Wood trim, and refinishing
On Daiquiri, hull #103, unlike you folks, apparently, my companion way
woodwork is mahogany, as are the horizontal boards of the plexi hatch.
This wood requires constant maintenance outside, which, frankly, isn’t
worth it. The inside mahogany trim is also mahogany, but I remove it
in the fall and re-finish in my basement over the winter! I use
Epifanes high gloss, about three coats, and looks fine!
Bob
Daiquiri II
Bob,
Thanks for the advice. Sounds good.
Max
http://www.maxlent.com
