174 (1 screw). They are sold in pairs and > separate from the Harken track (part number 374 or 2725). Remove the > good one and go to West Marine (or your local marine store that has > Harken parts and you will be able to buy a pair.> Nick>
— In freedom21@yahoogroups.com, “Doug Chace” <ch47_av8r@> wrote:> >> > I’m sure that it’s out there somewhere, but I’m not finding it. What > > is the part number for the Harken Traveller that our 21’s use? Mine > > broke and the “jimmy-rig” that I’m using isn’t working. > > > > Thanks, > > Doug> >>
Hi Doug,
I think What you want is a Harken #172 small boat/high load car.
They are discontinued BUT you can order one at pyacht.com (call Kevin
at 877-379-2248. He says Harken still have them , 2 week delivery,
they are blue).
http://www.pyacht.net/cgi-local/SoftCart.exe/cgi-bin/pagegen.pl?
U+scstore+tgxy7812ff38d338+pr+HAR172
Keep us posted on progress.
Nick
Nick,
Could be worse.
Doug
— In freedom21@yahoogroups.com, “Nick Marino” <blueraven1@>
Doug,
has
Nick
it.
What
Mine
Doug
