Posted by Barry Stellrecht (yak@…>)
We just purchased a F33 cat ketch with the original wrap-around sails
(or at least pretty old ones…if not the 1981 originals!) and
wishbone booms. The sails are more-or-less rigged, but I’ve got a few
questions about the rest of it:
The downhaul isn’t rigged. (Does anybody untie it to push the tack
up when stowing the sail?) My copy of the manual shows a line on the
mast collar from 9’oclock through the tack and then to 3’oclock. Is
this the right way to do it? -
My “headboard” is a wrap-around with a rope between the two ends
completing the circle. There is a loop (doubled overhand knot) in the
middle of it. Apparently I tie the hailyard onto this loop with a
bowline. I’m not sure if the sail hoisted up as high as it should have
like this or not. The F33 manual seems to show a different picture,
perhaps with a bridle in the halyard or something? My halyards do not
have any eyes or shackles in them. -
The reef lines are not rigged. Here is my best understanding from
looking at the parts available and the manual:
A. Tie to one side of wishbone.
B. Route up through reef clew
C. Route down to other side of wishbone and through turning block aft.
D. Run through block at end of boom (above outhaul)
E. Run (through the middle of the sail, I think) up to the reefed tack
or downhaul point. I have NO IDEA what this point is, but I figure
there is a block in here somehow…and maybe one of the three spares
I’ve got will work.
F. Run through turning block at mast collar
G. Route it along the deck back to the cockpit…I’ve got a diagram
and am not worried about this part. -
If I don’t have enough hardware to rig both main and mizzen reefs,
I figure that since the main is bigger, it is the one to put a reef
in. Is that right?
Thanks for any advice or opinions!
Barry
