Posted by scott_shuler (scott_shuler@…>)
There are depressions at the stern of my F-21 along the rails where
water accumulates. Anyone else have this? Anyone done anything to keep
it from happening?
it from happening?
Posted by mitya fonin (mitbok1@…>)
I think its one of the design flows Freedom yachts overlooked.
There is really no easy solution to this.scott_shuler <scott_shuler@…> wrote:
There are depressions at the stern of my F-21 along the rails where water accumulates. Anyone else have this? Anyone done anything to keep it from happening?
Yahoo! FareChase - Search multiple travel sites in one click.
Posted by Verle Utzinger (verleu@…>)
the design was changed in 1985 model freedom 21. the
water drains at thethe area just before the stern
cleets.
the rails where
it from happening?
Yahoo! Mail - PC Magazine Editors’ Choice 2005
http://mail.yahoo.com
To get rid of the accumulated water, I had my yard drill a 3/16 inch
hole (angled down and outboard) trying to come out in the channel under
deck lip. Apply resin in the hole with a ear swab to seal the bare
fiberglass but keep the hole open. You have to use a right-angle drill
(with a short drill bit) to position the drill correctly. My boat was
out of the water (recommended) which made positioning the drill much
more easy. I still have to clean debris from the hole periodically but
the result is far better than before. This is not a new fix but was
posted on the old F-21 site a couple years ago.
— In freedom21@yahoogroups.com, “scott_shuler” <scott_shuler@y…>
keep
it from happening?
Posted by Paul Monette (pmonette@…>)
I have the same holes on my F-21. The only
problem is the debris which plugs them from time to time. I keep a pipe clean
on my boat to clean out the holes.
From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of Nick Marino
Sent: Monday, November 07, 2005
8:54 PM
To: freedom21@yahoogroups.com
Subject: [freedom21] Re: Water
accumulating in depressions at stern.
a new fix but was
keep
it from happening?
I just drilled the drain holes as well. Could not get the right angle and ended up drilling in a way that it went through deck inside the boat and out through the hull. To fix this I glued in tubes cut from a discarded fishing road ( not sure if Fiberglas or carbon fiber ) and epoxyed around openings on each end. Works perfect so far.Paul Monette <pmonette@…> wrote: I have the same holes on my F-21. The only problem is the debris which plugs them from time to time. I keep a pipe clean on my boat to clean out the holes. From: freedom21@yahoogroups.com [mailto:freedom21@yahoogroups.com] On Behalf Of Nick MarinoSent: Monday, November 07, 2005 8:54 PMTo: freedom21@yahoogroups.comSubject: [freedom21] Re: Water accumulating in depressions at
stern. To get rid of the accumulated water, I had my yard drill a 3/16 inch hole (angled down and outboard) trying to come out in the channel under deck lip. Apply resin in the hole with a ear swab to seal the bare fiberglass but keep the hole open. You have to use a right-angle drill (with a short drill bit) to position the drill correctly. My boat was out of the water
(recommended) which made positioning the drill much more easy. I still have to clean debris from the hole periodically but the result is far better than before. This is not a new fix but was posted on the old F-21 site a couple years ago.— In freedom21@yahoogroups.com, “scott_shuler” <scott_shuler@y…> wrote:>> There are depressions at the stern of my F-21 along the rails where > water accumulates. Anyone else have this? Anyone done anything to keep > it from
happening?>
Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates.
