I have two questions regarding my F-30 sloop rig. I have always kept my Lazy Jacks tight. Basically tie them on at the start of the season, and leave them. Are others seeing an increase in performance by loosening the lazy jacks once the main is up?
I have lost the tube portion (not the pole) of my gun-mount spinnaker apparatus. I am attempting to have one made as efforts to buy one have failed. I obtained a copy of the original plans from Gary Hoyt although changes had been made over the years. As I recall my former tube, it had some type of liner inside the tube. Does anyone know the material of that liner and the thickness? I am also curious about the bolt-does yours have some type of rubber washer that rests between the tube itself and the bowspirit? Any comments, recommendations or photos would be appreciated.
Kent Holden
F-30 Breakaway
Connecticut
YAHOO! GROUPS LINKS
Visit your group “freedomyachts2003” on the web.
To unsubscribe from this group, send an email to: freedomyachts2003-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
DISCLAIMER Do not transmit instructions regarding your account by e-mail; instructions transmitted by e-mail will not be accepted by us, and Gagnon Securities will not be responsible for carrying out such instructions. Gagnon Securities archives and reviews all outgoing and incoming e-mail. It may be produced at the request of regulators or in connection with civil litigations. Information contained herein has been obtained from sources believed to be reliable, but its accuracy and completeness, and that of the opinions based thereon, are not guaranteed. This e-mail is not an offer to buy or sell or a solicitation of an offer to buy or sell securities.
I have a solid vang and adjust my lazyjacks so the boom just clears
the bimini. This is lower than the sailing position. When dropping
the sail, the boom is vanged down and the jacks are tight. sailing,
the’re loose. No further adjusting.
instructions.
performance
recall
comments,
instructions.
e-
to
The material inside the tube looked like PVC cut from a pipe that would
fit inside the tube. I put some Teflon from a roll I bought from a
woodworking store and lined the tube with that to decrease fiction. I
am talking about a F-21 but this should apply to all tubes.
of that liner and the thickness? >
If I had my druthers, I’d use teflon for the liner. If not that, then
Ultra high molecular weight polyethylene (UHMWPE). You want
self-lubricating characteristics, which PVC is lacking. Herm
