Does anyone have the triangular (corner to corner to corner) dimensions for the wrap around sails for UK F35 Cat Ketch. A sail maker has requested these dimension before he can quote. Measuring the sails in situ is not easy, even on a calm day and am just about to go are sailing for 10 weeks.
Thanks in anticipation.
I may be able to help. Iām sailing on another boat but will be at home in 2 days and could look up my records for what they are. Or just measure it. They might be in the owners manual in the group. I uploaded it some considerable time ago
Thanks for posting this drawing. The table in the top left has all the dimensions required. Perfect. Thanks
Kind Regards
Paul
Thanks for posting. Much appreciated.
I have found the measurements of my old mainsail, which had the large headboards to give a little more sail area. I put them on a drawing to get a new sail made, but if you go with the original double ply, they will give a reasonable fit. I had a zip pocket put in so that the aft two thirds of the sail was single ply, and thus lighter, but you need to ensure there is a hole to pass the reefing pennants through, since they pass through a block attached to the harness which holds the boom up.
The length of the luff, leech and foot will be standard for this model.
Regards,
Gerald
Apologies for delay in response. Dimensions are perfect. Thanks
Rgds Paul
