Posted by reedjayt2004 (reedjayt@…>)
I have two winches on my freedom 35 a two speed Harken 42 and a power
two speed 44. I want to clean and oil them, but I can’t figure out
how to begin taking them apart. I downloaded the service manuals, but
they weren’t too clear. The manual winch has a screw down in the
socket, but when I try to turn it counter clockwise, it just turns the
winch in the low speed. The power winch doesn’t have a screw but a
piece that pushes down a cutoff switch when a winch handle is inserted.
I’m sure all you long time boat owners service your winches all the
time and I’m egually sure its just something stupid I’m missing. Any
help would be greatly appreciated.
Jay
Posted by Jay Glen (britann9225@…>)
I’m not familiar with your winches, however, most disasemble by removing a snap ring on top of the drum assembly. Use a small flathead screwdriver to lift up one end of the snap ring and pull it off. everything else will then lift off the spindle. reedjayt2004 <reedjayt@…> wrote: I have two winches on my freedom 35 a two speed Harken 42 and a power two speed 44. I want to clean and oil them, but I can’t figure out how to begin taking them apart. I downloaded the
service manuals, but they weren’t too clear. The manual winch has a screw down in the socket, but when I try to turn it counter clockwise, it just turns the winch in the low speed. The power winch doesn’t have a screw but a piece that pushes down a cutoff switch when a winch handle is inserted.I’m sure all you long time boat owners service your winches all the time and I’m egually sure its just something stupid I’m missing. Any help would be greatly appreciated.ThanksJayJay Glen KI6JTK s/v Fantasy Freedom 40 Cat-Ketch Hull # 60 San Francisco Bay 925-783-4132 svfantasy@…
Got a little couch potato?
Check out fun summer activities for kids.
Some winches have have split rings (like a
key ring) that if you look closely at the top of the winch you can see around
the shaft. There are special tools for removing them but a screwdriver will do.
Once that’s off everything just lifts off. I don’t know if your
winches like this but its pretty common.
Alan F-33 Hull #51 1982
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of reedjayt2004
Sent: Wednesday, July 04, 2007
5:05 PM
To:
Subject: [FreedomOwnersGroup]
Winch Service
42 and a power
Jay
Posted by katorpus (jrb@…>)
The self-tailing Barients disassemble by unscrewing the
tailing “stripper”…not entirely intuitive, but very workable.
Surely there’s a “blown-up” parts diagram of your Harkens floating
around on the net somewhere…
— In FreedomOwnersGroup@yahoogroups.com, “Alan Kusinitz”
<akusinitz@…> wrote:
Some winches have have split rings (like a key ring) that if you
look
closely at the top of the winch you can see around the shaft. There
are
special tools for removing them but a screwdriver will do. Once
that’s off
everything just lifts off. I don’t know if your winches like this
but its
pretty common.
reedjayt2004
Sent: Wednesday, July 04, 2007 5:05 PM
Subject: [FreedomOwnersGroup] Winch Service
power
but
inserted.
Any
Jay
Some dont-you have to remove what the Brits call a circlip.
Otherwise,all greasing and oiling (only)of the pawls is straightforward
mailto:FreedomOwnersGroup%40yahoogroups.com, “Alan Kusinitz”
look
are
that’s off
but its
pretty common.
mailto:FreedomOwnersGroup%40yahoogroups.com] On Behalf Of
reedjayt2004
power
but
inserted.
Any
Jay
