Posted by hxschiller (schiller@…>)
I’ve discovered, after some aggressive cross-referencing that the FRAM
3593A oil filter fits the 2GM engine (and probably the 3GM too). Those
who own Honda Accords will recognize the filter number.
Gentlemen
I caution you
about saving a couple of dollars on a Non-Yenmar filter for your Yenmar. I
doubt that FRAM design that filter to the Yenmar specifications. It is
un-likely, that the filtration(micron-level), by-pass and pressure handling as
well as other attributes are “better” then those of the Yanmar.
It is not enough to have the threads and seal interface match.
Diesel engine
longevity comes from longer hours in relation to the number of cold starts and also
good maintenance. Operator abuse is the primarey cause of premature
engine failure, espically in sail boats.
Brian On S/V
Cayenne sailordude@…
-----Original Message-----
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of hxschiller
Sent: Tuesday, January 03,
2006 10:11 PM
Subject: [freedomyachts2003]
Yanmar 2GM lube oil filter
the 3GM too). Those
number.
You might want to look at this web site photo before you decide that it is worth saving $4 to buy the Fram instead of the Yanmar filter: http://www.handa-accessories.com/15400.jpg. If the difference between the Fram and the OEM Honda in the photo are representative of the difference between all Frams and all OEMs, then the extra $4 once a year seems like a small price to pay.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of hxschillerSent: Tuesday, January 03, 2006 10:11 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Yanmar 2GM lube oil filterI’ve discovered, after some aggressive cross-referencing that the FRAM 3593A oil filter fits the 2GM engine (and probably the 3GM too). Those who own Honda Accords will recognize the filter number.
Folks,
If you think you need better quality, but available at many outlets
including Walmart, I suggest FRAM TG3593A, the socalled “Tough
Guard” model. Herm (Freedom 28 Cat-sloop “Impulse”)
— In freedomyachts2003@yahoogroups.com, “Brian Guptil”
<sailordude@b…> wrote:
Gentlemen
I caution you about saving a couple of dollars on a Non-Yenmar
filter for
your Yenmar. I doubt that FRAM design that filter to the Yenmar
specifications. It is un-likely, that the filtration(micron-
level), by-pass
and pressure handling as well as other attributes are “better”
then those of
the Yanmar. It is not enough to have the threads and seal
interface match.Diesel engine longevity comes from longer hours in relation to the
number of
cold starts and also good maintenance. Operator abuse is the
primarey cause
of premature engine failure, espically in sail boats.Brian On S/V Cayenne mailto:sailordude@b...
sailordude@b…-----Original Message-----
FRAM
Those
YAHOO! GROUPS LINKS
Visit your group "freedomyachts2003
http://groups.yahoo.com/group/freedomyachts2003 " on the web.
<mailto:freedomyachts2003-unsubscribe@yahoogroups.com?
subject=Unsubscribe>
Your use of Yahoo! Groups is subject to the Yahoo!
http://docs.yahoo.com/info/terms/ Terms of Service.
