Wilf''s Hoist
I just posted another set of pictures in the photo section. The folder
is called “Hoist.” These photos are unnamed because I don’t know how
to do that. They are simple photos without need for captions. There’s
a couple of pix of the two 3x2’s supported by garbage cans as I plane
down the sharp edges. There’s the stain/sealer being put on. Finally,
there’s the two 3x2’s leaning up against the condo drying. Oh, yes,
there’s some pix of the boomvang hanging from the ceiling, which will
be my hoist. So far things are going well. I still have to drill the
holes, figure out how to saw a 12 degree angle (that’s probably not
going to happen), put the hing on, and get the bolt which holds the
snap-lock thing. I also plan to put a coat of clear poly-something on
the 3x2’s to keep the sun and weather from doing their evil work. A
buddy told me to do that today. I’m working on the rubber boots for
the bottom of the legs where it rests on the boat. Any suggestions
appreciated. Something easy, like, “Go dip the ends in ________, which
you can buy locally.”
More later. I plan to hoist of the mast on dry land when I get this
thing finished. I’ll probably do it alone. Prayers and good thoughts
on that day.
Allen
Our prayers are with you. Good luck…Allen McClung <amcclung@…> wrote: I just posted another set of pictures in the photo section. The folder is called “Hoist.” These photos are unnamed because I don’t know how to do that. They are simple photos without need for captions. There’s a couple of pix of the two 3x2’s supported by garbage cans as I plane down the sharp edges. There’s the stain/sealer being put on. Finally, there’s the two 3x2’s leaning up against the condo drying. Oh, yes, there’s some pix of the boomvang hanging from the ceiling, which will be my hoist. So far things are going well. I still have to drill the holes, figure out how to saw a 12 degree angle (that’s probably not going to happen), put the hing on, and get the bolt which holds the
snap-lock thing. I also plan to put a coat of clear poly-something on the 3x2’s to keep the sun and weather from doing their evil work. A buddy told me to do that today. I’m working on the rubber boots for the bottom of the legs where it rests on the boat. Any suggestions appreciated. Something easy, like, “Go dip the ends in ________, which you can buy locally.” More later. I plan to hoist of the mast on dry land when I get this thing finished. I’ll probably do it alone. Prayers and good thoughts on that day. Allen
Yahoo! FareChase - Search multiple travel sites in one click.
